New Bus- '56 Springframe Westy!
Page: Previous  1, 2, 3 ... 37, 38, 39 ... 48, 49, 50  Next
BlastMasterMannyFresh Premium Member
PostPosted: Thu Jul 02, 2015 7:37 am    Post subject: Reply with quote
safe travels guys.
Clara Premium Member
Clara is offline
PostPosted: Fri Jul 03, 2015 6:52 am    Post subject: Reply with quote
Here are some updates from November 2014:
picking up a couple crates at Forward Air:
Clara is offline
PostPosted: Fri Jul 03, 2015 7:02 am    Post subject: Reply with quote
Assembly November 2014:
Clara is offline
PostPosted: Fri Jul 03, 2015 7:06 am    Post subject: Reply with quote
NOS turn signal seals are not symmetrical
Clara is offline
PostPosted: Fri Jul 03, 2015 7:23 am    Post subject: Reply with quote
I detailed the cab.
The heater tube is original paint, and you can see the red oxide primer.
The floor and inside of nose is re-spray by Josh.
1st pic of air vent was before detailing, 2nd pic after I had done half. The edge closer to the camera is cleaner. I did the whole cab. It may have taken a whole day. or more.
I left the key rust shadow on the dash tray.
dust in original paint on dash to right of speedo pod.
light covering of original paint over driver's door, particularly above where coat hook is:
Clara is offline
PostPosted: Fri Jul 03, 2015 7:34 am    Post subject: Reply with quote
seat stand detail
I cleaned it with 0000 steel wool and water, then buffing compound, then waxed it
Whoever said keeping og paint is because you are lazy has never done this.
loaded the area under the seat up:
The passenger side was nicer. I used a lot of 3M Finesseit:
Clara is offline
PostPosted: Fri Jul 03, 2015 7:52 am    Post subject: Reply with quote
Cab roof panel install:
use soap you dirty hippies!
slide the panel forward in the slots:
see the insulation above the panel?
Watch out so the panel goes into the front slot, instead of jamming up against it
when it is too snug to push by hand, tap with block of wood and mallet:
There are *two* versions of the 55-61 cab roof panel. I installed the looser version, so it is a bit gappy there.
This 58 bus with og cab roof panels has the same pattern of cab roof panel
It took longer to write this than to install the cab roof panels.
Clara is offline
PostPosted: Fri Jul 03, 2015 8:33 am    Post subject: Reply with quote
Bows
This is what separates the goats form the sheep. The subhatch is awesome. However, the wood rots, and has issues. Here instead of replacing the entire area around the subhatch, I chose to only replace part.
In the future, I would just replace all the wood around the subhatch.
This bus was odd in that the bows had a horizontal keyway. Normal is a vertical keyway. Vertical is better.
I replaced the left half of the #1 bow, and nailed it to the og right half, with og nails. This bow was also cut wide back at Westfalia, then notched after they realized it stuck out into the subhatch area. I spent more time to do it this messed up way instead of using my normal patterns. I think this was a real early subhatch bus, and they were still figuring it out. The bow patterns were all different from later 50s subhatch bus bows. I copied the rotten og ones to the bus.
The marks on the right bow are where I glued up the nail holes from the trim and screw holes from the seam trim.
I think the bows were originally white Limba. I used luan which is a different species of mahogany. It is more red rather than gold. Same grain pattern.
Where #2 goes:
I whittled a patch for the #2 bow, and glued and nailed #2 back together:
I drilled and fit the hinge. The pin fits nice and snug, not sloppy:
I had made new pieces for next to the subhatch. The one with the hinge holes was rotten, the one the catches screwed to the screws were pulling out.
Clamped the straight pieces to the roof, drilled pilot holes, tapped the new nails in:
Clara is offline
PostPosted: Fri Jul 03, 2015 8:51 am    Post subject: Reply with quote
straight bow near door at #2 was straightforward:
Attaching the straight bow next to the hinge pin was a bit tricky, especially with the old wood. It would have been easier if I just replaced #2 bow completely.
old straight bow by hinge pins:
pretty tight:
must have angle juuuust right
in the right place
straight bow didn't line up perfect vertically, but good enough for Westfalia
here it was before. You can see it does not line up at the bottom of the bow pieces:
inner straight bow at #1 bow:
whew! That felt good to have that done Smile
Clara is offline
PostPosted: Fri Jul 03, 2015 9:02 am    Post subject: Reply with quote
Installed the 4th / outer screw for cab roof panels after installing the shoehorns... the strips at the lower edge of the roof.
