Tom N. Samba Member
Joined: May 21, 2005 Posts: 781 Location: dReading, PennsylRAINia
Posted: Fri Aug 19, 2005 6:54 pm Post subject: Fire Extinguishers |
What is the reccommended fire extinguisher to carry in a car? Just in case spit happens. I know Bill May and Glenn mentioned this... I want to make sure so I can buy one this weekend.
Thanks. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
thevanillaninja Samba Member
Joined: October 10, 2004 Posts: 704 Location: Scott, IL
Posted: Fri Aug 19, 2005 7:13 pm Post subject: |
but for cheap's sake you can go with a small kiddie abc that's $15-20 at wally world. at the very least you want an extinguisher that does what it's supposed to. messy car parts are easier to clean up than burnt car parts. _________________ 1967 Zenith Blue Type 1 "Elaine"
Bought in 2004
Stored for 4 1/2 years and soon to be resurrected..
'67 beetle |
Glenn Mr. 010
Posted: Fri Aug 19, 2005 7:16 pm Post subject: |
thevanillaninja wrote: |
messy car parts are easier to clean up than burnt car parts. |
Actually the powder used in the ABC fire exstingushiers will bond to the magnesium case and make it almost impossible to fully clean it. It's also corrisive to aluminum.
The Halotron is $85. That's about 3 tanks of gas. _________________ Glenn
Member #1009
#BlueSquare |
xoshiex Samba Member
Joined: July 05, 2005 Posts: 36 Location: Avondale, Az
oicdn Samba Member
Posted: Sat Aug 20, 2005 11:57 am Post subject: |
I've never carried an extinguisher in my car.....but I'm very familiar with fire properties from being a firefighter/submariner in the navy....
Why wouldn't you just wanna use a CO2 extinguisher? Acts as a cooling agent too... _________________ “If they’re an antisocial fag in real life, then they will probably be one on the Internet as well.
Unless it’s an Internet forum.
Then they’re the baddest motherfucker on the entire Internet.”
http://i5.photobucket.com/albums/y160/ThePoliticalThinker/lb.jpg |
fredybear Samba Member
Posted: Sat Aug 20, 2005 12:00 pm Post subject: |
Glenn wrote: |
The Halotron is $85. That's about 3 tanks of gas. |
The 20 dollar powder version from home depot put my flames out about a month ago....
Drove it home and washed the powder off with a hose and than some spray cleaner..
the powder bonding to the mag.....hmmmmm |
steponmebbbboom Samba Member
Posted: Sat Aug 20, 2005 9:33 pm Post subject: |
That is a 2.5 lb extinguisher. |
Posted: Sat Aug 20, 2005 10:04 pm Post subject: |
you would still agree that a regular abc is better than nothing, right?
and my preventative maintence/constant-obssession-with-knowing-how-my-vehicle-is-performaning-and-acting (a little bit of ocd) certainly doesn't hurt. not to diss you or your ideas, in fact I usually really enjoy your posts.. but I like to think my extinguisher is for when other people catch fire, if the case were to ever arrise _________________ 1967 Zenith Blue Type 1 "Elaine"
Bought in 2004
'67 beetle |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Aug 21, 2005 1:37 am Post subject: |
you would still agree that a regular abc is better than nothing, right? |
No. If you're not cool enough to run Halo, you should at least be ready to "go down with the ship." |
KILLERWATT Samba Member
Joined: November 18, 2003 Posts: 3298 Location: Vero Beach
Posted: Sun Aug 21, 2005 8:08 am Post subject: |
Halon extinguishers are used in places with expensive computers and electronics because they won't destroy the equipment. The only thing is they are for B&C combustibles only.. ie flamable liquids and electrical components. These don't take care class A.. ie your horse hair seats, carpet. If your magnesium engine block reaches it's ignition temp it is an oxidizer that gives off white lava when in contact with water, very dangerous. If your engine block goes it will either take a class D powder or almost a whole tank of a fire engine's water. |
