pjackman Samba Member
Joined: May 02, 2005 Posts: 149 Location: Vancouver, BC
Posted: Sat Oct 15, 2005 12:31 pm Post subject: |
Well I'll be darned. Thanks Thrak for the camper manual review . Perhaps the original owner's insistence on this point was the source of my misinformation and it was reinforced by the stove use declaration.
Thanks to everyone for their comments. I'm much relieved to know that driving with the fridge on propane is nothing much to worry about. Based on this thread I think I'll continue to use the alternator for long hauls as long as the cooling power is satisfactory, but leave it on propane for short hops. |
Mikeyworks Samba Member
Joined: May 10, 2004 Posts: 34 Location: Havre de Grace, MD
Posted: Mon Oct 17, 2005 7:01 am Post subject: |
While I am not overly intimate with the workings of the OEM Westy fridges, I know that many RV fridges work on the ammonia heating/cooling cycle (heated by propane) to provide the cooling "power."
Now many of these fridges are particuarly suceptible to operation angles. They need to be relatively level in order to operate. Since this is the case, many manufacturers highly recommend that you do not operate them on propane when you are driving. This is to prevent the unusual movement of the ammonia in the cooling circut while moving (turns, hills, braking, etc.). This can damage the unit if run on an angle for an extended period of time.
Again, while I am not an expert, this is just my $.02 with what's in my head.
mikey |
Thrak Samba Member
Joined: September 07, 2005 Posts: 29 Location: Lexington, Ky.
Posted: Mon Oct 17, 2005 12:56 pm Post subject: |
The cooling unit doesn't "know" which heat source it's operating on. It's still using ammonia. And if we couldn't use our fridges while driving they wouldn't be of much use. The manual says 8 degrees tilt any direction while parked. |
lordsniff Samba Member
Posted: Mon Oct 17, 2005 2:35 pm Post subject: |
Mikeyworks wrote: |
mikey |
Right on .
I for one was viewing this solely from a safety angle but you bring up an angle I had never thought of , although when camping in my trailer there are levelers everywhere . _________________ I was born at a very early age and it was such a shock I didn't speak for another 2 years .
______________________________________
87 Syncro
85 Gl
96 Dodge Ram V10
2001 Honda |
Posted: Fri Nov 18, 2005 3:41 pm Post subject: |
bigdood wrote: |
the biggest issue i see is remembering to turn it off at gas stations - don't think you'd want the pilot light running |
Anyone see the news on Fox today .
Van filled up at gas station with his cooler running on butane .
It became a ball of flame in minutes .
Theory has the cooler igniting the gasoline fumes .
Proves it does happen . _________________ I was born at a very early age and it was such a shock I didn't speak for another 2 years .
87 Syncro
85 Gl
96 Dodge Ram V10
2001 Honda |
IanMay Samba Member
Posted: Tue Aug 15, 2006 4:31 pm Post subject: |
I never shut off the pilot light when driving. Just at gas stations. NO PROBLEMS SO FAR!!!!!!!Ian |
Cat and Walter Samba Member
Joined: June 17, 2006 Posts: 244 Location: Soutern Utah
Posted: Tue Aug 15, 2006 4:39 pm Post subject: |
lordsniff wrote: |
The reason is in case of an accident . With an open gas tank and a naked flame , the end result is obvious .
Remember the coach with open oxygen tanks on the news recently . |
I love it when you talk dirty!! |
Mulcheese Samba Member
Joined: September 19, 2004 Posts: 548 Location: Maple Grove, Mn
Posted: Wed Aug 16, 2006 6:06 am Post subject: |
I never drive with mine on propane. What I do: Get up in the morning, plug the van in and turn ridge to AC ( I also have a trickle charger hooked up in the van to charge the aug. battery). Start packing the van and in a few hours load the fridge with cold food, temps are usually below 40* by then. Right before I leave I switch the fridge to 12v and away I go. The temp stays constant while I drive. When I get to my destination first thing I do is level the van and turn the fridge to propane. If I leave to drive somewhere for the day I switch to 12v and use that until I am parked back in my camping spot. If on my days adventure I am going to be away from the van for any extended period of time then I will switch it to propane so as not to drain the batt. and then back to 12v when the van is back on the road. This way works great for me and then I dont have to worry about an open flame when the van is moving. _________________ 82 Westy: Air is cool! |
Posted: Wed Aug 16, 2006 4:34 pm Post subject: |
We've been driving with propane always on since posting this topic last fall and have experienced no problems. |
tds3pete Samba Member
Joined: April 04, 2004 Posts: 914 Location: Seattle, WA
Posted: Fri Aug 18, 2006 10:36 pm Post subject: |
Although the PO said he always drove with the fridge on propane with no issues, I never drive with the propane tank main valve open...........I really don't want to be in accident that rips my tank loose spewing propane everywhere! Pilot light or no pilot light, who knows where the supply line might rupture....who wants their van to end up like a fried humvee in Iraq.
