sliding door lock is stuck, door will not latch.
Tobias Duncan
Tobias Duncan is offline
PostPosted: Tue Nov 05, 2013 3:42 pm    Post subject: sliding door lock is stuck, door will not latch. Reply with quote
This just failed suddenly. Had to tie the door shut.
I read a few sliding door threads but it seems thay my problem is different. The inside lock lever is just frozen in the down position.
sandoz
sandoz is offline
PostPosted: Tue Nov 05, 2013 3:51 pm    Post subject: Reply with quote
Check out the circlip holding the bowden cable on at the back of the door, that is what kept mine from operating one time. I bought a circlip at the hardware store and popped it on and was good to go....
Tobias Duncan
PostPosted: Tue Nov 05, 2013 5:05 pm    Post subject: Reply with quote
Was about to dive in and take it all apart when I noticed that the lever was bent against the opening. Pried it away from the edge and it seems to work fine now.
