sagebus Samba Member
Joined: July 26, 2004 Posts: 310 Location: Temescal Valley, Corona California
Posted: Mon Aug 01, 2005 10:20 am Post subject: What is this Bosch relay for? |
Found this relay laying in my bus, Bosch 0 332 204 150.Searched the # on google and bus depot,no luck. _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Mon Aug 01, 2005 11:12 am Post subject: |
How many terminals are on it? What are the terminal numbers listed on the relay? Better yet, a picture?
andy |
Posted: Mon Aug 01, 2005 11:22 am Post subject: |
no camera, five terminals, 85,86, 87a,87,30 _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
Posted: Mon Aug 01, 2005 12:39 pm Post subject: |
That's a general purpose "horn relay" and is used in many applications where you need a simple relay. About the biggest variable in that kind of relay is the amperage it's rated for. 85/86 is the activating circuit. 30 is the current supply, and 87/87a is the current output.
andy |
Posted: Mon Aug 01, 2005 12:53 pm Post subject: |
would this work as a hot start relay? _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
twinfalls Samba Member
Joined: November 21, 2003 Posts: 2133 Location: France
Posted: Mon Aug 01, 2005 2:22 pm Post subject: |
sagebus wrote: |
would this work as a hot start relay? |
Is there a current ( Ampere ) rating ? A hot start relay needs about 30 A. _________________ Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba. |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Mon Aug 01, 2005 10:31 pm Post subject: Re: What is this Bosch relay for? |
sagebus wrote: |
Found this relay laying in my bus, Bosch 0 332 204 150.Searched the # on google and bus depot,no luck. |
It's one of several standard Bosch 20/30A auto relay with mounting bracket. 5 Terminals, normally open. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Posted: Mon Aug 01, 2005 11:08 pm Post subject: |
Yes it is 12v 20/30 amp w/mounting bracket, about one inch square.Has a Schematic on the side that reads 85 over a pictorial representation of a relay coil w/86 under it.Then 87a & 87 over what looks like a switch in the Schematic (closed) and a 30 under that.Guess I will throw it in the parts box untill I learn what I'm doing.Thanks for the help I shure get a lot from this forum. _________________ 1984 Vanagon GL, Wolfsburg Westy 1.9 ltr |
