dickcharlton Samba Member
Joined: February 09, 2004 Posts: 257 Location: Victoria, B.C., Cold Canada
Posted: Sat Aug 06, 2005 2:10 pm Post subject: sawzall or grinder |
I'm replacing the lower sills on my bus and I 'm wondering what everyone's opinions are on something.
I have always made do cutting metal with a grinder and cutting blade. I am just wondering if a sawzall works better? Are they better for following lines and getting in small places?
Is it worth investing in one?
Do blades wear out as fast as cutting disks?
thanks in advance. |
Foxx Uncle Meat
Joined: August 27, 2001 Posts: 4897 Location: at the computer,.......DUH!
Posted: Sat Aug 06, 2005 2:50 pm Post subject: |
it's a rough call,.. i've used both,but a sawzall is faster and doesn't heat the metal up as fast,but you have to be carefull and let the blade do the work, you can't force it.
i'm on my 2nd sawzall,i wore out my old one. _________________ Frank
OG JHC
59 panel
Sarcasm is the body's natural defense against stupidity. i seem to use a lot. |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Sat Aug 06, 2005 3:21 pm Post subject: |
Another way to get a nice straight line if not cutting deep is with a circular saw. Pop on a metal cutting blade(like a grinder disk). People use them for roof replacement and long panel cuts. You can set the depth easily. Run a piece of tape and follow the lines. _________________ The honey-do list put my project on hold....... |
bmtx Samba Member
Joined: December 28, 2004 Posts: 606 Location: The Lone Star State
Posted: Sat Aug 06, 2005 3:45 pm Post subject: |
Every shop needs a sawzall, it will pay for itself, wether you do the sills with it or not. |
Posted: Sat Aug 06, 2005 4:18 pm Post subject: |
Agreed. And make sure you buy some the short blades, while you are buying the sawzall. You figure out why I say this quick enough. _________________ The honey-do list put my project on hold....... |
wheel607 Samba Member
Posted: Mon Aug 08, 2005 1:01 pm Post subject: |
Sawzall always first if you have enough support from surrounding braces. If you are out in the middle of a panel with no support, then gringer or shear. As said before, Sawzall used properly will not heat the metal like grind does. |
jwvert Samba Member
Joined: February 27, 2004 Posts: 138 Location: Texas.
Posted: Mon Aug 08, 2005 7:22 pm Post subject: |
Really need sawzall, angle grinder and air saw. Air saw good for fine work, cutting out for new body panels.
JW |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Mon Aug 08, 2005 8:30 pm Post subject: |
A nibbler is nice to have too. I use all of the above and a nibbler depending on the cut. |
