Rob E UK Samba Member
Joined: August 05, 2003 Posts: 834 Location: Stratford-upon-Avon, U.K
Posted: Tue Jul 03, 2007 7:57 am Post subject: |
im just about to fit my b&p's after having them machined down on the piston skirt and rebalanced.
anyone comment on the power increase? |
glutamodo The Android
Joined: July 13, 2004 Posts: 26323 Location: Douglas, WY
Posted: Tue Jul 03, 2007 2:14 pm Post subject: |
All the 40HP engines I've ever driven were already big-bore'd so I can't really say how much of a difference you'd notice between the two sizes. |
the.fordhams Samba Member
Joined: February 11, 2004 Posts: 471 Location: Charlotte, NC
Posted: Tue Jul 03, 2007 4:14 pm Post subject: |
A big bore kit will be noticeable - for me it took my vert from a 60mph machine to a 70 mph machine. This is subjective but as a comparison my 1600SP ragtop is a 75-80mph machine. Different gearing weight etc but hopefully you get the idea.
Rgds,
Al _________________ 63 OG Turkis Bug project
65 OG Safari Beige Notch
65 OG Pearl SO42 Patina
67 SO42 welding project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender |
rachel Samba Member
Joined: February 10, 2002 Posts: 29 Location: in front of this computer... f-that, my buses want me outside with them....
Posted: Tue Jul 03, 2007 6:20 pm Post subject: |
According to one source, regular 40 horse engines are 1192cc and a "big bore" 40 horse engine is 1385cc; those 200cc extra may make a big difference to a VW.
I think that the 40 horse in my bus is every bit the engine as the 1600SP in another bus but at a reduced top speed. Top speed for the 40 horse is 55MPH, top speed for the 1600SP is 65MPH.
The running gear in the 40 horse is stock-ish - the transmission, RGB, axles and backing plates are out of a '60, shifting into fourth gear is at about 30-35MPH. The running gear in the 1600SP is modified - the transmission is a 12-volt non-freeway flier, RGB axles and backing plates are '63 one-ton, shifting into fourth gear is at about 40-45MPH. |
House Minutia Militia
Posted: Thu Apr 01, 2010 7:12 am Post subject: |
Has anyone tried machining the new piston skirt to be similar to the old one to get around the clearance issue yet?
Or are you just knocking down the edges...? |
Posted: Thu Apr 01, 2010 2:19 pm Post subject: |
"Gerg" above has a dead link for a photo, it used to show how he was going to reshape his skirts. The important thing is to be uniform - all the pistons need to weigh the same when you're done, so just cutting the one or two pistons that hit the case isn't probably the best thing to do.
-Andy |
Posted: Thu Apr 01, 2010 2:27 pm Post subject: |
I was thinking of just machining the "New Mahle" to look like the "90's Cofap",
balancing them, and calling it a day...
Just wondering if anybody else has been doing that or are they hand
fitting / clearancing the troublesome one and then balancing the others to match.
I know this must come up quite often, I am surprised there isn't more talk about it.
TomSimon Samba Member
Posted: Sat Apr 03, 2010 12:01 am Post subject: |
while working on a project with my friend Greg Urrutia, we started talking about the big bore 40hp conversions we'd experienced
"When I worked at this independant shop back in the day" he said "our happiest customer was the one who brought in a tired 40horse and left with a big bore kit.... they usually called back later and said it was never that powerful when new, a completely different car!"
That was about the same as my one and only experience with a big bore 40 kit, my 63 ragtop (that I drove in college) was fun to drive again! |
JHvolks Samba Member
Joined: September 19, 2007 Posts: 98 Location: lancaster, pa
Posted: Wed May 26, 2010 12:37 pm Post subject: |
House wrote: |
OK, ran into the same 83mm/40hp clearance problem. So I filed and
filed just enough of the skirt to clear that case webbing. Then, since I
have a 1300 (69mm) crank installed, the bottom end of the number 3 connecting rod was hitting the bottom edge of the number 1 piston
on the edge just below the wrist pin, so I shaved that off as well.
Net Result: The New Mahle looks exactly like the 90's cofap!! Now
we will see if I can get the other 3 the same shape & weight. I did
make a template from clear mylar with a hole that slips over the wrist
pin. That should be a start. _________________ 1962 Beetle
1957 Beetle
1963 Single Cab
1959 Bus
1957 Beetle |
64vdub Samba Member
Joined: August 05, 2008 Posts: 614 Location: Sunny So. Cal
Posted: Mon May 23, 2011 8:43 pm Post subject: |
Has anyone used the "AA" brand of 83mm big-bore pistons? Not sure if they would need to be clearanced too. Thanks. _________________ 64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
Founding member of Derkaferklub, Southern Cal. since 2008
Q: Would you consider a trade? What do you collect?