#3 bow was fine to re-use. They usually are. It has the odd horizontal keyway.
restored roof panel in:
used this to caulk the roof trim:
Greg squashed the aluminium trim in place carefully and firmly with the Knipex pliers and a piece of wood cushioning the jaw of the tool, while I tapped each nail in holding the trim through the roof panel into the bow:
holy smokes, it's installed:
Clara is offline
PostPosted: Fri Jul 03, 2015 9:33 am    Post subject: Reply with quote
More assembly, again, this was November 2014
waxed the floor, just cause it was so beautiful:
screwed the og wood down
easy e Premium Member
easy e is offline
PostPosted: Fri Jul 03, 2015 9:57 am    Post subject: Reply with quote
Looking great!! Love it!
e
aka: Evan
hitest
hitest is offline
PostPosted: Fri Jul 03, 2015 10:09 am    Post subject: Reply with quote
Well, there are thread updates, then there are thread updates!
This is clearly the latter. I love how sympathetic you are with this rare camper. Well done Clara- I guess Greg gets a nod too. Cool
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '68 L30k 141, '71 L12 113, '74 ORG 181
FU#5
zuggbug
zuggbug is offline
PostPosted: Fri Jul 03, 2015 6:51 pm    Post subject: Reply with quote
Awesome guys, thanks for sharing, it helps me a bunch.
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
j.pickens
j.pickens is offline
PostPosted: Fri Jul 03, 2015 9:09 pm    Post subject: Reply with quote
A sunset interlude amongst the assembly pix. Here is the bus along Lake Erie tonight. I call it "Portrait With Cooling Tower"
BeaterBarndoor wrote:
Red Fau Veh wrote:
jjjjack
jjjjack is offline
PostPosted: Sat Jul 04, 2015 3:03 am    Post subject: Reply with quote
Love all the attention to detail. I can't wait for the next episode Very Happy
Jack Stenner
1959 Mango Westfalia SO-23
1953 Porsche 356 Coupe
IG:j.stenner
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
Clara is offline
PostPosted: Sat Jul 04, 2015 6:45 am    Post subject: Reply with quote
flashback to camper kit install:
wood edging under panel:
insulation:
long panel:
wood bar for cushion support:
piece of wood for bulkhead support:
had to take off the cushion support bar to put the bulkhead panels in,
then bolted on the spring frame brackets
Clara is offline
PostPosted: Sat Jul 04, 2015 6:50 am    Post subject: Reply with quote
I don't think we installed the support for the jumpseat. Something to do with broken bolt and bad drill bit.
Clara is offline
PostPosted: Sat Jul 04, 2015 7:17 am    Post subject: Reply with quote
subhatch:
I used original screw placement, and it took HOURS to install that panel.
After getting the Bulli Brigade and comparing subhatch screw placement I was glad I did. AFACT, there were two versions of subhatch screw placement.
There was a problem with installing the sub hatch. Seemed like the hinges were too short. The original ones to the bus had broken, so we got some off another bus. They worked fine until the new bows were installed.
Old bows had a bit of a gap, at the front hinge. The bow was entirely rotted away at the front hinge, actually, and that is how we had driven this bus around for 25000 miles. It was harder to see with the metal trim around the roof, but the hatch wiggled up down so it was clear there were issues.:
So the bottom line is we removed the seals around the hatch, just put in enough to not smash metal against metal, and called it good enough to drive to Florida.
Clara is offline
PostPosted: Sat Jul 04, 2015 7:28 am    Post subject: Reply with quote
By this time the ETD to leave for Bulli Brigade was rapidly approaching. And passed. John invoked the 45 minute rule, jumped in his swivel seat sunroof kombi, and headed south.
I did not take as many pics as I meant to of the process. Honestly, we used some NOS bits on the bus, like gas door seal, pop out window seal, I did not even document. I really like real VW pop out window seals. But time was short, the pressure was on.
Greg did a quick spit and polish on the roof rack, we popped the motor in, threw the gear in the bus and drove south en route to Florida, with no time for relaxing. Just drive 1000 miles. Ya, we saved the original paint rear bumper for a patina bus and painted an NOS bumper.
We stopped for the night at Lufteknic:
I could look back and see this:
All bright eyed and bushy tailed when we got to Florida:
Didn't make it to Tampa that night, camped out and got there the next morning.
In the condo parking lot:
Page 38 of 50
