barnjunkie Samba Member
Posted: Thu Sep 01, 2005 12:39 pm Post subject: how good is a judson in a barndoor ? |
Hi all
I would like to know from fellow bd drivers with original 30/36hp
engines, How slow are they ?
and if you've driven a barndoor with a judson how did this compare to a
stock engine ?
Top speeds with judson ?
cheers
_________________ Luca Brasi's got nothing on me
54 rhd Judson super narrowed
BDM Wannabe |
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6956 Location: San Diego, California, USA
Posted: Thu Sep 01, 2005 12:54 pm Post subject: Re: how good is a judson in a barndoor ? |
barnjunkie wrote: |
Hi all
stock engine ?
cheers
I can tell you that a stock Barndoor is slow. Mine hits about 50 to maybe 55 mph on the freeway with reduction gears and bias plies.
I haven't driven a Judson-ized Bus though so I can't tell you about the difference. My guess is that it might hit something like a 1500-1600 single port type performance, certainly not fast but a little bit more sack. _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
EverettB Administrator
Joined: April 11, 2000 Posts: 69813 Location: Phoenix Metro
busracer Samba Member
Posted: Thu Sep 01, 2005 1:57 pm Post subject: |
judsons run hot. all that friction.
why dont you fork out 6500 for one of mr okrasas no okrasa parts whirlwind 36 horse SHORT blocks and smoke some 1835s! |
Posted: Thu Sep 01, 2005 2:08 pm Post subject: |
busracer wrote: |
Rob- Get it right, man, it's a "HURRICANE" like the rum-filled Louisianna beverages that you'd have to be drinking till you couldn't think straight when you handed the cash over to him for it. _________________ Please check us out on Instagram at @holygrailgarage
camerod Volksfab
Joined: October 01, 2002 Posts: 606 Location: washington state
Posted: Thu Sep 01, 2005 6:58 pm Post subject: |
my okrasa powered kombi(1300 tsv) still had less power than a 1600 single port bus...maybe not less RPM HP but for sure less torque which is what you really need in a bus anyway! _________________ DON'T SHIT WHERE YOU EAT! |
Posted: Fri Sep 02, 2005 2:50 am Post subject: |
Thanks guys but I fogot to mention
the bus will not have reduction boxes/gears
it will be a 36hp beetle box will this make it worse ??
Cheers
Barnjunkie _________________ Luca Brasi's got nothing on me
BDM Wannabe |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Fri Sep 02, 2005 4:59 am Post subject: |
I'd forget about top speed with a Judson...it's the first thing people ask and really it's the least important.
The things you really need to know is that it give a really useful boost in torque meaning you don't slow to a crawl on anything but the steepest of hills.
Issues that exist with later splitties like cutting the engine bay ceiling to fit the air cleaner doesn't affect a Barndoor...lots of room.
As for running hot, well they run hotter but not enough to get the green light flickering. Ducting air from the vents onto the blower casing will keep things cool. If you have a good Judson you're not going to be bothered with overheating.
If Judsons cremate engines like some people think, they wouldn't have shifted over 70,000 units in their day.
Ask Julian Hunt if he misses his Judson on his '52 panel? _________________ John.
Posted: Fri Sep 02, 2005 7:57 am Post subject: |
Hi John
the top speed will tell me how much the bus will gain
I know about what a judson charger will do on a bug
If I'm traveling long distances and cruising at 50mph without a charger
Its a little too slow for my liking only because I think its unsafe on
modern roads
but if I cruise at 60/65mph then thats exceptable
so if in a bug top speed was 80 something mph and I was traveling
at 65/70mph I know there is more power left
I just need to know what extra I would get in a bus
cheers for the input more please
Trevor _________________ Luca Brasi's got nothing on me
BDM Wannabe |
EvilBus Samba Art Critic
Joined: June 18, 2004 Posts: 1523 Location: Texas Damnit!
Posted: Fri Sep 02, 2005 9:29 am Post subject: |
I can comment on this, since I have one. The gearing in mine is stock and so unless you want to wind it out (Which I don't) you're still 55MPH tops. Since putting mine on
there's faster acceleration and the sound is definitely sweet to listen too. I was going up and down the hills in Eureka Springs last weekend with no problems.
I've had the inside of the housing honed and ceramic coated and polished. The outside was powdercoated. The only problem I had was clearance for the original style crank style rear pulley nut.
_________________ - JHC de Tejas - |
Posted: Fri Sep 02, 2005 9:38 am Post subject: |
barnjunkie wrote: |
Cheers
Barnjunkie |
Well I don't think you'll be happy with the 36 in any case with that scenario. You're pushing a lot of weight and air. You may want to opt for at least a 1600.. _________________ - JHC de Tejas - |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Fri Sep 02, 2005 9:46 am Post subject: |
I just want to know why the license light wire is blue? _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
Ragman The Sambinator
Posted: Fri Sep 02, 2005 10:04 am Post subject: |
As you all probalby know, the top speed would still be quite limited to the tranny. If you really want to increase your top end speed, you'll need to address the tranny as well as the engine. |
Posted: Fri Sep 02, 2005 10:24 am Post subject: |
DaveM wrote: |
I just want to know why the license light wire is blue? |
Paint F*up .. It's getting handled this weekend.. One thing at a time. I'm trying to obtain a whole new harness for it. Most places want me to gut the bus first, send it to them then get the harness back.. _________________ - JHC de Tejas - |
Posted: Fri Sep 02, 2005 3:34 pm Post subject: |
John Moxon wrote: |
The sight brings tears to my eyes "EvilBus" |
don't worry it wont happen Judson all the way for me John
Has noboby taken off the reduction gears on a barndoor
without going for a larger g/box ?
BDM Wannabe
Posted: Fri Sep 02, 2005 3:42 pm Post subject: |
EvilBus wrote: |
Would the reduction gears stop you from meeting the obtainable top
speed ?
without the reduction gears you would get better top speed but be straining the engine on the hills wouldn't you ?? _________________ Luca Brasi's got nothing on me
BDM Wannabe |
Posted: Fri Sep 02, 2005 4:08 pm Post subject: |
Well, that post didn't work. I'll try again.
There's lots of barndoors with straight axle setups and even some with later style reduction gears. To get to your original question, I think that a straight axle with a 36HP judson may work but I think it may be labored a bit. You may want to think of a larger power plant or if you want to still run a Judson there's a bit of work in setting up a 40HP judson on a 1600.
The later reduction boxes allow busses to go quite well in the 60-70MPH. _________________ - JHC de Tejas - |
