Edgar64 Samba Member
Joined: September 04, 2008 Posts: 48 Location: Vancouver, Canada
Posted: Thu Jul 05, 2012 12:07 pm Post subject: |
Good point about the revs. and getting pushed around. I'll go back to the shop and see what else they suggest.
Thanks, |
Don66bus Samba Member
Posted: Tue Aug 07, 2012 2:18 pm Post subject: Buying 15 inch tires |
I have a 66 Deluxe that I use for daily driving spring, summer, and fall here in Canada. I load it up sometimes. I have driven it across the country several times.
I have been running Toyo Spectrum 205/70-15 tires for the last 25,000 miles and they are approaching the wear bars on the front tires. Time for new tires. I have read all the conversation on this thread and most of the "large meat" thread, and there is a diversity of opinions. My choices locally seem to be:
1) A good passenger car tire (good for 1500+ pounds) such as a Nokian eNTYRE or Cooper CS4, available here for about $500 for 4 mounted and balanced.
2) An 8-ply tire for about twice that
3) Doing it the American way from a retailer like Tire Rack, drop shipping to a US border town, and then dealing with transportation, customs, and local installation.
I am leaning toward a 205/75-15 because that tire diameter is closest to the stock 7.00 - 14 that came on the bus. Considerably wider though. I wouldn't mind dropping the revs 3 or 4% over the 205/70-15 tires on now. Based on the experience of others on the Samba, the 75 series tires should not cause a problem with clearances.
The cost is not the prime issue. These tires will likely outlast my use of the bus, given my current annual mileage. However, if I am going to pay much more for light truck tires, I would like it to be for a discernible advantage.
Some of you have made these choices recently. Any advice? |
Posted: Tue Sep 25, 2012 10:22 am Post subject: 205/75 - 15 tires |
In the end I bought 205/75 - 15 Cooper Discoverers. I could not get my local distributors to find me a 6 ply tire without additional shipping costs added to their already high prices. I like the Coopers. They ride quietly and have a more aggressive tread than the Toyos I had on previously. I am getting some scraping when I turn hard right in parking lots on the right front, but never on the left, curiously. I have not tried them out yet with a good load on.
Given this experience, I would probably buy 205/70 - 15 for the front. or maybe for both front and back, if I were to do it again. |
DavidKvapil Samba Member
Posted: Tue Sep 25, 2012 10:47 am Post subject: |
You shouldn't have any issues with a 205/75-15. I would check all the leaves in your beam for any broken ones and replace them. You should be able to fit at least a 215/75-15 on it and not rub, as that's what I'm running on my '62, and I have never even come close to rubbing on some pretty intense dirt roads. _________________ '62 Turkis Kombi FOR SALE. Please see my ad. |
Posted: Tue Sep 25, 2012 10:53 am Post subject: Tire contact |
The tire doesn't contact the sheet metal above (which would be spring-related) but touches the back of the fender well on the edge of the turned tire. A previous owner had done some welding on the cross member there years ago. It may be that it is pushed forward from its stock position by 1/4" and that is the reason for the sporadic contact. |
Posted: Tue Sep 25, 2012 12:23 pm Post subject: |
Yeah, that is the typical point of contact for larger tires. I would still check out the leaves in your beam. I have put tires as large as 7.00-15 on all four corners of my stock height bus and was able to drive it around moderately without any rubbing, and that's a 29.8" tire. With 205/75's you should have at least an inch and a half of clearance at rest with the wheel turned in any direction. _________________ '62 Turkis Kombi FOR SALE. Please see my ad. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue Oct 30, 2012 12:50 pm Post subject: |
Anyone buy 205/75/15s or 195R15s recently?
I was going to order some Cooper Discoverers in 205/75/15 but it looks like they don't make a Load Range C tire anymore.
The ones available are Cooper Discoverer HT.
Load range is "97S" which appears to be less than C and is a passenger car rating, not a light truck (LT) rating? _________________ How to Post Photos
erlawson Samba Member
Posted: Tue Oct 30, 2012 1:21 pm Post subject: |
Tire Easy has several 195R15 still listed that are load range D (this is what I have on my bus), but nothing with the aggressive tread of the Cooper.
Eddie _________________ 57 ragtop bug, 59 Country Buggy repop., 61 ranch buggy/bus, 62 baja, 63 dune buggy/baja, '66 dune buggy, '66 & '67 fastbacks, 70 "Mule", 73 Thing, 09 dune/street buggy
TOOB Member #13
BSQUARE wrote: |
...When bugs mature, they become type 3s. |
Ghostwagens |
tev Samba Member
Posted: Tue Oct 30, 2012 2:01 pm Post subject: |
Everett,
I bought the Nexen SV820s for my 60 westy a few months ago and I'm pretty happy with them. I was looking for something similar to my old Cooper Discoverer 195/75R15 (load range C) and this is actually pretty close. If you compare the Discoverer tread to the Nexen, you can see a very basic similarity in the pattern. I kinda think Nexen ripped off the Coopers. I'm very happy with em so far. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Wed Oct 31, 2012 6:25 am Post subject: |
I ran a set of the Cooper Trendsetters (205-75-15/ 1598lbs rating) on my 61 when I had it. A prety nice tire, but IMO it really didnt have the side wall support that I wanted. At freeeway speed and in heavy cross winds you could feel the sidewalls flexing it seems to me. The SV820s are the tire Iam looking at for my next set, I have seen them on a early SC and they didnt seem to have any clearnce issues and the owner raved about them.(HA HA went back and read thru this thread, I gave sorta the same review back in 2005) |
Stocknazi Samba Member
Posted: Wed Oct 31, 2012 10:36 am Post subject: |
DavidKvapil wrote: |
You shouldn't have any issues with a 205/75-15. I would check all the leaves in your beam for any broken ones and replace them. You should be able to fit at least a 215/75-15 on it and not rub, as that's what I'm running on my '62, and I have never even come close to rubbing on some pretty intense dirt roads. |
did those 215/75 15's have any clearence issues in the rear. you do have the earlier wheelwells front and back right? _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Tue Nov 06, 2012 9:31 am Post subject: |
EverettB wrote: |
I am looking at those Nexen's too, they look good and I do like the idea of a straight 195R15. |
I have ordered a set of Nexens. They have not arrived yet but I wanted to post an update in case anyone is in the market right now.
