levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Aug 08, 2005 3:50 pm Post subject: Procedure for changing 85 Vanagon gear oil? |
I'm guilty of never changing the gear oil fluid. Never! And I know it oughta be done cause it's tough shifting.....so, after an hour of fruitless search results?
(I did get the procedure for air cooled , not sure that'll help with this 85 1.9 )
Is it a 17 mm bolt I need to find?
Is there also a drain plug? or do I need a turkey baster to pull fluid?
I don't want to stir up the gl4 vs. gl5 controversy...I'm going with the redline mt-90.
A gallon of that stuff be enough? |
r39o Samba Polizei
Posted: Mon Aug 08, 2005 4:26 pm Post subject: |
How about you poke your nose under there and look? An 85 sits high enough so you can do that. I know, I was just under there the other day. The standard drain VW drain / fill plug is 17mm. Go look in the Bentley or your owners manual for fill quantity. Ya fill till it runs out. If you filled a gallon in, my gosh that would be amazing. BTW: You will need a pump to put it in.
It is an awfully good idea to put in magnetic plugs and do not overtighten as they are tapered. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Joined: November 09, 2002 Posts: 154 Location: Portland OR
Posted: Mon Aug 08, 2005 8:49 pm Post subject: |
i'm able to get the fluid in there without a pump. i use the quart (i think its a quart?) size bottleand you can tip it upside down and get the end in the hole. get some rags and cardboard cause you'll probably lose a little.... mine is an 82 so maybe the ability to do this is not there on a watercooled. |
Ericthenorse Samba Member
Joined: October 03, 2004 Posts: 782 Location: Los Osos CA.
Posted: Mon Aug 08, 2005 10:53 pm Post subject: |
Somebody needs a nap...... What you are looking for is a big 17mm allen wrench. to use on the plug at the bottom of the tranny. the book says that you can use 3.7 quarts, but that is for a new tranny. You will not be able to get all of the old stuff out, so I would guess it will take about 3 quarts. This stuff is thick, so don't let it fool you . When it starts to spill back, give it a few seconds and see if it has leveled off. You can stick the end of your finger in and feel around to see how close you are. You can probably get a big 17mm allen socket at your local parts store since it is the same size as a lot of other Audi and VW cars... _________________ '69 bug--rusty as hell
'91 vanagon carrat-slammed,5 speed,4 wheel disks,17x8.5's |
angelchild Samba Member
Joined: July 06, 2004 Posts: 223 Location: Newfoundland, CANADA
Posted: Mon Aug 08, 2005 11:05 pm Post subject: filling |
to fill it, I used one of those bendy accordian end funnels.....put the end into the fill hole, and accordian bended it so the funnel was facing up and resting on suspension 'parts'...then you can pour your tranny oil in from the side reaching in just above & in front of (or was that behind?...can't remember) the wheel (a light helps to make sure your pouring into the funnel!) _________________ 64 Cal-Look Beetle |
Posted: Mon Aug 08, 2005 11:10 pm Post subject: |
It comes out here... park on a hill , or jack up the front of your van to help it all run out.
It goes in here. passengers side, up near the front of the tranny, about 1/3 of the way up.
I would like to thank my EXTRA 5 SPEED... for helping me in this demonstration.....
(you heard right... I might be letting a perfectly good 5 speed go up for sale at a bargain price....) _________________ '69 bug--rusty as hell
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Tue Aug 09, 2005 5:40 am Post subject: |
Hey Eric, I noticed the bike wheel, do you race 'cross? |
r39o Samba Polizei
Posted: Tue Aug 09, 2005 10:13 am Post subject: |
Why do they insist on painting them blacK???? Too lazy to do some scrubbing? It sure does not make spotting leaks any easier. UGH. Rant off... _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
levi Samba Member
Posted: Tue Aug 09, 2005 12:54 pm Post subject: |
Thanks guys, you're making it impossible for me to put this off any longer, and that's just what a lazy bastard like me needs.........put in my order on the oil about 5 minutes ago.
