AndrewM Samba Member
Joined: February 18, 2002 Posts: 496 Location: Charlotte, NC
Posted: Sun Aug 14, 2005 7:17 pm Post subject: wiper switch smoke |
Today I was driving my 64 bus and I switched on the wipers. The wipers didn't come on. Next thing I see is a small bit of smoke and I smell something burning. The far right fuse on the fuse panel pops. I feel under the dash and the double wire on the right side of the 2 prong wiper switch is hot. Any ideas what's gone wrong??? |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Sun Aug 14, 2005 7:21 pm Post subject: Re: wiper switch smoke |
AndrewM wrote: |
Something shorted out, duh! _________________ -Andrew |
Posted: Sun Aug 14, 2005 7:28 pm Post subject: |
Thanks for the advise there Einstein. jk.
I replaced the fuse right away pulled the switch back and and pop, blew the second fuse. |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Sun Aug 14, 2005 9:55 pm Post subject: |
If you don't find a shorted wire, more than likely the wiper gearbox or linkage is frozen up so the motor is drawing WAAY too much current. Pull the black/purple wire off the switch or off the motor. If you still blow fuses then you have a short in the switch or wiring. If it doesn't blow fuses with the wire pulled, then it's the motor, gearbox and/or linkage. Good luck! |
Posted: Mon Aug 15, 2005 7:07 pm Post subject: |
I figured out what was up. A few weeks back my inner wiper arms popped off in a rainstorm. A few weeks later I pulled the parcel tray and popped the arms back on. While I was under there I took the wiper motor out to check out why both arms had popped off. When I put the wiper motor back in I accidentally switched the ground wire and the hot wire. When I pulled the switch the wipers worked, I guess the were running backward though, but you really can't tell since the wipers are doing what they are supposed to. I didn't need to use them until the other day and the engine was running this time when I turned them on. So I guess more current to pop the fuse?? Anyway they work now and I feel like a dumbass for switching the wires but at least I got a schooling on the wiper system.
Thanks dstefun for the advise and to Andrew from Gville, have fun with your new ride.(i saw Jake at the rock, you lucky bastard!) |
Andrew Samba Member
Posted: Mon Aug 15, 2005 7:25 pm Post subject: |
AndrewM wrote: |
Yep... _________________ -Andrew |
