1968 "red tomatoe" project" beetle
walter kandetzki
walter kandetzki is offline
PostPosted: Sun Apr 22, 2007 5:33 pm    Post subject: Reply with quote
havent done too to much,got the pistons/jugs and a head on my 1641 single port and i also got my birth certificate..found out it had a red interior which is strange ( says it right next to the red line i put)
walter kandetzki
PostPosted: Tue May 01, 2007 1:34 pm    Post subject: Reply with quote
body is off and the chassis is going out to have a new floor put in and a new pan...also found this number on the beam (covered it with tape for now)
walter kandetzki
PostPosted: Tue May 29, 2007 10:27 am    Post subject: Reply with quote
chassis is back.i gotta undercoat the new pan and undercoat over the stuff on the tunnel and drivers pan.
gostros
Mr. Obvious
gostros is offline
PostPosted: Wed May 30, 2007 7:30 am    Post subject: Reply with quote
walter kandetzki wrote:
Whoa, let's see the plymoth!
AJ Quick
AJ Quick is offline
PostPosted: Thu May 31, 2007 11:39 am    Post subject: Reply with quote
That is a clean bug!
Plymouth a Super Bird?
Read My Beetle Restoration Blog!
http://www.RideSpace.net/
http://www.AJQuick.com/
View user's profile Send private message Visit poster's website AIM Address Classifieds Feedback
walter kandetzki
PostPosted: Thu May 31, 2007 1:11 pm    Post subject: Reply with quote
yep,its a superbird
walter kandetzki
PostPosted: Thu Jul 19, 2007 6:33 pm    Post subject: Reply with quote
body is out to have some panels welded and undersides painted so i can drop the body on the pan.found a factory marking while removing the undercoating.
walter kandetzki
PostPosted: Sun Aug 12, 2007 6:26 pm    Post subject: Reply with quote
got this NOS vdo guage panel and this used clock (needs the glass replaced but it works) for my 68 bug (which i have to paint red).also found a thermostat cable for the air cleaner....
walter kandetzki
PostPosted: Wed Oct 31, 2007 2:30 pm    Post subject: Reply with quote
well its been a good while since ive worked on the 68 (been working on my jetta getting it the way i want it)..i painted the transmission ford engine gray (it would get that white chalky stuff all over it all the time soo i needed to protect it)...
walter kandetzki
PostPosted: Sun May 11, 2008 7:26 pm    Post subject: Reply with quote
wow its been a long time since i posted on this.havent really done anything since all the dough has been in my jetta.im still waiting on my axel tubes and im trying to get the body back so i can have it stripped of paint then having more bodywork done.getting axel bearings n all soon and i also got some NOS fender beading for it (i gotta find a 4th one soon)
walter kandetzki
PostPosted: Sun Feb 15, 2009 1:07 am    Post subject: Reply with quote
its been awhile since i updated again..well i got the body back and i didnt like the bodywork..quarter panel was welded on with the new panel welded behind a piece of the old one and bondo slapped all over it and instead of fixing the rear apron.it was bondod..may have to buy another quarter panel and have a good body person fix it Confused
walter kandetzki
PostPosted: Thu Nov 12, 2009 8:41 pm    Post subject: Reply with quote
managed to pick one of these up on samba for my bug.it was an accessorie for my 68
Green_Lantern
Green_Lantern is offline
PostPosted: Fri Nov 13, 2009 9:25 am    Post subject: Reply with quote
Making good progress! I'm interested to see what your jetta looks like... Mk3 or 4?
walter kandetzki
PostPosted: Fri Nov 13, 2009 3:14 pm    Post subject: Reply with quote
its a mk4.mods to it right now are 20th ae rear brakes,euro front bumper strip,hella e codes (soon retrofits with audi rs6 projectors),13pd flywheel,msd ignition,gruven parts tensioner pulley (motor is a 12v vr6),bfi stage 1 trans,stage 2 dogbone,billet coolant pipe,oil pressure guage,tdi .756 5th
bnam
bnam is offline
PostPosted: Fri Nov 13, 2009 6:56 pm    Post subject: Reply with quote
looks like the gravel guard goes the other way -- fat end towards the body and tapers towards the wheel opening.
walter kandetzki
PostPosted: Fri Jan 28, 2011 9:07 pm    Post subject: Reply with quote
i have not done a thing to this car in awhile...took the beam off to rebuild it and never did anything...i in a way thought about selling it...i turned into a watercooled freak...own two waters now...
walter kandetzki
PostPosted: Thu Aug 25, 2011 9:40 pm    Post subject: Reply with quote
parted out my mk4 jetta (almost done).keeping my mk3 as my daily and once i finish selling stuff off the jetta im going to redo the chassis again.get a new steering box,get all of the brake lines and master cylinder and other parts and work on the chassis.going to go with a 1641 engine but im keeping the stock carb,correct muffler and all of the tins and thermostat on it.my buddy wanted my mk4 jetta wheel so i traded him for these ORIGINAL empi sprint stars.keeping the car bone stock minus the motor and these wheels.all of em are 4.5 wide (other 3 are not in pics).i may polish the silver area or repaint it silver.keeping the black part though
walter kandetzki
PostPosted: Sun Nov 13, 2011 6:55 pm    Post subject: Reply with quote
started stripping the beam down to repaint it right and stripped the framehead (well started).found these numbers on the beam as well
walter kandetzki
PostPosted: Mon Dec 05, 2011 10:57 pm    Post subject: Reply with quote
picked up a formula vee shifter locally for 15 bucks.its not even rusted or even really pitted.just real dirty and needs a good cleaning.i have the plastic base..just missing the boot.i do have the shift knob to but its worn out
got brake lines and some grommets
should i replace the drivers floor?it doesnt have holes but its getting crusty...the seat rails are messed up (in red).i cant decide if its a good idea or not..if i do i will get a wolfsburg west pan
walter kandetzki
PostPosted: Mon Dec 19, 2011 8:06 pm    Post subject: Reply with quote
after hours of wire wheeling and getting all of the surface rust paint off i got my first coat of master series on.what a PITA...
Page 4 of 6
