My57Oval Samba Member
Posted: Mon Aug 29, 2005 1:44 pm Post subject: Proper grease type for king/link pins etc. . . > |
And all the other chassis grease fittings. What today is similar to what was used back then? Or does anyone have a shop manual that specifies what to use, or an owners manual? Thanks ! |
'55oval Samba Member
Posted: Mon Aug 29, 2005 8:02 pm Post subject: |
rakeyworth,
Unless I missed something along the way, grease is grease. I don't think it much matters what you use to grease the K/L pins, etc. synthetic or regular. What is your concern???
Steve |
Posted: Sat Apr 02, 2016 6:10 pm Post subject: Re: Proper grease type for king/link pins etc. . . > |
My concern is that it has now been over 10 years and I still don't have a good answer. |
EVfun Samba Member
Posted: Sat Apr 02, 2016 8:33 pm Post subject: Re: Proper grease type for king/link pins etc. . . > |
Well, if you haven't greased the car in 10 years it won't make any difference now. _________________
Wildthings wrote: |
Posted: Sat Apr 02, 2016 8:49 pm Post subject: Re: Proper grease type for king/link pins etc. . . > |
I know! Damn it! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Apr 03, 2016 6:20 am Post subject: Re: Proper grease type for king/link pins etc. . . > |
I've always just used Castrol multipurpose wheel bearing and chassis grease.
_________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
splitjunkie Samba Member
Posted: Sun Apr 03, 2016 8:36 am Post subject: Re: Proper grease type for king/link pins etc. . . > |
Joey wrote: |
this is what you want or any similar multipurpose grease.
Do not go with Molybdenum based grease as it is incompatable with lithium based grease. The Moly based grease is easy to spot because it is black where as Lithium based multipuropse grease is greenish, blueish or yellowish.
If you grease it and dark black grease comes out of the seals them someone used Moly based grease at some point. _________________ Chris