My factory manual says never drive with the propane on, probably thanks their legal department. _________________ '58 Westy camper-come and gone
'73 Westy-bought new in Holland,now gone
'86 Syncro weekender-come and gone
'79 Westy...Oscar
'95 Eurovan Camper/5 spd...Marsha Mellow |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Jun 09, 2010 10:32 am Post subject: |
I am posting this here because it is a "sticky" and it might be of some help to someone who has a similar problem. Once I got my Vanagon back on the road, the fridge would "blow out" when running on propane underway. I had read where someone had fabricated a deflector to stop this from happening. Anyhow, I was content to us 12v when underway and switching to propane when stopped for an extended time. Before our recent trip, I noticed the sheetmetal screws were getting pretty rusty looking that retain the outside vent. I decided to pull the vent off and replace all of the sheetmetal screws. I thought about fabricating a deflector, but was concerned the factory grommet would not seal properly and I intend to paint the van this year and did not want to silicone the tar out of it.
Once I had the vent off, there was a lot of dust and dirt. I cleaned as much as I could and got the idea to blow compressed air through the little orafice/drain inside below the fridge door. A pretty good cloud of dust came out the vent area. I put it all back together with new stainless screws for now. On our trip, one morning I forgot to switch the propane off. At lunch time we stopped and the fridge was still running on propane even after running 70mph in a New Mexico desert cross wind. I figured it was a fluke, so I tried it again the next day. Somehow, by just blowing out the drain and replacing the screws, the fridge stays lit. I do turn it off when I fill the propane tank, but have not worried when I fill up since I am using diesel. As far as propane consumption, using the fridge continuous on propane and the stove for coffee and heating dinner, we used about a pound of propane a week. Your results may vary. mark _________________ ☮️ |
msinabottle Samba Member
Posted: Wed Jun 09, 2010 9:34 pm Post subject: Leaks in the Hoses/NOT WHEN FILLING PROPANE! |
Another theory advanced around here has been that pinhole leaks in the vent and intake hoses cause the fridge to blow out when driving, as mine does. I just run it on DC and turn it over to propane immediately upon stopping.
Also, in no uncertain terms, my propane guy (who has worked a LOT with Vanagons) says you're quite safe running with the gas on--except when you're filling the propane tank itself. Then it's yet another way for Vanagon Spontaneous Combustion. As if we needed one.
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Sat Jun 12, 2010 1:04 pm Post subject: |
Tomwesty,is your fridge a compressor model??
I'm living in my vanagon for almost 2 years and the fridge is constantly running on propane for 2 years
It works great.
The propane tanks lasts between 10 and 13 days depending how much I cook.
I heat up some water every morning for the tea,about half a liter in a cast iron pan with cover.
I cook for dinner for about 10 to 15 minutes once a day.
I can't have the fridge running on propane all the time if I'm driving,it looks like the flame is blown out when driving,I never found a security device that shuts it:if anyone knows how to disable it,please LET ME KNOW
Sometimes the flame doesn't stay if it has been shut after a long drive and I'm starting it.I found an easy trick:start it on,then turni it to minimum right after,for 5 minutes.It works.then back to maximum.
