help snapped key in ignition barrel
northwestalloy
northwestalloy is offline
PostPosted: Sat Nov 05, 2005 9:15 am    Post subject: help snapped key in ignition barrel Reply with quote
can anyone help me i have snapped my key in the ignition barrel. how do i get it out
thanks in advance
MedicTed
MedicTed is offline
PostPosted: Sat Nov 05, 2005 9:25 am    Post subject: Reply with quote
Tweezers or lock shop.
Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra
Shaken
Shaken is offline
PostPosted: Sat Nov 05, 2005 9:41 am    Post subject: Reply with quote
Had the same thing happen to the PO of the bus I bought... he bypassed the ignition and put a key on the dash...
Don't do that...
Needle nose pliers got my key out, but I guess it would depend how much purchase you have on the broken end.
Just remember to turn the key back to 'off' before trying to pull it out.
If you don't have enough of the broken key to grab, you could try a little JB weld on the key parts, might be enough to pull it out.
Just don't use too much and totally gum up your ignition.
Shaken
My other car is an MGB.
Cogito ergo possum.
View user's profile Send private message Facebook Twitter Instagram Classifieds Feedback
kevander
kevander is offline
PostPosted: Sat Nov 05, 2005 10:13 am    Post subject: Use tiny screwdrivers! Reply with quote
I had this problem twice and solved it by using two small computer screwdrivers - flat bladed. After sticking them in around the key, I turned the key to the off position. Then, I used them to carefully wedge the key out enough to grab with a needlenose pliers. Helps to have 3 hands or a helper!
"No one ever said life was easy."
twinfalls
twinfalls is offline
PostPosted: Sat Nov 05, 2005 11:54 am    Post subject: Reply with quote
All of the above and
I would firstly spray WD 40 and soak with thin oil.
Stock 1974 US Westy, AW-A 1800cc dual carbs. Twin Falls is my favorite site on the Churchill river in Manitoba.
Blaubus
Blaubus is offline
PostPosted: Sat Nov 05, 2005 1:14 pm    Post subject: Reply with quote
WD 40 has silicone in it! if you use THAT (first) you can forget about the JB weld... wont stick, by god!
SteelersBus
SteelersBus is offline
PostPosted: Sat Nov 05, 2005 1:40 pm    Post subject: Reply with quote
I am a locksmith and deal with this problem daily. Air cooled VW keys are opposite on both sides. Making picking them almost impossible. Anyway, go to a local locksmith and tell them your story. Ask them if you can borrow their key removal tool. It is small enough to go into a lock with the key in it. You twist the tool clockwise into the lock against the key. Then you pull it towards you. Not too hard, just enough to get a grip of the side of the key. Trying to remove it any other way damage the wafers in the lock or the key path itself. Good luck and let us know how it turns out.
Volkswagen Locksmith
Keys by Code, Locks & Keys Supplied,
Key all your Locks to one Key.
http://www.baughmanlock.com
Granny Grose's Buses 13
May 31 - June 3, 2018
Millmont, PA
https://www.facebook.com/groups/333391253346965/
bugster1226
bugster1226 is offline
PostPosted: Sat Nov 05, 2005 2:28 pm    Post subject: Reply with quote
I've used a VERY small fish hook with a long shank.
Straighten out the hook part and insert the barbed end along side the key. Twist EASY and pull done it three times on different cars. Works ok.
( IF YOU BREAK THE FISH HOOK OFF YOUR SOL) Good Luck
It ain't rocket science
deschutestrout
deschutestrout is offline
PostPosted: Sat Nov 05, 2005 2:36 pm    Post subject: Reply with quote
That's a creative solution! I'll remember that one.
'71 bug, answers to "Clementine"
'75 7 passenger bus called "Kombi"
'78 7 passenger sunroof bus, goes by "Gus"
'78 Westy "'Ole Red...The Happy Camper"
'78 Westy "The Big Turd"
steponmebbbboom
steponmebbbboom is offline
PostPosted: Sat Nov 05, 2005 3:51 pm    Post subject: Reply with quote
How are all these people snapping their keys off in the ignition switch?
Confused ???
twinfalls
PostPosted: Sat Nov 05, 2005 5:06 pm    Post subject: Reply with quote
So do I; I love it.
twinfalls
PostPosted: Sat Nov 05, 2005 5:20 pm    Post subject: Reply with quote
Confused ???
I guess, they have very badly worn keys and lock's wafers; And, or they don't know the trick to giggle a bit the wheel to help when the key is hard to move.
We did break appartement keys, few times, because
1_ my son is a moose
2_the lock got wear
3_the keys were weak.
I changed the cylinders for, I hope, better stuff.
ratwell
ratwell is offline
PostPosted: Sat Nov 05, 2005 9:55 pm    Post subject: Re: help snapped key in ignition barrel Reply with quote
If it's not deep maybe you can use a paperclip and a dab of glue and yank it out after the glue sets.
'78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ
Put your trust in the law offices of Bentley, Muir, Haynes, and Wilson.
