Colorado_Baja Samba Member
Joined: August 24, 2005 Posts: 54 Location: The Forest, CO
Posted: Fri Aug 26, 2005 12:58 pm Post subject: |
Ive decided to go with that JD flat OD green.
So what is this plug thing? Its neer the front drivers wheel.
The body lift is three inches. How do I figure out if their is a suspension lift?
And what is this thing? should their be one on the other side?
What about this bottle? the lines just hang down below the gas tank..
What are these lines for one seems to be plugged..
TIA to anyone who can shed some light.
Greg |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Fri Aug 26, 2005 1:26 pm Post subject: |
1st pic - Plug Thing - appears to be brake light switch
3rd pic - tube piece from rear bumper/cage assembly
4th pic - brake fluid reservoir
Not certain on other pics - don't have car available to look at...
didget69 |
baja5 Samba Member
Joined: February 28, 2004 Posts: 4326 Location: Ramona,Ca.
Posted: Fri Aug 26, 2005 1:28 pm Post subject: |
That 2 prong switch looks like your brake light switch. the bottle is your brake fluid resivior, that bar looks like a remnant of where a rear engine cage was and that tube by the hood hinge is for your windshield defroster. although i don't know why it has that small port on it. |
baja5 Samba Member
Posted: Fri Aug 26, 2005 1:32 pm Post subject: |
I almost forgot, the suspension looks fairly stock to me.i believe that if the front end was lifted you can see weld marks in the center of the beam where it was cut and turned. the rear could have been adjusted by turning the spring plates but with the engine out Vw's tend to sit pretty high so it's probably stock. |
-Frosty- Samba Member
Joined: July 19, 2005 Posts: 115 Location: Bothell, WA
Colorado_Baja wrote: |
That's the brake light switch on the master cylinder
Usually you can tell if the spring plates in the rear are much closer to the bottom stops than the top (with the engine installed), and if the front bump stops have been removed. Also if the front beam has been cut and turned or torsion adjusters added.
That's a rear bumper mount, either for a cage or double tube bumper. There should be one on each side to install the bumper, if you choose to go that route.
That's the master brake cylinder reservior. Those hoses should be connected to the top of the master cylinder.
Not quite sure, but it looks like it's for auxillary heat, such as a gas heater. What year is it? Maybe they are supposed to go to the center defrost (mine doesn't have one, it's too old, so not familiar with it). _________________ 1964 Baja, never finished |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Fri Aug 26, 2005 1:43 pm Post subject: |
Its a 66,67 or 68. Swing axle with balljoint. Just noticed 4 lug. I'll say late 67-68. _________________ The honey-do list put my project on hold....... |
HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Fri Aug 26, 2005 1:53 pm Post subject: |
68. you can see the gas filler door welded shut in the last pictures _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
Stout Samba Member
Joined: June 08, 2004 Posts: 17 Location: Spokane, WA
Posted: Fri Aug 26, 2005 3:49 pm Post subject: |
In that last picture with the smaller plugged vent hose is on later model cars.
There are "defrost" vents in the middle made of plastic in addition to the ones on the outside edges. There would have been some plastic hoses that ran from that plugged spot to the middle vents.
-Mike |
runslikeapenguin Samba Member
Joined: August 07, 2005 Posts: 4674 Location: Federal way WA
Posted: Fri Aug 26, 2005 4:06 pm Post subject: |
hey where do you get the john deer paint?
and how hard is it to put on a body lift? |
Nicksan Samba Member
Posted: Fri Aug 26, 2005 5:26 pm Post subject: |
runslikeapenguin wrote: |
Body lift is not hard, simply unbolt the body, jack it up and slide the pieces into place and then lower it down and bolt it up. If you have a few floor jacks and several peices of 2x4`s it makes it really easy. What sucks though is that its hard to find a quality body lift kit. |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Fri Aug 26, 2005 5:39 pm Post subject: |
there also should be brake fluid in it.........
after you hook up the hoses of course. _________________ blank |
Posted: Fri Aug 26, 2005 5:42 pm Post subject: |
Thanks for the replys guys. Im going to pick up a repair manual this weekend witch should answer most of my random questions.
As for the year its a 66' thats whats on the title that I got at least.
Inside the car I found some extra bolts and two of those spacers, like the one I pointed out in the pic above. Is their any way to tell who manufactured the body lift? I looked on all the stuff I could see and dident see any markings. Im just wondering where those extra bolts and spacers go. Could anyone post a link that sells similar body lift kits? im sure they all install the same.
How meny gallons does the stock gas tank hold?
Greg |
Posted: Fri Aug 26, 2005 5:47 pm Post subject: |
Body lift is not hard, simply unbolt the body, jack it up and slide the pieces into place and then lower it down and bolt it up. If you have a few floor jacks and several peices of 2x4`s it makes it really easy. What sucks though is that its hard to find a quality body lift kit.[/quote]
what about the tunnel? dont you have to do something with that? |
Greg[/quote]
10 i think |
Posted: Fri Aug 26, 2005 6:03 pm Post subject: |
Remove the backseat of the car. Under it on the pan there will be a vin #. Check that vin (and the one on your title)against the samba's vin number decoder. 66 should have 5 lug wheels. Maybe someone replaced the drums, brakes, wheels etc with later models. There is also a chance that someone replaced the quarter with a later one with the fuel door in the front quarter. I would suspect however that the year on your title is a mistake.
Its not a big deal, but when you go to get parts they wont be right. I also think that the dual reservoir master cyclinder (two hoses) was later than 66 also. _________________ The honey-do list put my project on hold....... |
Posted: Fri Aug 26, 2005 6:10 pm Post subject: |
Jowlz wrote: |
Its not a big deal, but when you go to get parts they wont be right. I also think that the dual reservoir master cyclinder (two hoses) was later than 66 also. |
WOW good info thanks Jowlz ill be sure to check the vin on my tub when I get off work. Should be easy as the whole interior is stripped.
Greg |
Posted: Fri Aug 26, 2005 6:11 pm Post subject: |
what about the tunnel? dont you have to do something with that?[/quote]
Oh crap, I forgot to mention Your stock seats will not fit anymore and you have to cut a oval shape hole into the firewall and move the steering shaft slightly. I am using a urethaen donut so the angle was ok. I had no problems with the tunnel. The kit I used had all the pieces you need to support the whole body. |
Posted: Fri Aug 26, 2005 7:00 pm Post subject: |
[quote="Nicksan Oh crap, I forgot to mention Your stock seats will not fit anymore and you have to cut a oval shape hole into the firewall and move the steering shaft slightly..[/quote]
The front seats or the back?
I plan on running aftermarket buckets so its probly not a big deal.
Greg |
Posted: Fri Aug 26, 2005 7:13 pm Post subject: |
any pictures of the 3 inch body lift? |
Posted: Fri Aug 26, 2005 7:52 pm Post subject: |
Front seats, They hit the heater channels before they can get to the sliders. I dont know about the back because Ive never had a back seat.
