M_atthewanderson Samba Member
Joined: January 25, 2005 Posts: 288 Location: Seattle
Posted: Sun Aug 14, 2005 5:35 pm Post subject: van dont turn over |
Okay my van runs smooth now but I cant start it with out push starting it. I have a 1980 manual 2.0 Vanagon and the starter cranks long and strong but it just doesn’t seem to want to turn over. It will turn over just fine after a little push I can not figure this one out? _________________ 1980 2.0 Sunroof Vanagon |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Mon Aug 15, 2005 6:38 am Post subject: |
First thing I would do is go check all your connections, grounds starter connections, all FI connections. You had the whole engine out not long ago, so something could have came loose. _________________ My Art:
http://www.instagram.com/flynn8552/ |
Randy in Maine Samba Member
Posted: Mon Aug 15, 2005 6:45 am Post subject: |
matt,
So when you go to start it with the key it will turn over nice, fast, and strong? Does this have anything to do with your recent distributor problem?
And the flap in your AFM is swinging freely?
I am with mightyart here, I like a bad connection at the starter or one of the grounds. Might be time to whip out that contact cleaner for all of the elctrical connections.
I know nothing about a idle stabilizer, but check it out as per your Bentley.
I assume that you are getting good spark, adequate fuel pressure (26 psi), and adequate voltage going to the FI?
For the life of me I cannot figure out why it will push start but not start off the starter. |
Posted: Mon Aug 15, 2005 10:22 am Post subject: |
thanks guys i will check those conections and clean them up _________________ 1980 2.0 Sunroof Vanagon |
