DanJReed Samba Member
Joined: July 30, 2004 Posts: 548 Location: Riverton NJ
Posted: Tue Aug 23, 2005 5:48 pm Post subject: |
My PO had 205 "General Ameriways" in the van.
It rode quite nice, until the sidewalls started to crack. _________________ -Dan
(87 Westy Vanagon, 98 Jetta GLS 2.0, 95 Golf Sport) |
r39o Samba Polizei
Posted: Tue Aug 23, 2005 6:21 pm Post subject: |
Dan,
Which 205?
Common sizes are: 185-14 195-14 205-14 205/70-14 _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
pocvw Samba Member
Posted: Tue Aug 23, 2005 7:03 pm Post subject: |
Dan, that was you that ordered tires...where did u get them mounted? did they charge you alot to mount them? _________________ Life is a garden - dig it!
1980 VW Westfalia |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Tue Aug 23, 2005 7:41 pm Post subject: |
r39o wrote: |
Why the 205s? Will they fit?
I plan on the 195s because I want to reduce my high way RPMs. 4K PRMs at 70 MPH sure is buzzy. |
hey, 195....205...these numbers refer to the width of the tire, and will have no effect on the rpm you turn at a given speed. For that you want a tire with a larger diameter. |
Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Wed Aug 24, 2005 5:01 am Post subject: |
If you get a tire that is wider it will change the diameter and change you speedimeter slightly. It wont make a considerable difference, if any, on your highway rpms. Tires have three numbers for the size. A 195/75/14 means that the tires width is 195 millimeters, the 75 means that the sidewall measurement, from ground up to the rim, is 75% of the width (195) it is called the aspect ratio, and the last number 14 is the rim diameter. The vans take a 185/R/14, the R in the middle, wich is a metric sizing, actually means about 82 aspect ratio. If you get a wider tire you will be changing the diameter of the tire and your speedometer will be off. You can do some mixing up on the numbers. I have LT195/75/14 on my van which is about the same diameter as the stock size. If you wanted even wider than you could go with a 205/70/14 and get pretty close to the same diameter. Now when you start looking into lower profile tires there are even less options for a load range C tire. My tire is actually a light truck tire, very agressive but I dont here any more road noise over the sound of the van. _________________ 82 Westy: Air is cool! |
pocvw Samba Member
Posted: Wed Aug 24, 2005 9:29 pm Post subject: |
Alright, this is what I found out from some places here around town:
Wal-Mart: Special order Michelin Agilis 185R14 - $128/tire (includes mount)
Big O Tire: Special order Michelin Agilis 185R14 - $144/tire (includes mount)
Brian's Tire Factory: Special order Michelin Agilis 185R14 - They supposedly called Michelin and told me that the Agilis tire is discontinued (what??).
Special order Continental Vanco-8 185R14 - $84.74/tire (includes mount)
195R14 - $97.74/tire (includes mount)
Quigley's Tire Towne: Suppose to call me back.
So, based upon this info, I am probably going to get the Vanco-8's (195s, I think). I called these businesses specifically looking for the Agilis and the Vanco-8's. _________________ Life is a garden - dig it!
1980 VW Westfalia |
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Wed Aug 24, 2005 10:28 pm Post subject: |
Another option is the Yokohama Y356 "SuperVan" The 185/14's were about $55 from Tire Rack and I paid about $20 each to have them mounted locally. I like them so far. One thing I noticed about the correct tires is that that steering is much quicker and lighter than with car tires. The Yok's didnt get a good snow revue, but here in beeUtiful east TN we dont get snow. It goes from 33o and raining to 31o and icing. Not much goes on ice. |
cnskate Samba Member
Joined: May 10, 2005 Posts: 295 Location: Bellingham, WA
Posted: Wed Aug 24, 2005 11:09 pm Post subject: |
Discount Tire and Les Schwab will match places like the TireRack's internet price with shipping. I think they are a little bit happier to do that than install tires you ordered elsewhere. _________________ "Wherever you go, there you are." |
pocvw Samba Member
Posted: Wed Oct 19, 2005 5:22 pm Post subject: |
Here is the update on my tire situation. About 10 weeks after placing the order for the Continental Vanco8 (195/R14) tires, they finally came in and I had them mounted today. The difference in the ride is AMAZING!!!! It rides so much more smoothly and more solidly. Truly amazing! I have only put on about 5 miles on the tires and I am sooooo impressed!! I highly recommend them!
I ordered them from Brian's Tire Factory. The cost was a little high (if to do over again, I'd order them from TireRack.com), but really worth it!
Total cost = $538.91
I was expecting around $400-$450, but I guess I didn't figure in the $80 in freight. Anyone know, off hand, how much freight is through TireRack?
Oh, and FYI, the tires were made in the Czech Republic (printed on the tire). But they are still German engineered! _________________ Life is a garden - dig it!