A 5 speed huh? Damn, don't tempt me...... |
Posted: Tue Aug 09, 2005 2:55 pm Post subject: |
No 'cross racing, but I did just get a hardtail mountain bike to do a little ammature downhill. They have a "Clidesdale" class that is made just for us big fat bastards(6'5"-275lbs) _________________ '69 bug--rusty as hell
Paulbeard Samba Member
Posted: Sun Oct 29, 2017 10:43 am Post subject: Re: procedure for changing 85 vanagon gear oil ? |
Now I wonder if this has ever been done to mine? Swepco 201 seems to be the preferred brand, so that's ordered…
No shifting problems but it does whine a bit. Maybe this is why.
I wonder how much will drain… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Sun Oct 29, 2017 11:58 am Post subject: Re: procedure for changing 85 vanagon gear oil ? |
Just to add to the conversation, the owners manual states that the transmission oil does not need to be changed.
from page 102:
The final drive requires hypoid oil SAE 90,
which does not have to be changed.
How can this be? Well the reason we change engine oil is because of the gasoline and combustion contaminants, which break down the properties of the oil's ability to lubricate. The transmission is a closed box with a magnet to collect all the wear particles from the gears and bearings. So if you think about it a little, what is there to change the chemistry of the transmission oil? I think I changed mine because it made me feel better, that and a little fear. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Merian Samba Member
Posted: Sun Oct 29, 2017 12:35 pm Post subject: Re: procedure for changing 85 vanagon gear oil ? |
it still needs to be changed - VW did not think people would be crazy enuff to keep their vehicles for 30 years
change it every 5-10 years or 75-100k miles, which ever comes first
from discussions with chemists, engineers and tech reps. at various oil co.s (boutique included), they all think the shelf life of engine or gear oil is no longer than 5 years
OTOH, it sits still and may separate on the shelf, so if used it will be mixed and you can maybe extend the interval some
OTOOH, a deda vanagon can sit for a long time too - and they die pretty frequently _________________ .... |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Sun Oct 29, 2017 7:44 pm Post subject: Re: procedure for changing 85 vanagon gear oil ? |
davideric9 wrote: |
from page 102:
How can this be? Well the reason we change engine oil is because of the gasoline and combustion contaminants, which break down the properties of the oil's ability to lubricate. |
The transmission is built to last the "lifetime of the vehicle", something like 100,000 miles. Vanagons, in general, easily serve out their "lifetime" but by the end they're swimming in their own barf, shortening the life of lots of valuable parts that you may have wanted to use again. The lifetime oil is a manufacturer recommended hari-kiri that you can opt out of - if longer trans life is desired.
The engine is different, due to the contaminants of combustion, engine oil must be changed several times (for the engine to last the "lifetime of the vehicle").
davideric9 wrote: |
The transmission is a closed box with a magnet to collect all the wear particles from the gears and bearings. So if you think about it a little, what is there to change the chemistry of the transmission oil? |
The magnet does not collect "all the wear particles". It holds the large broken-off particles (if any). It's right there next to the Ring gear, a 6 inch gear that spins at 700 RPM at 65mph where the tooth speed is 22 feet per second. The violent motion in the thick fluid washes a lot of the of trash off the magnet. Then every night, the magnet gathers some nearby trash for tomorrow's wash-off. The rest of the trash just falls downward as far as it can wherever it is, during the time the oil is motionless.
To conclude your oil is "good" by looking at your magnet, your magnet should have areas that are devoid of metal. If it's completely "full" it's no longer effective and your time to change oil was passed a long time ago.
Oil can be expected to "meet its spec" for 5 years. So it's not "dead" in 5 years but the oil producer is no longer responsible for the oil "meeting its spec". Five years is an "industry accepted standard". I bet it mainly serves to goad you into to changing old oil (buying more oil).
davideric9 wrote: |
I think I changed mine because it made me feel better, that and a little fear. |
Understood. The trans doesn't fail quickly, it's hard to be sure that you're doing the right thing when you don't even know if you'll still own the van another 50,000 miles. But things are changing. There are no good used transaxles out there anymore, and rebuilds can cost $3-5,000 now. Vanagons are becoming valuable vehicles worthy of "proper maintenance".
