Electric Windshield Washer Pump Installation FAQ
Mr.Mexi
Mr.Mexi is offline
PostPosted: Mon Aug 23, 2010 8:24 pm    Post subject: Reply with quote
you guys may find this a usefull how 2 I prepared over on earlybay.....
http://forum.earlybay.com/viewtopic.php?f=31&t=18970&hilit=electric+washer
my resto thread: http://forum.earlybay.com/viewtopic.php?f=2&t=15384
1977_L63H_P27
1977_L63H_P27 is offline
PostPosted: Sat Aug 28, 2010 1:19 pm    Post subject: Reply with quote
Liveonjg wrote:
I installed a small momentary contact switch so operation of the washer remains the same. Keeps everything looking stock.
-John
Different switches, but a smooth installation. Over one year and it's still workin'. I really need to do that write up on mounting the pump in the bottle. Makes it vibration free Wink
busdaddy wrote:
...and try a few chubby ones until you find one you like.
1977 Westfalia P27 Green Bay Bus
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club
BajaCapt
BajaCapt is offline
PostPosted: Sun Aug 29, 2010 1:19 am    Post subject: Reply with quote
Excellent!
Thanks for sharing this cool idea! Now to find the switch, the Ebay guy mentioned in the link no longer selling, I will try locally.
Your switch looks pretty much like the one in my 71, thanks again Wink
Jose.
1970fun
1970fun is offline
PostPosted: Sun Aug 29, 2010 2:02 am    Post subject: Reply with quote
Why drill extra hole for switches?
Look at this one, did my van like this and ít works great!!
prairie_vw
prairie_vw is offline
PostPosted: Mon May 16, 2011 12:58 pm    Post subject: Reply with quote
anything wrong with this switch for wiring my washer pumper. I found it laying around and might as well use it if I can......thanks
http://www.amazon.com/Gardner-Bender-GSW-22-Button-Switch/dp/B000BW0YWG
1978 Champagne Edition
1977 Westy
#12, C, Bay Window forum hockey team
chabanais
chabanais is offline
PostPosted: Mon May 16, 2011 1:16 pm    Post subject: Reply with quote
Just use the stock switch. When you remove the button you'll see there's a long plastic tube. Cut out the back of the switch, zip tie your washer button there and when you push the stock button in it will push the washer button and activate the pump. I've had mine for 10 years always works.
"I spud therefore I yam."
stever1000
stever1000 is offline
PostPosted: Mon Feb 13, 2012 9:48 am    Post subject: Reply with quote
1977_L63H_P27 wrote:
-John
This looks great, how much modification is required to fit the momentary switch?
Liveonjg
Liveonjg is offline
PostPosted: Mon Feb 13, 2012 2:45 pm    Post subject: Reply with quote
All I had to do was open the hole up a bit.
Keep it acoustic.
77 FI 2L Westfalia - Ripple
77 FI 2L Westfalia - Althea
62 Dual Carb Single Cab - Lou
ivwshane
ivwshane is offline
PostPosted: Sun Feb 17, 2013 3:26 pm    Post subject: Reply with quote
I'm planning on doing this mod but I have some questions about the hoses. Is there any reason NOT to remove the hoses and flip them so that the longer lengths are on the passenger side and closer to the bottle and pump?
Or should I just get new hoses? If so what kind of hose and where? Can they be purchased at my local flaps?
Also where do I draw the power from? Specifically where on the fuse box should I attach it?
Casey Ryan
Casey Ryan is offline
PostPosted: Sun Feb 17, 2013 3:45 pm    Post subject: Reply with quote
I replaced the hoses with black airline hoses from a pet store. They have worked well and were easy to run. You can buy a Y splitter from the pet store too. Regarding lengths, it really doesn't matter so you should run them however you want.
For power, you can run it to the accessory fuse (7 i think) on your fuse block.
Casey
'78 Riviera Camper
Blog: www.facebook.com/VWBusBlog
ivwshane
ivwshane is offline
PostPosted: Sun Feb 17, 2013 3:49 pm    Post subject: Reply with quote
Casey
Thanks! One last question, am I reading this right? In order to get to the wiper switch (I have a 77 westy) I have to remove the steering wheel? I don't need to drill out the tamper proof bolt do I?
http://www.ratwell.com/technical/SteeringColumn.html
Casey Ryan
PostPosted: Sun Feb 17, 2013 7:41 pm    Post subject: Reply with quote
Casey
If you are wanting to do the stock-like hookup that the guys talked about earlier in this thread then you only need to remove the horn button and remove the main nut then slide out the cluster. You shouldn't need to take out that tamper-proof bolt.
I didn't do any of that fancy stuff even though I thought it was pretty cool. I just put a momentary switch on my dash next to the headlight switch and wired the pump into that. It's a helluva lot easier than taking apart the steering wheel. Yeah, it's not stock, but it's simple and it works.
My advice is to take the win of getting a pump in there and using a button on your dash or somewhere else. Save the dissembly of the steering column for a rainy day.
Casey
'78 Riviera Camper
Liveonjg
Liveonjg is offline
PostPosted: Sun Feb 17, 2013 10:48 pm    Post subject: Reply with quote
Casey
Casey
It really isn't that hard, do it right the first time and you won't have to do it again.
Keep it acoustic.
obnoxiousblue
obnoxiousblue is offline
PostPosted: Mon Feb 25, 2013 3:44 pm    Post subject: Reply with quote
A PO of my bus did an install here and actually did a decent job, I was impressed.
Turned out in addition to a wire coming loose, the pump motor was running, and shred healthy but it wouldn't pump, even with the motor below the height of the reservoir.
So, I bought the same motor that the OP used.
HS anyone else found an issue with these things spraying over the bus? Lol
I get some on the windscreen, but ALOT on the ceiling of my garage! Laughing
Mike
1964 Beetle
2001 Eurovan Camper
busdaddy
busdaddy is offline
PostPosted: Mon Feb 25, 2013 3:53 pm    Post subject: Reply with quote
You are aware the nozzles are adjustable, right? Wink
Слава Україні!
obnoxiousblue
PostPosted: Mon Feb 25, 2013 3:56 pm    Post subject: Reply with quote
You sir, never, ever ease to amaze me lol.
How do I do this thing you call "adjustment"? Lol
Mike
1964 Beetle
2001 Eurovan Camper
Yondermtn
Yondermtn is offline
PostPosted: Mon Feb 25, 2013 4:01 pm    Post subject: Reply with quote
Find something with a pointed end and stick it into the nozzle and adjust accordingly. The nozzle is kinda like a ball or BB that swivels in its housing.
busdaddy
busdaddy is offline
PostPosted: Mon Feb 25, 2013 4:05 pm    Post subject: Reply with quote
The unmentionable green book describes it with photos, section 4:10.9 Wink Razz
Слава Україні!
obnoxiousblue
PostPosted: Mon Feb 25, 2013 4:17 pm    Post subject: Reply with quote
I have that book!
Thanks!
Mike
1964 Beetle
2001 Eurovan Camper
obnoxiousblue
PostPosted: Mon Feb 25, 2013 4:39 pm    Post subject: Reply with quote
Wow, that was so simple. Took like three shots to get both dusted and spraying in the same angle/height. But it's done!
Thanks again Busdaddy!
Mike
1964 Beetle
2001 Eurovan Camper
Page 2 of 4
