tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Mon Feb 08, 2021 4:32 pm Post subject: Battery draining overnight. |
We have a 1600 with an alternator with an external regulator. Unless we shut off the battery switch to disconnect, the battery will be dead dead overnight.
There are diodes to prevent this but not sure how that works. The buggy had a generator and this problem showed up after changing over to the alternator.
Do we look for a different regulator or?
_________________ My wife said I never listen to her.
Or something like that! |
Dale M. Samba Member
Posted: Mon Feb 08, 2021 6:22 pm Post subject: Re: Battery draining overnight. |
Mmmm.... Regulator?......... ,
What type of alternator do you have?.... IS it a AL 78 or AL 82....
AL 78 requires a regulator, BUT not the regulator used with a generator, it had to be a regulator designed for the alternator...
AL82 alternator does not require a regulator....
Need to know more about your conversion to alternator...
Posted: Mon Feb 08, 2021 7:15 pm Post subject: Re: Battery draining overnight. |
Ok. I will check out the alternator in the morning. _________________ My wife said I never listen to her.
Posted: Tue Feb 09, 2021 3:31 pm Post subject: Re: Battery draining overnight. |
Here is the alternator and external regulator. It was wired up with the indicator light and it charged fine. Problem was the battery draining totally after engine was shut off and left overnight.
Posted: Tue Feb 09, 2021 8:16 pm Post subject: Re: Battery draining overnight. |
Disconnect regulator from alternator and see what it does over night....