I never used the 12V,this is inefficient
I'm thinking about switching to a real one,compressor model. |
ohlott Samba Member
Joined: March 28, 2007 Posts: 294 Location: san clemente CA
Posted: Sat Jun 12, 2010 3:39 pm Post subject: |
Used to do it all the time until my van blew up.....Nah just joking. I ran it all the time. When I took the fridge out to clean it and got it back in. The flame would blow out. I rigged a wind shield out of a bottom of a kids sand bucket. worked great. Now I run the truck fridge. Best mod ever. _________________ 83.5 westy 2.2 subi |
Kejidog Samba Member
Joined: July 26, 2011 Posts: 92 Location: Nova Scotia
Posted: Tue Jun 05, 2012 12:21 pm Post subject: |
We must be the only people who use our fridge on here, our dometic runs great with no mods. Cold beer and sometimes frozen bacon, I usually start my fridge on 12 volt. Drive to our destination and once the van is nice and level. Give it three of four good pumps and bingo! Cool fridge. Works every time. _________________ 85 Westy Camper "Jeebus"
"new" rebuilt 2.1 with a ten cent stainless exhaust- lovin all the power!!!! |
debbiej Samba Member
Joined: December 14, 2008 Posts: 1556 Location: las cruces, nm
Posted: Tue Jun 05, 2012 12:29 pm Post subject: |
does driving with the fridge on 12 v put a load on the alternator or battery? |
GWTWTLW Samba Member
Joined: April 22, 2008 Posts: 2174 Location: Portland, OR
Posted: Tue Jun 05, 2012 12:35 pm Post subject: |
I've mentioned this before but it's probably worth mentioning again to at least give folks something to take into consideration. When I rolled my Adventurewagen, my stove was ripped completely out of the cabinet leaving a leaking propane line. If the tank had been open at the time, my outcome might have been a little different. Just something to think about... _________________ 89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw |
kamzcab86 Samba Moderator
Posted: Tue Jun 05, 2012 12:43 pm Post subject: |
Kejidog wrote: |
We must be the only people who use our fridge on here, our dometic runs great with no mods. Cold beer and sometimes frozen bacon, I usually start my fridge on 12 volt. Drive to our destination and once the van is nice and level. Give it three of four good pumps and bingo! Cool fridge. Works every time. |
Nope. I use mine every road trip and it fires up on propane every time (nothing done to mine either). It struggles in hot weather, but keeps drinks nice and cool. It was to great to open the van after a grueling 18 mile bike ride back in May and pop open a nice cold beverage. I had to use it as a cooler on a short road trip last week to keep a last minute purchase of M&Ms from melting.
I usually drive with it running on 12v, unless the drives between camp spots are somewhat short, or lots of stops are being made.
debbiej wrote: |
My '90 doesn't seem to care if the fridge is on 12v... verified with a volt meter. _________________ ~Kamz
2016 Golf GTI S
danfromsyr Samba Member
Posted: Tue Jun 05, 2012 1:04 pm Post subject: |
the Adventure wagen stove is a very different install and device than the westy stoves.
the AW ones are held in with only (2) screws (in my ASI Case fwiw) and coupled via a flex rubber hose.
the Westfalia units are significantly secured into the cabinet and have no flexible coupler..
I've seen many many pics (your's included) of vanagon wrecks.. never a westy stove much more than displaced with shattered plywood.
of course this isn't an endorsement to drive with the propane tank valve in the open position.. and my biggest fear on running the fridge is at a gas station filling up.. the next guy over can have a big spill and your pilot could ignite it. but then so could yoru Alt or Dist when you fire up the van to get away from that yahoo too.
2nd big fear on leaving on the propane tank lies with the stove knobs. and a partially open burner valve.
GWTWTLW wrote: |
I've mentioned this before but it's probably worth mentioning again to at least give folks something to take into consideration. When I rolled my Adventurewagen, my stove was ripped completely out of the cabinet leaving a leaking propane line. If the tank had been open at the time, my outcome might have been a little different. Just something to think about... |
Abscate wrote: |
The Raven Samba Member
Posted: Tue Jun 05, 2012 2:57 pm Post subject: |
I leave it on propane all summer....good beer fridge at home. I have it turned all the way up so figuring 45-55f good temp for the beer I drink. I leave it on during fillup as well, no point worrying as its on the other side of the van. |
