andre b Samba Member
Joined: August 10, 2004 Posts: 806 Location: San Jose C.A.
Posted: Mon Jun 12, 2017 5:21 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
dgsaz wrote: |
andre b wrote: |
dgsaz wrote: |
dgsaz wrote: |
dgsaz wrote: |
Does anyone know of a current source for Nexen SV820 / 195 - 15? |
I spoke with a distributor for Nexen today and he said they had been discontinued.
He said there might be some random tires here and there, Easter Egg hunt.
This tire has my interest now: https://simpletire.com/catalog/product/104833
Anyone with any experience with these? |
Well, I pulled the trigger on a set of Rangers.
Upon further investigation of the tire specs, the manufacturer's published height was 27.2" which put them at the same height as the Nexen SV820. 8 ply load range D.
The stout sidewalls from the 8 ply provides good lateral stability. Which is important when being passed by large trucks or nasty side winds.
dgsaz |
nice..where did you get em from? |
Simple Tire.com https://simpletire.com/catalog/product/104833 |
so i got those tires i order,and it turns out they sent 195/14s.i was actually not pissed,,becouse i was gonna return em any ways!!!lol..so now im gonna get the Rangers,they look good so far, |
srfndoc Samba Member
Posted: Wed Jun 14, 2017 7:52 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Pricey, a bit short and the load range is still a bit under whats recommended (but not by much). I have not heard much good about Coker's bias ply's, not sure about these. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Jun 14, 2017 2:10 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
srfndoc wrote: |
Pricey, a bit short and the load range is still a bit under whats recommended (but not by much). I have not heard much good about Coker's bias ply's, not sure about these. |
i do like the look of the wide oval redlines
https://www.cokertire.com/tires/styles/bias-look-radials/firestone-wide-oval-radial-redlines.html
they are high, but they do look the part. GR70-15 or FR70-15, the bigger ones are 27.7 inch diameter.
but they are high.... _________________ regards
Uli
RUSS914 Samba Member
Joined: May 31, 2013 Posts: 88 Location: West Columbia
Posted: Thu Jun 15, 2017 8:31 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Ordered some Thunderer Ranger R101, 185/R-14 tires today for my 59 truck. I will let ya know how they do.
Thanks,
Russell |
Posted: Thu Jun 15, 2017 8:44 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
RUSS914 wrote: |
Thanks,
Russell |
Russell, your 59 would have had 15 inch wheels. The outer tire diameter would be bigger than a 185/14. _________________ regards
Uli
Posted: Thu Jun 15, 2017 9:27 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Hey there,
The site references the tire diameter at 26". Plus the previous owner put 14" wheels on the truck.
This tire should be taller than the 185-70-14 currently on the truck, right? |
Posted: Thu Jun 15, 2017 2:03 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Russell,
yes, a 185/14 is usually a little taller than a 185/75/14.
however, an original 15 inch bias ply would have been about 27 inches tall.
if your truck is lowered (no RGBs) and straight axle, then smaller tire diameter is okay.
one inch in diameter is a significant difference. _________________ regards
Uli
Posted: Thu Jun 15, 2017 2:06 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
mandraks wrote: |
Russell,
one inch in diameter is a significant difference. |
Uli,
Thank you for the confirmation! I really appreciate the input from this forum.
And yup..no RGBs
Kind regards,
Russell |
Posted: Thu Jun 15, 2017 2:22 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Fri Jun 16, 2017 3:45 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I just put a set of 4 - 195/70/15C Hercules CV Power Tires up for sale in Tires and Wheels.
Less than 3000 miles.
Load Rate: 104/106
Speed Rate: 106
Ply Rate: 8
Load Capacity: 2094
Max Pressure: 65 lbs.
Tire Height: 25.8"
Look for the add in Tires and Wheel.
Posted: Mon Jun 26, 2017 12:58 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
So,,i got a set of the Achilles 195?80LT these tires look great...i also found a 670 15 LT..For another project,..both sets look great so far.
Posted: Mon Jun 26, 2017 1:02 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Nice. I bought one of the Power King 6.70x15's to use as a spare as it fits in the walkthru spare tire well. The Achilles are a great choice as well, almost went with them before going with the Thunderer's. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Mon Jun 26, 2017 1:04 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Here is a picture of the truck with it's new tires.
Kumo 185/70/14 up front
Thunderer Ranger R101 185/R-14C in the rear
Thanks for help with sizing!!
Russ |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Mon Jun 26, 2017 4:58 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Here is the Power King 670x15 mounted on my spare:
Posted: Mon Jun 26, 2017 5:01 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
heres the 195/80
haven't mounted the 670s.yet,,i think both tires are really nice..
Posted: Mon Jun 26, 2017 5:02 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
srfndoc wrote: |
those look great..have you put it on the bus yet to see ho it looks? |