A: I collect money
GO SF GIANTS! |
Chuey Samba Member
Joined: October 18, 2010 Posts: 858 Location: Oceanside, California
Posted: Tue May 31, 2011 9:26 pm Post subject: Try the seller. |
Wolfsberg West sells 1385 kits. They should know if they need modification.
Chuey |
Posted: Tue May 31, 2011 9:54 pm Post subject: |
Well, if they are the Mahle kits, they are probably going to need it, depending on your engine case.
I've not seen these AA big bore kits myself. I was just looking at the AA website and I'm not seeing where they sell kits they made themselves. There's a listing on AA, for the MAHLE sets that I found, which look like this:
but when you click on it, it says "Sorry, the product was not found." |
OvalWindowBucket Samba Member
Joined: April 23, 2003 Posts: 694 Location: Reviving my Microbus
Posted: Wed Jun 01, 2011 1:26 pm Post subject: |
I bought a set of AA 83mm Big Bore p&c from Mr. Motorhead (samba user). I can post pictures of the pistons/skirts soon, but I have not mocked up my motor to see if there are clearance issues. _________________ Wanted OG Basalt & Silver Beige interior panels for '63 Deluxe
http://www.thesamba.com/vw/classifieds/detail.php?id=1041828 |
Posted: Wed Jun 01, 2011 6:16 pm Post subject: |
The 83mm mahle pistons that I mentioned in the above post ( that I had to grind down) were purchased from WW.
After I ground the buggers down, they were amazingly within 5 grams
of each other, so I balanced to one gram. they've been in the car and have about 4000 miles on them......runs great....very peppy & 31mpg.
Jeff _________________ 1962 Beetle
1957 Beetle
1963 Single Cab
1959 Bus
1957 Beetle |
Posted: Wed Jun 01, 2011 6:58 pm Post subject: |
OvalWindowBucket wrote: |
I bought a set of AA 83mm Big Bore p&c from Mr. Motorhead (samba user). I can post pictures of the pistons/skirts soon, but I have not mocked up my motor to see if there are clearance issues. |
Yeah, do so!
The piston blanks used for those Mahle's are unlike anything I've ever seen before or since for 83mm - they are almost lacking skirts. A quick glance should show you what style they are.
I just looked up that ad in theSamba Classifieds . I'm not sure if the photo used is the actual part - those appear to be 77mm in his photo. ( the cylinder has thick cylinder walls, plus the "groove" under the top where it meets the head that there is no room for on the thinner-wall 83mm jugs, plus when I enlarge the photo it looks like 76-something stamped on top of the pistons - also it has the "open" style slots around the cylinder stud holes, something else I've never seen on big-bores before - all indicated in this small snip I took from that listing - below
So... I'd be interested in a photo of what you got - piston AND cylinder.
-Andy
Mr. Motorhead Mad Scientist
Joined: January 06, 2004 Posts: 717 Location: Practitioner of 36hp alchemy
Posted: Wed Jun 01, 2011 8:27 pm Post subject: |
Okay, I changed the picture. The AA pistons are an almost carbon copy of the Mahle 83mm. I said almost. The big difference is the length of the skirt. The AA piston measures at 2 3/4" while the Mahle stands an 1/8" taller. It really does not matter what brand 83mm big bore pistons you buy........I've had clearance issues on some 40hp cases with all brands over the years starting with the Japanese NPRs that I started using in the mid-70s. The advice I always give on these and many other non-stock parts is make sure it all fits and spins clean with at least .040 clearance between parts that could collide.
Piston on the right is AA, on the left is Mahle. Both use the 2mm compression rings. _________________ 30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy |
64vdub Samba Member
Posted: Wed Jun 01, 2011 9:20 pm Post subject: |
Are Mahle's are still made in Germany? I wonder if the AA are of similiar quality...I'm inquiring cause I'll be tackling my first re-build on a spare 40hp I picked up. _________________ 64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
A: I collect money
GO SF GIANTS! |
Posted: Wed Jun 01, 2011 10:46 pm Post subject: |
Nope, not German. I don't know how long it's been since Mahle moved production ot Brazil but I think every new Mahle kit I've ever bought (83, 85.5, 87) in the last 20 years has been from there. |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Thu Jul 07, 2011 7:52 pm Post subject: |
Where do u buy rings for a big bore? To use a 1600 cc crank do u need to clearence the case? _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
64vdub Samba Member
Posted: Sat Jul 09, 2011 8:22 pm Post subject: |
Not sure about the crank, but you'll probably have to shim the cylinders for the increased stroke. _________________ 64' Pearl White beetle, type 113 sedan. Purchased in Hamburg Germany, driven for a year via vw tourist program, shipped to CA in 1965.
A: I collect money
GO SF GIANTS! |
