Hand Crank
Mike Edwards
Mike Edwards is offline
PostPosted: Fri Jul 29, 2005 4:17 am    Post subject: Hand Crank Reply with quote
Finally got around to installing the hand crank I bought from Mike Crip last year. What a blast! I may never use the starter again.
Anyway.....
I need a way to cover the hole in the rear tin. It is right by the muffler and I don't want to draw in that hot air. Just curious what others have used.
Thanks,
Mike
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Fri Jul 29, 2005 7:52 am    Post subject: Reply with quote
I plan to install a little swiveling metal piece on my tin with a bolt on one side and a little hook on the other, with some kind of rubber stopper between them.
I haven't really sketched it out well, but you get the idea. For some more vintage-approved ideas, look up "crank start tin" in the Classifieds section.
markie61
markie61 is offline
PostPosted: Sun Feb 25, 2007 4:09 pm    Post subject: Reply with quote
Old thread....
New video.....
Keys!!??? We don't need no stinkin' keys....!
Mark
Whut is that-there Thang!?
Chicks dig my Thing - so what if it's little and yellow...!?
Towel Rail
PostPosted: Sun Feb 25, 2007 4:39 pm    Post subject: Reply with quote
Coolness! I had not yet seen that video! Smile
Since my earlier post, I discovered that my frame horns were sprung enough that my engine was too misaligned to use the crank. Sad I'll have to wait until after the resto to crank-start this Thing...
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Go-SpeedRacer
Go-SpeedRacer is offline
PostPosted: Sun Feb 25, 2007 6:16 pm    Post subject: Reply with quote
You see where those tail lights are mounted, is that a Euro set up, not only are they bus tail lights, I assume but, they are down close to the bumper in lieu of up high on the slanted part. Looks pretty clean.
markie61
markie61 is offline
PostPosted: Sun Feb 25, 2007 7:59 pm    Post subject: Reply with quote
The spoken German on the video is another clue that it is a European vehicle Wink . I prefer the look of the orginal lights down low over the elephant feet up high on US models, but think the slickest are the aftermarket flat ones up high.
Mark
Ferretkona
Ferretkona is offline
PostPosted: Sun Feb 25, 2007 8:37 pm    Post subject: Reply with quote
All Things, 181, 182 (or whatever names were used) previous to our imported 73's and 74's came with the bus lights. 73 buses did not use them either.
Woreign
Woreign is offline
PostPosted: Mon Feb 26, 2007 6:11 am    Post subject: Reply with quote
It's a shame that the North American models didn't come with the crank... Probably because VW was afraid that someone would hurt themself and want to sue, or we're too lazy to use a crank and are expected to call roadside service!
By the way, what does the kit consist of? A crank, special drive pulley nut, and a rear engine tin with a hole in it?
markie61
markie61 is offline
PostPosted: Mon Feb 26, 2007 6:55 am    Post subject: Reply with quote
It also looks like like the crank handle itself has some sort of ratching mechanism/freewheel built in so the crank doesn't spin with the running engine and take someone's head off.
Mark
Towel Rail
PostPosted: Mon Feb 26, 2007 7:29 am    Post subject: Reply with quote
Mark
Nope. That's built into the nut. There are "ramps" built into the side of the nut that keep it from engaging with the crank once the engine is moving faster than the crank.
markie61
markie61 is offline
PostPosted: Mon Feb 26, 2007 9:06 am    Post subject: Reply with quote
Oh....in the video, it sounded like some sort of ratcheting sound.
Yeah, I'll bet that crank setup has more potential for hitting someone in the head than a gas heater blowing up...
Mark
oorwullie
oorwullie is offline
PostPosted: Mon Feb 26, 2007 10:35 am    Post subject: Reply with quote
Mark
not really, it's pretty foolproof provided you don't have your thumb around the handle and it kicks back!
i was rooting around in one of my sheds last week and discovered (among other things)2 more cranks i'd forgotten about. i think the bent one is from my 65 army bus(used regularly till i converted to 12v) and that the shorter one is from a 63 army bus i broke about 15 years ago, but it might be an original trekker one.
Towel Rail
PostPosted: Thu Mar 08, 2007 12:23 am    Post subject: Reply with quote
That longer one looks like it could work for a beetle (assuming you straightened it.)
lukesky
lukesky is offline
PostPosted: Thu Mar 08, 2007 9:24 pm    Post subject: Reply with quote
As far as the cover for the hole in the bumper (Towel Rail, you've seen this), the P.O. of mine took an old round trailer light plug socket and screwed it on into the hole, making it look like you'd plug the trailer lights in there. Of course, it took me a while (and TRail's help) to figure that with no trailer hitch and none of the wires being connected, it was unlikely that anyone would ever plug anything into it.
I have replaced it with a newer VW emblem.
You get what you get, and you don't throw a fit.
-Gabi
oorwullie
PostPosted: Fri Mar 09, 2007 1:35 am    Post subject: Reply with quote
i'll post a pic of the original rear tin with crank hole later. Arrow
oorwullie
PostPosted: Fri Mar 09, 2007 6:05 am    Post subject: Reply with quote
Video Bob
Video Bob is offline
PostPosted: Fri Mar 09, 2007 1:15 pm    Post subject: Reply with quote
Having been raised in the dark ages, when tractors were started with a crank, I offer this bit of information. Do not wrap your thumb around the crank handle. Place all fingers and thumb on the same side of the crank handle. Thus if the engine backfires, it will not break your thumb on the reverse spin. Age sometimes has it's benefits Razz Razz
Ya can't have too many Vdubs!
1956 Oval
1966 Beetle
1974 Thing
1974 Super Beetle
1976 Westy P22
oorwullie
PostPosted: Sat Mar 10, 2007 11:28 am    Post subject: Reply with quote
this is true. Wink
i learned at an early age with cement mixers and dumper trucks on building sites.
pewe_kodok
pewe_kodok is offline
PostPosted: Thu Mar 22, 2007 1:10 am    Post subject: Reply with quote
where i can get hand crank set? like special nut, and crank arm