And LOTS of folks are putting DOUBLE the horsepower thru their poorly maintained, old transaxles. And spinning them faster and harder. With reliable new, big engines, expect to drive them farther and faster. But don't give a thought to this crucial (now undersized) component.
This is the time where you wish someone changed the oil every 30K back while the trans was healthy. And every 15k as it got older and "soiled itself" sooner. GL4 & GL5 are only $15/gal it's not an expensive or difficult DIY maintenance item _________________
....KTMs, GasGas, SPOT mtb |
Bleyseng Samba Member
Posted: Mon Oct 30, 2017 8:32 am Post subject: Re: Procedure for changing 85 Vanagon gear oil? |
Swepco 201 90w has always been the oil of choice. It seems VW changed from every 30,000 miles of the Lifetime when all the auto manufacturers were advertising their cars as needing less maintenance ( time wasted in the dealer's shop). _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Sodo Samba Member
Posted: Mon Oct 30, 2017 8:44 am Post subject: Re: Procedure for changing 85 Vanagon gear oil? |
Bleyseng wrote: |
Swepco 201 90w has always been the oil of choice. |
I think Swepco 201 is a great oil for the "protection" especially for a big engine, but you have to be patient shifting for the first 10, 20 miles when it's cold. (PS I have a gallon of Swepco 201 that I'd like to sell, send a PM if interested). Thicker oil just HAS to offer better separation between the metal parts. Also when the trans is old and loose, thicker oil HAS to be better too. But don't grind your gears (& make metal in the oil) shift slower & easier... go easy. Syncroshop advises "shift with two fingers."
Something to be said about staying with "dino" oil in an old trans. Like waldi writes, synthetic oil in an old trans can wash all kinds of metal-contaminated trash off your gears and return it to circulation in the trans.
So you'd have to change your oil several times in short succession, which could be costly with synthetic. Your illustrious Sodo thinks there is a way to do it though (settle your expensive oil ) but that's a task for "the hobbyist" .
Bleyseng wrote: |
It seems VW changed from every 30,000 miles of the Lifetime when all the auto manufacturers were advertising their cars as needing less maintenance ( time wasted in the dealer's shop). |
I agree it's part of marketing, the mfrs present it to the new car buyer "as a benefit" of lower maintenance cost. Tthey know its built well enough to satisfy the original buyer for the "lifetime of the vehicle" (~100,000 miles swimming inits own barf). And the benefit for the mfr is the van gets "retired" taken off the road sooner, creating demand for new vehicle sales. The last thing they need is the van driving another 200,000 miles, where satisfied customers COULD be buying a new car.
The original owner doesn't care about 100,000 miles and onward, they have sold or traded the car. Only the antique'rs care about the second life of the car. _________________
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Mon Oct 30, 2017 10:30 am Post subject: Re: Procedure for changing 85 Vanagon gear oil? |
Step one. Set you van on the rear bumper. Remove drain plug. When oil stops running out reinstall drain plug.
Step two. Set van back on wheels. Fill with specified amount of oil. Check level as per manual. Adjust as necessary.
Yes, I did write manuals in a former life. |
Merian Samba Member
Posted: Mon Oct 30, 2017 11:31 am Post subject: Re: Procedure for changing 85 Vanagon gear oil? |
Thicker oil just HAS to offer better separation between the metal parts...
but only if it flows in between them and it may be too thick to do so.
Besides, the separation may be limited by other factors. _________________ .... |
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Fri Nov 03, 2017 11:48 am Post subject: Re: Procedure for changing 85 Vanagon gear oil? |
As I read elsewhere in my samba studies...
Open the fill port before draining. Otherwise, you might successfully drain the gear oil only to discover that the fill plug is stuck and you are unable to fill |
kamzcab86 Samba Moderator
Posted: Fri Nov 03, 2017 1:57 pm Post subject: Re: Procedure for changing 85 Vanagon gear oil? |
For those reading along who have automatics, there is no drain hole for the differential (where the gear oil goes). You'll either very carefully loosen the pan bolts and tilt a corner down to drain, or siphon/suck the fluid out of the fill hole:
(borrowed pic)
dgbeatty wrote: |
Step one. Set you van on the rear bumper. |
_________________ ~Kamz
2016 Golf GTI S
