fan belt all weird
orangebug60guy
Twin #1
orangebug60guy is offline
PostPosted: Tue Sep 27, 2005 7:04 pm    Post subject: fan belt all weird Reply with quote
so we have the 1600sp down in the basement and we've been dickin around for a while and its almost ready. one thing is we need new engine tin on the 1&2 cylinder, easy! but i've noticed that the belt on the alt isn't moving right and is turning when it get to the alt only in certain times. this also seems to be making the whole fan shroud lean forward and stuff to, almost like the belt is too small and making it lean. here's some pics, any help!
screwed up belt???
engine tin that needs replacing
Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation.
dirtylawnchair
dirtylawnchair is offline
PostPosted: Tue Sep 27, 2005 7:25 pm    Post subject: Reply with quote
I hope you get an answer I have a 36hp doing the same thing.
does it seem that the gen pully is sticking out further than the crank pully? Thats what I found.
Paulie
63 Standard OG paint
hazetguy
hazetguy is offline
PostPosted: Tue Sep 27, 2005 7:27 pm    Post subject: Reply with quote
first of all, get a new continental belt. 9.5 x 905. get rid of that (what appears to be) cheesy NAPA belt which is probably not the right size anyway.
you don't have an alternator, you have a generator. is it a 30amp or a 38amp? it will be stamped in the generator body. if you have a 38amp, you need other backing plates or your alignment will always be off.
it looks like you don't have any shims between the pulley halves. have you tried adjusting that?
clean the rust and crap out of your pulleys, where the belt rides. you're gonna chew up belts super fast if they are as rusty as the look.
the tin in the last pic is almost comical. i know you said you need to replace it, but you were going to do that before you drove it, right??
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
orangebug60guy
Twin #1
PostPosted: Tue Sep 27, 2005 7:44 pm    Post subject: Reply with quote
ok so its a gen...alright! but i'm geeting new cooling tin beofre i put it in the bus. whats the plate i'm missing, it does seem to stick out to far. i had a few shims in between the pulley's and it just made the belt slip more.
PostPosted: Tue Sep 27, 2005 7:50 pm    Post subject: Reply with quote
Your belt is riding way too high, are there any shims in there?
What hazetguy said...
hazetguy
hazetguy is offline
PostPosted: Tue Sep 27, 2005 8:19 pm    Post subject: Reply with quote
you may not be missing any plate. what amperage is the generator?
after knowing that, the next step is to get a new, real belt.
hazetguy: invested?
orangebug60guy
Twin #1
PostPosted: Wed Sep 28, 2005 4:42 pm    Post subject: Reply with quote
is this the right kind of belt?
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D903%2D137%2DBG
there are none of the 9.5x905
coolerthanelvis
coolerthanelvis is offline
PostPosted: Wed Sep 28, 2005 8:59 pm    Post subject: Reply with quote
They've got shims but it looks like they are all on the outside.
A few of those shims should be between the pulley halves.
Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob
meinvw
meinvw is offline
PostPosted: Thu Sep 29, 2005 6:48 am    Post subject: Reply with quote
New belt, shim it correctly, and if it is leaning, double check that the shroud is bolted down. Also as stated before clean that rust! It could be grabbing the belt and making it walk out of the pulley. Maybe check the pulley and make sure it is not bent either.
The memories of a man in his old age, are the deeds of a man in his prime.
Quando Omni Flunkus Moritati !
73 High roof, 91 Carat, 87 Weekender, Mr magoo buggy, 88 LT 28, 98 R32,81 Diesel double door, 73 tin top, 72 HR.
pyrOman
Fire Master
pyrOman is offline
PostPosted: Thu Sep 29, 2005 7:04 am    Post subject: Reply with quote
Here's my $0.25 Confused
Not reading any of your questions and just looking at the pictures I see a motor that absolutely needs to be totally taken apart, cleaned up, inspected for excesive wear, have any and all parts replaced as needed, and put back together with brand new tin. And yes a new belt! Rolling Eyes
In other words, from just the looks of that motor, the belt should be the very least of your worries! Good luck! Cool
orangebug60guy
Twin #1
PostPosted: Thu Sep 29, 2005 8:16 am    Post subject: Reply with quote
i'm putting new tin on it in a few days and i have all new hardware
