runderwood Samba Member
Joined: July 17, 2007 Posts: 274 Location: near philadelphia, pa
Posted: Mon Oct 15, 2007 8:11 am Post subject: |
Any chance someone has one of the "arms" lying around that you could throw on a flatbed scanner along with a ruler, and upload a pic so those of us that need a template to make that piece have something to go by?
I also purchased a new WW valve, but no arm...
BTW - the valve I got has one brass tube and one plastic tube... can they still be pulled out and switched?
Thanks! _________________ 61 DD Panel |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Mon Oct 15, 2007 8:46 am Post subject: |
runderwood wrote: |
Thanks! |
you could buy an original for much less than the effort it would take to reproduce one. _________________ .
Wanted:
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Mon Oct 15, 2007 11:13 am Post subject: |
runderwood wrote: |
Yes _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Mon Oct 15, 2007 1:49 pm Post subject: |
Quote: |
you could buy an original for much less than the effort it would take to reproduce one. |
I've not seen the "arm" available... supplier? or anyone have a used one? _________________ 61 DD Panel |
happyhippo Segapone Wanna-B
Posted: Mon Oct 15, 2007 2:08 pm Post subject: |
runderwood wrote: |
I've not seen the "arm" available... supplier? or anyone have a used one? |
I looked for an original arm "forever" and couldn't find one. Couldn't find any repros either. I finally had to buy an entire bus and haul it 550 miles to get one. Thank goodness the rest of the parts on the bus covered all my costs. _________________ -- Jeff--happyhippo
Look, I'll do whatever you want...Just get that death-weiner away from me! -- Principal Skinner
Never let a stripper clog dance near your dangle. -- Bob Oblong |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Oct 15, 2007 3:13 pm Post subject: |
Lind wrote: |
shameless plug here:
if anyone needs a core bus reserve lever, I have a couple for sale:
ditto (except i only have one for sale):
http://www.thesamba.com/vw/classifieds/detail.php?id=514388 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
EverettB Administrator
Joined: April 11, 2000 Posts: 69830 Location: Phoenix Metro
Posted: Mon Oct 15, 2007 8:20 pm Post subject: |
EXCELLENT! thanks! the pic will be very useful...
i don't really want to have to buy a whole valve, when all i need is the lever! _________________ 61 DD Panel |
Clara Samba Member
Posted: Mon Oct 15, 2007 8:56 pm Post subject: |
happyhippo wrote: |
runderwood wrote: |
I looked for an original arm "forever" and couldn't find one. Couldn't find any repros either. I finally had to buy an entire bus and haul it 550 miles to get one. Thank goodness the rest of the parts on the bus covered all my costs. |
I once saw a complete crap petcock on the samba for $5, with an arm... so I bought it.
Then it went on a bus (I think someone talked me out of it).
I dunno why, but they are often missing. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
dms Fred G. Sanford
Joined: August 05, 2007 Posts: 493 Location: At large. . .
Posted: Mon Oct 15, 2007 11:42 pm Post subject: |
I just bought a new one , $58.00 later and a screen $8.25 ouch
it looks to be well made german one , I didnt think you could get the kits for them still otherwise I would have got one of those instead .
There is nothing worse than a leaky gas tank . _________________ If you don't like the way I drive , stay off the sidewalk . |
Jerry J Samba Member
Joined: June 12, 2004 Posts: 1257 Location: Portland, OR
Posted: Tue Oct 16, 2007 5:23 pm Post subject: |
runderwood wrote: |
Thanks! |
If you are going to knock these arms off, let me know as I'd be interested in one if it's not too expensive. _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
Posted: Wed Oct 31, 2007 7:01 am Post subject: |
So, to make the new WW valve operate smoothly (the new valve i got is so stiff its fairly hard to turn with a wrench on it), do you just take off the rubber boot, and sand down that rubber gasket with the four holes to make it a little thinner? maybe some grease in there? _________________ 61 DD Panel |
Posted: Wed Oct 31, 2007 2:27 pm Post subject: |
runderwood wrote: |
So, to make the new WW valve operate smoothly (the new valve i got is so stiff its fairly hard to turn with a wrench on it), do you just take off the rubber boot, and sand down that rubber gasket with the four holes to make it a little thinner? maybe some grease in there? |
DaveM recommends a bit of graphite grease.
If you just got the whole works from WW I'd send it back and ask for one that works smoothly. _________________ Jerry
'58 Bug
'63 KGhia
'67 Squareback
'67 Standard Bus
'60 Single cab |
Stocknazi Samba Member
Posted: Wed Oct 31, 2007 5:12 pm Post subject: |
Jerry J wrote: |
runderwood wrote: |
If you just got the whole works from WW I'd send it back and ask for one that works smoothly. |
x2
for 60 bucks it should work correctly _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Fri Nov 02, 2007 1:54 pm Post subject: |
So after going back and forth with WW, they are telling me they are all relatively stiff since they are new and unworn... my options seem to be to return it and try one from elsewhere, or take apart the one I received and try lubricating it...
I'm not entirely enthusiastic with the response from WW...
Who out there has purchased a new valve, and was able to make it turn with the cable after a little modification? What did you do?... or has anyone purchased a new valve that was great right out of the package? If so, where did you get it from?
Thanks, _________________ 61 DD Panel |
Posted: Fri Nov 02, 2007 6:27 pm Post subject: |
I got mine from WW a couple years ago. It was stiff, but moved easily enough that I could (just barely) operate it from the cab.
I found I had to make an adjustment the length of the sheath so that I could get full movement out of it.
Oddly, I've yet to use it since I installed the new tap.
I suppose I should cycle it a couple times before I put the bus to bed for the winter. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Fri Nov 02, 2007 6:38 pm Post subject: |
Runderwood, are you trying to open and close the valve when not installed?
Like holding it in your hands and operating it?
If so, it could just be that its harder to operate by hand than you might expect.
Mine was very hard to operate manually, but when installed, it feels like I'd think the factory would want it tofeel when you pull the cable in and out. _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Fri Nov 02, 2007 7:22 pm Post subject: |
I am holding it in my hand trying to operate it... i did test fit it on my tank before i had installled the tank in the van, and either way seemed awful tight... (and I'm trying to turn it with a 5" wrench not the little 2" lever)...
i guess i'll try installing it... i do think however, that since i need to make my own lever anyway, I'll make it a little bit longer than normal to get a little more force... shouldn't be issue if it's there's extra throw right?, the knob in the cab would just pull out a bit further than normal... _________________ 61 DD Panel |
Posted: Fri Nov 02, 2007 7:42 pm Post subject: |
runderwood wrote: |
i guess i'll try installing it... i do think however, that since i need to make my own lever anyway, I'll make it a little bit longer than normal to get a little more force... shouldn't be issue if it's there's extra throw right?, the knob in the cab would just pull out a bit further than normal... |
I'd watch that, because the solid shaft part of the knob end might get pulled right out of the ferrule with the longer throw. _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Fri Nov 02, 2007 7:55 pm Post subject: |
j.pickens - thanks - didn't think about that possible issue... standard size lever it is, and i'll hope it works... _________________ 61 DD Panel |
