ZENAK Samba Member
Posted: Wed May 15, 2013 9:29 pm Post subject: |
better yet, trace it, scan it, and post it for a template. |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Thu May 16, 2013 6:42 am Post subject: |
EverettB wrote: |
That is a 40hp engine.
Sounds normal. |
it is a bit confusing at first for us europeans that the US engine horsepower ratings are different from the original ratings.
In Germany a 1200cc with the removable generator stand has 34PS
In the US that is a 40 horse...
the 30PS motor is a 36 horse in the US
the original 24.5PS motor is a 30 horse in the US and so forth.
considering that there are actual 40, 42, 44 and 47PS motors in europe, you can just imagine that this is an easy mistake to make. _________________ regards
Uli
Buba Samba Member
Joined: February 23, 2003 Posts: 383 Location: Argentina
Posted: Tue Jun 11, 2013 8:43 pm Post subject: |
Hi Folks, can someone take this measures for me? I have to make the hole in my apron. If you can take them in milimeters will be great.
Now with a better pic.
A:
B:
C:
D:
E:
Best regards
Marcos
_________________ 52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Wed Jun 12, 2013 4:39 am Post subject: |
I have a 36hp '58 bus with crankstart apron and flat decklid. If I wanted to run a 1600cc motor in this bus can I simply switch the apron to a 59-65 style and use with factory 1600cc exhaust/tailpipe? I guess what I am asking is will the '58 decklid latch to the later apron? |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3096 Location: Alberta
Posted: Wed Jun 12, 2013 5:08 am Post subject: |
Marcos:
A= 39mm
B= 9mm
C= 10mm
D= 21mm
E= 2mm
The entire cutout is cut out of the front face and rear face of the apron. On the one I am using for measurement, those two faces do not line up perfectly top to bottom. Because of that, there is actually only 7mm space for C.
I hope that makes sense. I can't comment on any other aprons, but it would be prudent to get a second opinion.
buseric wrote: |
Yes
That is the configuration on my Sept 58 SC - aftermarket brakelight decklid and stock 59-65 apron. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin
Stocknazi Samba Member
Posted: Wed Jun 12, 2013 3:16 pm Post subject: |
buseric wrote: |
i believe the latch is in the same place on a 58 or 59-65 apron.
i did have an issue w/the tailpipe and damper hitting the rear bumper mount and had to make a spacer for the mount tab on the stock muffler
i am using a 65 decklid and apron combo _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Wed Jun 12, 2013 7:20 pm Post subject: |
Riff Raff wrote: |
Marcos:
A= 39mm
B= 9mm
C= 10mm
D= 21mm
E= 2mm
buseric wrote: |
Yes
That is the configuration on my Sept 58 SC - aftermarket brakelight decklid and stock 59-65 apron. |
Thanks. I thought it looked the same. |
Buba Samba Member
Posted: Sat Jun 15, 2013 2:30 pm Post subject: |
Riff Raff wrote: |
Marcos:
A= 39mm
B= 9mm
C= 10mm
D= 21mm
E= 2 mm
Great Riff Raff. I just see this answer
Regards
Marcos _________________ 52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug |
Frozensolidtacos Samba Member
Posted: Mon May 23, 2022 4:21 pm Post subject: Re: VW Bus rear apron comparisons |
I'm trying to repair holes like in this thread but have no reference to go off of.
Where the exhaust cutouts are, is the metal there suppose to be flat from top to bottom or curved? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon May 23, 2022 4:43 pm Post subject: Re: VW Bus rear apron comparisons |
Frozensolidtacos wrote: |
ALWAYS helps to know year of bus in question. Also good to at least read thru the first page with the images and explanations of each era of rear apron. So far as we know none of the buses should have more than one exhaust cut outs. _________________ In Stereo, Where Available! |
Posted: Mon May 23, 2022 4:47 pm Post subject: Re: VW Bus rear apron comparisons |
Eric&Barb wrote: |
ALWAYS helps to know year of bus in question. Also good to at least read thru the first page with the images and explanations of each era of rear apron. So far as we know none of the buses should have more than one exhaust cut outs. |
Sorry. 63 DC. |
Posted: Mon May 23, 2022 6:26 pm Post subject: Re: VW Bus rear apron comparisons |
Sorry. 63 DC. |
No worries. Center of the hole is about 11.5" or 32cm from left edge of apron. Problem is the hole is not just a round hole half cut into the apron. The places that would be corners of the hole (where it meets the lower straight edge of the apron) are each radiused with a curve on each side.
Your best bet is to get a ruined rear apron due to rust or upper damage, and use that for a repair piece. If you post an image of your apron and put "WTB" in front of the advert title with something like "ISO damaged rear apron for repair piece." or something like that in the classifieds. _________________ In Stereo, Where Available!
Posted: Mon May 23, 2022 6:35 pm Post subject: Re: VW Bus rear apron comparisons |
Other possibility is if you contact Klassicfab and see if they will make you a repair piece. Since they make the whole rear apron, it should be easy for them to make just part of it. _________________ In Stereo, Where Available! |
Posted: Mon May 23, 2022 6:54 pm Post subject: Re: VW Bus rear apron comparisons |
Eric&Barb wrote: |
Other possibility is if you contact Klassicfab and see if they will make you a repair piece. Since they make the whole rear apron, it should be easy for them to make just part of it. |
I figured where I need to fix and such for the cut outs. I just wanted to know if where the cutouts are is flat or curved. Mine is damaged curved so it's hard to tell which way it's suppose to go |
Posted: Mon May 23, 2022 8:14 pm Post subject: Re: VW Bus rear apron comparisons |
Also just like the lower straight edge the curves of the cut out have a slight flange of sheet metal bent forward. This is to stiffen the metal so it does not vibrate too badly that will cause cracking of the metal.
Here is a 1966 NOS apron EB uploaded to the gallery, cut out is same size:
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
