kenbug67 Samba Member
Posted: Sat Jun 29, 2019 9:22 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Thanks!!! I was thinking that would be the best compromise without sacrificing the look too much!!
Will prob get the Michelin Agillis 195/70R15 , love michelin tires.....but these look a little more chunky.
or the japanese made Falken R51 Linam 195/70R15..nicesst looking. Passenger] tire look. |
b-man Samba Member
Posted: Sat Jun 29, 2019 12:22 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Here’s a set of 195/70-15 Hercules light truck tires on my ‘56 so you can gauge how that size tire might look on your bus.
_________________ 1956 Dove Blue Panel
1966 Velvet Green Single Cab
1957 L41 Black Oval Window Beetle |
repeteVW Samba Member
Joined: March 23, 2010 Posts: 34 Location: Alpharetta, GA
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Wed Oct 16, 2019 9:45 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
6.70/15s were and are used. However, they can sometimes rub on the fronts. In the back of the wheelwell, there is a metal seam that can get in the way. Hammer can easily fix that.
I used to drive on 6.40/15s and found them plenty tall enough, and never had issues with the weight
for the "faster drivers" the radial probably a good choice even at the higher price _________________ regards
Uli
Posted: Thu Oct 17, 2019 6:22 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Thanks, Uli. Still pondering here. Lawrenceville, I see. Cool!
I'm also curious if anyone can report on any direct experience with the American Classic bias-ply look radial, as linked above. |
srfndoc Samba Member
Posted: Thu Oct 17, 2019 7:57 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I still think the load rating on the Coker bias plys is unsafe. I’m sure it would be fine for a show car but if you drive to distant shows or have a heavier load I would not want to use them. They do look great. _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Lind Samba Member
Joined: November 06, 2000 Posts: 9913 Location: idaho
Posted: Thu Oct 17, 2019 8:32 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
srfndoc wrote: |
I still think the load rating on the Coker bias plys is unsafe. I’m sure it would be fine for a show car but if you drive to distant shows or have a heavier load I would not want to use them. They do look great. |
I agree on the load rating, although I have driven on firestones, and they don't have the squishy marshmello sidewall that passenger rated have. The big problem that I have with the firestones from coker is the price. They are more than twice as expensive as many of the various LT rated radials. I don't like paying more to get less with new production stuff. _________________ .
Wanted:
sled Samba Member
Posted: Thu Oct 17, 2019 8:37 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Lind wrote: |
I don't like paying more to get less with new production stuff. |
but its all about the look bro!! _________________ drive your split. |
Posted: Thu Oct 17, 2019 5:41 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Lind wrote: |
srfndoc wrote: |
I agree on the load rating, although I have driven on firestones, and they don't have the squishy marshmello sidewall that passenger rated have. The big problem that I have with the firestones from coker is the price. They are more than twice as expensive as many of the various LT rated radials. I don't like paying more to get less with new production stuff. |
Lind, the Firestone 6.70s have a much better load rating vs the 6.40s. Perhaps you already realize that. |
hgandmc Samba Member
Posted: Sun Nov 03, 2019 7:58 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I've got a front rubbing from the top of the tires when I have passengers in my 62 deluxe. I am running Toyo extensa P205/75/15. I had to let air out to get the backs on, my mechanic said they were too big, but a (California)Bus expert said thats what everyone is running. Even the first post in this forum states this. My son said it makes the bus look to beefy. Why am I rubbing? Is there another problem, or do I look for a smaller set.I got a little cash at the moment. Thoughts--
Thanks
Frank
Also..do you feel a guilt when you buy tires over the net and go to a local to put them on? |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20267 Location: Sandpoint, ID
Posted: Sun Nov 03, 2019 8:25 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
hgandmc wrote: |
Thanks
Frank
Not all tires of the same size, are the exact same diameter/width from a different manufacturer. You may have some "large" 205/75R15's. I have run that exact size with no issues.
Also, if you are rubbing up front when others are not, I wonder if you may have a few broken torsion leaves in your front beam? It happens.
I buy my tires locally. The few dollars saved buying online does not offset the money spent with folks that live in my town. Also, they do a lot of stuff at no charge for me when I need it. _________________ nothing |
Posted: Wed Nov 13, 2019 8:58 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Thanks...makes great sense. Going to throw my bus up on stands and take a front end apart before I buy smaller tires. Good point about where to purchase tires.
Thanks
Frank |
paul_e_watson Samba Member
Joined: September 13, 2003 Posts: 8 Location: Colorado Springs
Posted: Tue Dec 10, 2019 6:21 am Post subject: |
srfndoc wrote: |
The price on these have dropped, now $62.99 each. |
Wow! They're now "on sale" for $188 - EACH!
I'm just trying to find a nice original looking tire for my 61 single cab for around town driving. So frustrating! |
Posted: Tue Dec 10, 2019 8:08 am Post subject: |
paul_e_watson wrote: |
srfndoc wrote: |
you can easily find a 195/70/15 C rated tire. they are in the 130 range, not quite 26 inches in diameter. For around town that should be fine. the bay buses had 195/75/14s on them, you can still turn the steering wheel..... _________________ regards
Uli
Posted: Tue Dec 10, 2019 9:23 am Post subject: |
mandraks wrote: |
srfndoc wrote: |
you can easily find a 195/70/15 C rated tire. they are in the 130 range, not quite 26 inches in diameter. For around town that should be fine. the bay buses had 195/75/14s on them, you can still turn the steering wheel..... |
Thanks for the info... I was debating the Achilles and Thunderer and even the Continental Vanco. I just found speedytire.com and they had some Thunderer Ranger R101 for about $75 + shipping so I pulled the trigger. So glad to finally be in the "club" with my 61 single cab. Have been trying to find the right one for years and did about a month ago. Love this site with all of it's knowledge! _________________ current stuff:
past stuff:
1966 Bug convertible
1973 Bug
1961 Single Cab
1969 Karmann Ghia |
Rhodrich Samba Member
Joined: December 27, 2001 Posts: 130 Location: London, UK
Posted: Sat Aug 22, 2020 2:05 pm Post subject: Re: 15" Radial Tires - Sizes and Vendors |
I've just fitted Nexen Roadian CT8 commercial tires in 185/80/15 (185R15C) size to my '64. They fill the arches nicely...
MUCH better than the 165R15 car tires it had on there before.
My spare tire has a 6.40-15 tire on it, and I can confirm that it's pretty much the same diameter as these. |
zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Sun Aug 23, 2020 1:52 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
does it fit behind the seat? Whats the load rating? Looks good _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2357 Location: In the woods, Ontario
Posted: Sun Aug 23, 2020 5:19 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
zimblewinder wrote: |
does it fit behind the seat? Whats the load rating? Looks good |
They are D rated, so very sturdy. Great tires, i had them on a couple buses. Havemt tried them behind the seat. |
They are D rated, so very sturdy. Great tires, i had them on a couple buses. Havent tried them behind the seat. |
Posted: Sun Aug 23, 2020 5:58 am Post subject: Re: 15" Radial Tires - Sizes and Vendors |
Indeed. 103/102R (8PR) Load Rating on the label. Haven't tried behind the seat either, but it looks like they'd be OK. I've now got one of my old 165/80/15s as a spare. |