I found a cheaper source than http://www.tires-easy.com/
I went on the Nexen Tire site at http://www.nexentireusa.com/ and looked up a local Nexen Tire Dealer. They were able to order the SV820s for me straight to their store. Same price as online. The downside is that it could take up to 2 weeks. Upside is I do not have to pay any shipping ($60 for a set of 4 to AZ) by ordering them online. I will have to pay tax but tires-easy.com was charging tax too, at least to AZ as that is the law because they have a physical distribution warehouse here... which doesn't allow pick ups, I asked. _________________ How to Post Photos
jpstine Samba Member
Posted: Tue Nov 06, 2012 12:23 pm Post subject: |
EverettB wrote: |
EverettB wrote: |
I went on the Nexen Tire site at http://www.nexentireusa.com/ and looked up a local Nexen Tire Dealer. They were able to order the SV820s for me straight to their store. Same price as online. The downside is that it could take up to 2 weeks. Upside is I do not have to pay any shipping ($60 for a set of 4 to AZ) by ordering them online. I will have to pay tax but tires-easy.com was charging tax too, at least to AZ as that is the law because they have a physical distribution warehouse here... which doesn't allow pick ups, I asked. |
I have been working a source here in Tucson. There price is a little higher than online. would you PM me the name of the place your getting yours. I'M VERY INTERESTED on how these tires are gong to work for you.
Regards _________________ “Sometimes you have to be really high to see how small you really are, I’m going home now.” Epic Felix Baumgartner quote.
1960 SO-23 Westy
1974 Ghia Vert
1970 Ghia Hardtop
1962 FC150 Willys
1950 GR22 Massy Harris
1945 VAC Case |
islandveedub Samba Member
Joined: March 10, 2003 Posts: 157 Location: Honolulu, Hawaii
Posted: Sat Nov 17, 2012 5:54 pm Post subject: |
I have a 60 doublecab with a big nut trans and Cooper Discoverer 205/75/15 tires on stock 15" wheels. I have a problem getting the tire off the rear and ended up dropping the axle off the spring plate to get it off. Even letting the air out of the tires didn't help. Is it the combination of earlier bus with big nut trans that give this problem, or is this common with all 205 tires even on a small nut trans?
I would really like to have a tire that I could take off and put back on without the extra hassle. I can't imagine getting a flat and having to drop the axle on the side of the road. Anyone have a good tire recommendation, or should I look for a small nut trans? Switch to bias ply? _________________ Alex
60 Doublecab
62 23 Window Walkthrough Bus |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sat Nov 17, 2012 8:22 pm Post subject: |
islandveedub wrote: |
I would really like to have a tire that I could take off and put back on without the extra hassle. I can't imagine getting a flat and having to drop the axle on the side of the road. Anyone have a good tire recommendation, or should I look for a small nut trans? Switch to bias ply? |
With that tire width, the bigger brake drums that come with a big nut tranny, and the more compact wheel wells of an early bus all conspire to make tire R&R difficult. Skinnier tires would help, but they are a little tough to find in an aggressive tread like the Discoverer.
That said, I had 195R15 Discoverers on my 57 standard with a big nut trans and did not have any issues. These tires are slightly narrower than your 205's, but sadly are no longer available. _________________ nothing |
Posted: Sun Nov 18, 2012 12:52 am Post subject: |
Thanks for confirming that cdennisg and Everett. I was searching all over the site and couldn't find anything on it, although I know there must be a bunch of people faced with the same problem.
I was a little concerned about buying a new set of tires because it might not fit, but I'm glad to hear that 195R15's should do the trick. I'll search for a set with the proper load range and post up here whether or not I'm successful. _________________ Alex
60 Doublecab
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Sun Nov 18, 2012 5:39 am Post subject: |
EverettB wrote: |
EverettB wrote: |
I posted those in the big meats thread about a year ago when I bought a set. I was really happy with them but sold the bus shortly thereafter. I will be putting another set on the new bus. They were about $630 CDN shipped to my door, which I thought was great. |
VWcollector1 Samba Member
Posted: Mon Nov 26, 2012 4:03 pm Post subject: run whitewall tires on crew cab lowered 3 inches |
Hi, I'm lowering my '61 crewcab 3 inches. I want to use original whitewall tires and not inserts. The selection that's out there isn't too extensive, but have been doing my research.
I was told by a friend who is in the business of modifying spring plates and drop spindles that 195/60R15 are probably the biggest tire I can put in my 3" lowered bus without rubbing.
I've read this thread, and it sounds like what I want in aesthetics I'll have to sacrifice in stability. I plan to pretty much just use to drive around town and to local shows only and not any long distance driving.
I'm running a bug swing axle in the rear and a 4" narrowed beam in the front. I know I may need to run a spacer in the front.
I was thinking of 195/65 R15's in the rear and 185/60 R15's in the front. Any comments or thoughts would be appreciative. |