1980 VW Westfalia |
BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Wed Oct 19, 2005 8:02 pm Post subject: |
Confession; I thought you guys were being tire snobs, "You need LT tires, or 8 ply monster side wall tires". I bought a parts Westy a few weeks ago, it had Light Truck tires on it. I swapped them onto my Westy. I kick myself for buying cheap tires. These Vans were made to roll on some real rubber. I promise anybody tire shopping, you will not regret getting some stiff tires that fit the van. |
Fox Samba Member
Joined: September 25, 2005 Posts: 60 Location: Dark side of the moon
Posted: Thu Oct 20, 2005 7:43 am Post subject: |
All good! After much research I am going with the Michelin LTX 195/75R/14. They rate out the best when all things are considered. AND Costco has them for an out the door price of $420, (with current $60 off a set of four) gotta like that! Discount tire said they would beat Costco's price by $20 but for the extra twent I'd rather be able to hang out in Costco each time I want my tires balanced and rotated as opposed to any tire shop I've ever been in.
Cheers, |
RCB Samba Member
Joined: September 05, 2005 Posts: 4143 Location: San Francisco-Bay Area
Posted: Thu Oct 20, 2005 5:28 pm Post subject: Tires |
Greetings, `Ive been told that the Michelin Agellis tires have been discontinued, BUT they sold the mold rights to a company that will bring them back as a "classic tire". All that means is more money.
I wanted to purchase the Continental Vanco 8's for my Westy, but I wasent going to pay $90.00 for shipping .Theyve been on back order in Reno for months and months and months.
I finally settled on the Yokohamas Y356LT in the 185/75/R14,D load rating. I bought five of them from BigO and they matched Tire Racks price AND it works out about the same. If I bought from Tire Rack and had them shipped to a
BigO store they would charge $25.00 per tire to mount and balance. Buying through BigO ( 90 days same as cash) they mount and balance and give ya tire stems as part of the price.
Im having HD Bilsteins shocks installed at the same time.Nice deal at Bus Depot.
Im interested in hearing from those riding on the Yokohamas as to what tire pressure you are running..... Do you have the same pressure all around or do you run the rears a bit higher??
As a side note to anyone planning on a tire purchase, please keep in mind that a Westy comes in at 6000 lbs and it takes a special kind of tire to handle the weight and tire distribution of such a heavy vehicle, so keep you and your families safety in mind when choosing your tires.
Happy and safe trails to all,
Robert |
stumpie Samba Member
Joined: April 03, 2005 Posts: 87 Location: carlisle, pa.
Posted: Thu Oct 20, 2005 6:10 pm Post subject: tires |
I am about to order new tires, but am notsure of the size. I don't want that skinny look. Know what I mean?? I'am am running 205's now, but they look like dougnuts,but ride nice. Walmart gave me a price of 117.00 per. I know you can get them cheaper. When I do make the plung I will let WMart mount them, there price is hard to beat. What sizes are you guys running?? |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Thu Oct 20, 2005 6:49 pm Post subject: Re: Tires |
RCB wrote: |
I finally settled on the Yokohamas Y356LT in the 185/75/R14,D load rating. |
Are you sure about this size??
The correct size is 185R14 with NO middle aspect number.
185/75R14 is a smaller tire.......
The comparable size to the correct 185R14 is 195/75R14. |
levi Samba Member
Posted: Thu Oct 20, 2005 9:41 pm Post subject: |
just ordered today the continental vanco 8...went to discount and they gave me a high price but when I showed them that tire rack was selling them for 56 bucks they agreed to match the price, and 10 $ each to mount them...
The set comes in at 309 $ incl tax etc.......
Good rating on these tires. D instead of C rating, to 1874 pounds...
The tires on my 85 were put on aug 1996. 9 years! and they honestly look like they could go at least another year or more. Just a little over 70,000 miles on them..they are michelin LTX 195/75 m+s....they've been great but are only rated to 1435#..... |
Rick73Super Samba Member
Joined: June 30, 2004 Posts: 1792 Location: Ocala FL 34481
Posted: Fri Oct 21, 2005 10:39 am Post subject: |
I just purchased Michelin Agilis 215-65 15 less than a month ago, local shop had to order them, took about a week. Great investment. |
r39o Samba Polizei
Posted: Fri Oct 21, 2005 1:54 pm Post subject: |
levi,
Why didn't you go for the 195's? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
RCB Samba Member
Posted: Fri Oct 21, 2005 2:43 pm Post subject: Tires |
Greetings Carl, Your right, thankx for the correction. I wouldnt want to stear anyone in the wrong direction especially for such an important item as a tire.
I appreciate you reading my posting and replying in a timely manner.
Happy and safe weekend to all,
Robert |
vandukw Samba Member
Posted: Fri Nov 24, 2006 3:57 pm Post subject: anyone have uniroyal laredo tires? |
had new uniroyal laredo when I bought it, 6 ply, anyone think I would see improvement if I switch to vanco's ? |
vw_nick Samba Member
Joined: August 21, 2005 Posts: 391 Location: Nashville, TN
Posted: Fri Nov 24, 2006 7:57 pm Post subject: |
as I know it.. sipes are for traction on ice
I worked at a volvo shop up north and we only sold nokia(n) tires... one year they came out with the "Q" with the sipes as an ice tire. If you listened carefully, it sounded like a little deck of cards shuffling as you drove. _________________ Nick |
