vwspijlbus Samba Member
Joined: December 23, 2003 Posts: 546 Location: The Netherlands
Posted: Tue Oct 04, 2005 1:07 pm Post subject: Mud flap on the front..? |
Hi,
does anyone mounted mud flaps on the front?
I bougth recently an additional set of rear mud flaps to mount on the front (just for the looks).
Any mounting advise / tips / pictures from thise who whent down this path? _________________ Frank
1967 Dutch SO-42
www.vwspijlbus.blogspot.com |
NAES Samba Member
Joined: September 10, 2003 Posts: 2121 Location: AREA-52 Southern Killafornia
Posted: Tue Oct 04, 2005 1:26 pm Post subject: |
I saw that a lot in the late 80's/early 90's. Played way out in Califas
If you were ghetto you just drilled into the rear of the wheelwell. Wait, I think that's how they were all done!
It's a lousy look if you ask me, not that you did. _________________ Barndoor Mafia
Box On Wheels
SBS #00 |
TeamSpatula Samba In The Rain
Posted: Tue Oct 04, 2005 1:31 pm Post subject: |
Foolish though it is to mention Bays & Vanagons in here, the later Westies did have a mud flap to protect the propane tank for the stove...they had some sort of bracket, although it's been a while since I sold my '87 so I don't know if you could adapt it or not. _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
ronnie Samba Member
Joined: May 01, 2002 Posts: 1053 Location: lost somewhere between the earth and my home.
Posted: Tue Oct 04, 2005 2:06 pm Post subject: |
these are on my 62 westy
they looked to me like they could be dealer installed. |
Posted: Tue Oct 04, 2005 11:33 pm Post subject: |
Ronnie: thanks for this pic! _________________ Frank
1967 Dutch SO-42
tlavergne Samba Member
Posted: Wed Oct 05, 2005 6:31 pm Post subject: |
I have been thinking of doing this myself. I think it would protect my rockers. I almost bought a pair of rear mud flaps at a VW show this summer (to try to put on the front) but the guy wanted $60
Still thinking about how to do it and have it look OK.
Tom |
Posted: Thu Oct 06, 2005 3:26 am Post subject: |
ronnie wrote: |
They sure were not added "yesterday".
Have you seen other splits with mud flaps on the front in the US?
I do not know if this was an option at that time.
In the Netherlands I do not see it that mutch... _________________ Frank
1967 Dutch SO-42
vitwagen Samba Member
Joined: January 16, 2003 Posts: 128 Location: ROMA ITALIA
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Mon Oct 31, 2016 1:28 pm Post subject: Re: Mud flap on the front..? |
reviving this discussion!!! Has one else seen mudflaps on the front recently? I'm assuming some of the Shasta Buses have them. Can anyone post pictures of the mounts? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Oct 31, 2016 1:57 pm Post subject: |
vitwagen wrote: |
My bus had M75 option, rear and front MUD flaps, but anybody knows the exactly part number or did never see? Any pics?? |
Problem with the Mcodes is that VW kept using them, often adapting the codes somewhat or to mean completely new things. So the factory birth certificates must be read with that in mind. _________________ In Stereo, Where Available! |
stevo Samba Member
Joined: January 22, 2004 Posts: 908 Location: the eugeniverse
Posted: Sat Jun 13, 2020 10:08 am Post subject: Re: Mud flap on the front..? |
Longboardluv wrote: |
Below are the front wheel brackets from the Westy pictured above.
Posted: Sat Jun 13, 2020 12:08 pm Post subject: Re: Mud flap on the front..? |
Thanks for posting that image! How long are the bolts from under the head to the end?
From your previous image it looks like there might be a diagonal brace?
Never mind, the diagonal brace is just the flange of the jack outrigger. _________________ In Stereo, Where Available! |
stevo Samba Member
Posted: Sat Jun 13, 2020 10:00 pm Post subject: Re: Mud flap on the front..? |
Eric&Barb wrote: |
Thanks for posting that image! How long are the bolts from under the head to the end? |
tha'd be 5" |
Posted: Sun Jun 14, 2020 8:50 am Post subject: Re: Mud flap on the front..? |
stevo wrote: |
Eric&Barb wrote: |
tha'd be 5" |
Thanks again, that helps to give it a scale. Might build us a set for the SO-34. _________________ In Stereo, Where Available! |
Daddybus Samba Member
Posted: Sun Jun 14, 2020 3:01 pm Post subject: Re: Mud flap on the front..? |
stevo wrote: |
Eric&Barb wrote: |
tha'd be 5" |
What size M? |
panel Samba Member
Joined: December 02, 2001 Posts: 1091 Location: Victoria B.C. Canada
Posted: Mon Jun 15, 2020 5:49 pm Post subject: Re: Mud flap on the front..? |
panel wrote: |
Saw some in this video........ |
Problem with that is the flaps are just bolted to the body. That is going to hold water/dirt between the flap and bus body, causing much faster rust in that area. _________________ In Stereo, Where Available! |
