VDubMattStuart Samba Member
Joined: July 10, 2005 Posts: 273 Location: Lincoln, CA
Posted: Thu Nov 10, 2005 10:34 pm Post subject: Tire Recommendations? |
I looking to buy a set of new whilte wall tires for my stock 53. I know that there are a few places to buy from, but can anyone recommend a specific tire and where to get them? |
steven wood Samba Member
Joined: March 14, 2004 Posts: 1647 Location: Virginia, NOT West Virginia!
Posted: Fri Nov 11, 2005 2:05 am Post subject: |
Are you looking for original tires or something that looks like an original but is a radial? I like Denman whitewalls but I've heard that there no good for driving, old technology. The BF Goodrich that Coker sells is nice and it's a radial. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Fri Nov 11, 2005 2:12 am Post subject: |
Like Steven said, go to www.cokertire.com or contact Lucas Tires in Long Beach. They should have all the specs for you. _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Posted: Fri Nov 11, 2005 5:35 pm Post subject: |
thanks guys |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Fri Nov 11, 2005 7:23 pm Post subject: |
If you can find a supplier, Firestone 5.60x15 feature a 2 3/4-inch whitewall compared to a Denman which has a 2 1/4-inch whitewall. |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Fri Nov 11, 2005 7:29 pm Post subject: |
Skim wrote: |
Like Steven said, go to www.cokertire.com or contact Lucas Tires in Long Beach. They should have all the specs for you. |
Anybody got a number for Lucas Tires?........I tried information but they can't find them. Maybe they have moved? _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
crotchsplit Samba Member
Joined: May 02, 2004 Posts: 308 Location: Orlando, FL
Posted: Fri Nov 11, 2005 9:00 pm Post subject: split tires |
looking for a set of original size split bug tires which i believe are 5.20 X 16, anyone know where i can find these? i tried coker but had no luck finding them there. which tires are being used on stock splits? |
Wiggy Samba Member
Joined: April 17, 2003 Posts: 6601 Location: Downingtown, PA
Posted: Fri Nov 11, 2005 9:09 pm Post subject: Re: split tires |
slammedsplit wrote: |
I thought Coker had 5.0 x 16. I believe those are the correct tires. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
Skim Rants Master
Posted: Fri Nov 11, 2005 9:43 pm Post subject: |
53 0val wrote: |
Skim wrote: |
Anybody got a number for Lucas Tires?........I tried information but they can't find them. Maybe they have moved? |
No Bob they are still on Temple in Long Beach
2850 Temple Ave., Long Beach, CA 90806
Phone 562-595-6721 • Fax 562-595-0381
Hours: 9am - 5pm (8PM ET)
Monday - Friday
http://www.lucasclassictires.com/ _________________ GFK
1953 Kabriolet
1954 Sunroof
Posted: Fri Nov 11, 2005 9:45 pm Post subject: |
Thanks Tony. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
Posted: Sat Nov 12, 2005 7:48 am Post subject: tires |
i found out that 5.50 x 16 is what was used on several of the top notch restored splits. |
Wiggy Samba Member
Posted: Sat Nov 12, 2005 8:12 am Post subject: Re: tires |
Yeah- but I definately think those are wrong. _________________ Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval |
Posted: Sat Nov 12, 2005 9:20 am Post subject: |
I think Kevin is right again......5.50 or 5.60 would be too large for a split.... but not for your Zwitter. My '53 oval came with 5.60s and I can't believe that they would change half year. _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Sat Nov 12, 2005 10:01 am Post subject: |
My 1950 owners manual says "5.00x16" _________________ John Henry
'57 Deluxe
'56 Single Cab |
Heb623 Samba Member
Posted: Sat Nov 12, 2005 10:12 am Post subject: Tyres size |
The size of the tyres for all splits deluxe & standard before the "zwitter" is: 5.00x16!
Pressure front: 17,1 -18.5 lbs/sq.i (1,2 - 1,3 at)
Pressure back: 22,7 - 24,2 lbs/sq.in (1,6 - 1,7 at)
Spare wheel: 22,7 - 24,2 lbs/sq.in (1,6 - 1,7 at)
"Zwitter" and later 5.60 x 15!
ET |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sat Nov 12, 2005 10:18 am Post subject: Re: split tires |
2splits wrote: |
I thought Coker had 5.0 x 16. I believe those are the correct tires. |
Coker has plenty of 5.0 x 16s: http://www.cokertire.com/store/customer/search.php...1&y=10 |
Posted: Sat Nov 12, 2005 12:24 pm Post subject: |
Careful. All of those tires are motorcycle tires. The will fit on the 16" VW rim, but you get about a 1" wide contact patch.... and your split will look like iit is running on 4 motorcycle tires (which it would be). VERY unsafe tire for a car, load rating might not be suitable either... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Sat Nov 12, 2005 12:29 pm Post subject: |
That is a motorcycle tire also, although one with a very square profile. _________________ John Henry
'57 Deluxe
'56 Single Cab |
