ROGER LAWLESS Samba Member
Joined: December 18, 2004 Posts: 238 Location: SANTA CRUZ, CA
Posted: Sun Nov 13, 2005 12:21 pm Post subject: oil filter BLOW_OUT |
Why does my spin-on oil filter gasket blow out all the time?
I just replaced the old spin-on system with an EMPI one. Same problem.
I pulled out both oil releif springs and pistons and they were free in the galley. The springs look like 'stock' but I am not sure. I pulled one out of an old 1500cc and the springs were the same thickness and felt like they had the same tension.
The oil filter I bought at a NAPA parts house and they stated it would work.
CIP1 catalog states that I should run a empi 'high pressure' oil filter.
Any thoughts?
Thanks, Roger _________________ I have a61 Ragtop and a 69 Ghia Coupe |
Alan_U Samba Member
Joined: July 10, 2004 Posts: 1762 Location: Vancouver, BC Canada
Posted: Sun Nov 13, 2005 12:30 pm Post subject: |
K&N HP3001 is equivalent to a PH8A fram (piece of junk)
That filter is what I use since its capable of very high burst oil pressure and will filter extremely well.
step down your oil viscosity. 10w30 should be sufficient in most weather conditions.
I had issues when my 2332 was fresh. I was using a high quality PUREONE puralator. It didnt' like me
K&N worked like a charm. Nots expensive and works extremely well. _________________ 11.92sec pump gas true daily driver. Who says it cant be done.
No more time for VW's....... |
Posted: Sun Nov 13, 2005 12:32 pm Post subject: blow out oil day |
What filter can I buy TODAY? I do not wan't to have to order one as it will be another week. _________________ I have a61 Ragtop and a 69 Ghia Coupe |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76939 Location: Sneaking up behind you
Posted: Sun Nov 13, 2005 12:33 pm Post subject: Re: oil filter BLOW_OUT |
ROGER LAWLESS wrote: |
EMPI is Chinese for CRAP.
trust me... EMPI doesn't make the filter... they just put their name on it. Also FRAM is not what it used to be. The PH8A is junk and the HP1 now has the same inside of a PH8A but with a heavier can.
I decided to Nuke the issue and went with a Canton Mecca filter. It's got a billet can, anti drain back valve and a 8 micron filter element.
_________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Posted: Sun Nov 13, 2005 12:35 pm Post subject: Re: blow out oil day |
What filter can I buy TODAY? I do not wan't to have to order one as it will be another week. |
Go to the VW dealer and but a filter for a 91 GTi. They work like a charm. Or goto a auto parts store and but the same filter. Just make sure it's either a Mann or Mahle filter. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Nov 13, 2005 12:39 pm Post subject: |
Do any of them have a 'relief valve' built into them?
The can on mine seems ok but the rubber gasket blow's within 15 sec. of starting the engine. I am running 10 w 30 oil. _________________ I have a61 Ragtop and a 69 Ghia Coupe |
Glenn Mr. 010
Posted: Sun Nov 13, 2005 12:41 pm Post subject: |
The Mann and Mahle both have bypass valves.
Do you have a oil pressure gauge? If so, what's your pressure? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Nov 13, 2005 12:43 pm Post subject: |
I havn't wired it up yet. I can do that in about 15 minutes as I already ran all the wires. _________________ I have a61 Ragtop and a 69 Ghia Coupe |
Posted: Sun Nov 13, 2005 12:47 pm Post subject: oil pressure |
My local parts place has them BOTH for the 2K engine, GTI.
Will that work?
Glenn Mr. 010
Posted: Sun Nov 13, 2005 12:57 pm Post subject: |
I don't know. The fitting is 3/4"-16... you can try to match it up.
Is this a filter pump or remote filter. If it's a remote see if they have a Fram HP-1. It's for Ford V8s... that should hold you. _________________ Glenn
Member #1009
#BlueSquare |
Mad Manx Samba Member
Joined: September 30, 2004 Posts: 304 Location: Redondo Beach California
Posted: Sun Nov 13, 2005 3:09 pm Post subject: |
Again I chime in with Glen about the Canton Mecca filter. I have them
on all of my cars, 2 Volkswagens and a Ford. You will never blow one
up and they look cool. They are a bit expensive but you only buy it once
and then get replacement elements. If you need something now, get one
of the others that Glen mentioned but think about ordering a Canton you
will never regret it. I still have oil dripping from the rafters in the garage
from the so called heavy duty spin on Fram that blew 4 years ago. |
Bruce Samba Member
Posted: Sun Nov 13, 2005 3:36 pm Post subject: Re: oil filter BLOW_OUT |
Check your oil filter mount. I have seen many of them where the center threaded fitting was not square to the gasket surface. You can screw the filter in and look at the gap all the way around. It should be even. |
Posted: Sun Nov 13, 2005 4:56 pm Post subject: oil filter blow-out |
Well I went and bought the Mann German filter for the 91 GTI as mentioned by one of the guys.
IT BLEW out in 10 seconds! I watched the end puff out and then the oil seal went plooey! Oil all over the garage again. Placed the seal back into place and REALLY cranked it down again. Started the engine and no less than 5SECONDS, well you guessed it, plooey.
Back to a heavy duty oil pump without a spin-on oilfilter.
I had previously today pulled both 'pressure relief' valves and springs/pistons, out and checked them out. NO problem here.
Three studs and one bolt hold the oil pump and cover in place, Right? No more as the top right BOLT, for clearance, stripped out
Any way to repair this while still in the car?
I am at my wit's end. What little I have left.
Glenn Mr. 010
Posted: Sun Nov 13, 2005 4:59 pm Post subject: |
Something is wrong... what size pump do you have?
26mm or 30mm? _________________ Glenn
Member #1009
#BlueSquare |
veedubcrazy Samba Member
Joined: February 14, 2005 Posts: 2130 Location: La Porte, Tx.
Posted: Sun Nov 13, 2005 5:26 pm Post subject: |
i was having the exact problem, blowing out the spin-on filter gasket. i now use a diesel rabbit oil filter. its a mann filter, part #w940/25. i have not had a blow out since. _________________ 1967 Deluxe Sedan |
Brad M Samba Member
Joined: April 12, 2004 Posts: 280 Location: Belmont NC
Posted: Sun Nov 13, 2005 6:26 pm Post subject: |
Rodger,
Do you have any way to tell the pressure? My guess would be a restriction in the system past the filter causing abnormally high pressures. Or a bad filter mount with either an uneven mating surface or a pitched thread sert where the filter screws on causing it to meet the surface unevenly. Check to see if the filter mount is shot or if you have a restriction past the filter.
Not trying to make this sales pitch for CM or toot Glenn's horn to much but I also took his advise about the CM and have it ready to go in with my new 2017 when the rest of the parts arrive. You will not blow this thing up without some serious pressures. I also forked out for some Gene Berg swedged hoses and filter mount.
It's expensive but I'd wager to say its the last filter you will ever buy. Filter elements are not bad at around $15 and the staff at CM is great to deal with.
http://www.cmfilters.com
Ok now back to your problem at hand, let us know what your oil pressure is at startup and any info you have on the condition of your filter mount. _________________ Brad
61 Double Cab (Sold 8/7/10)
74 Standard Beetle |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Sun Nov 13, 2005 6:33 pm Post subject: |
If you're literally blowing the seals out of the filters you must have rediculously high oil pressure!Also sounds like you're running an Empi oil filter setup |
Glenn Mr. 010
Berg hoses are top quality.
I found a local hydraulics shop that also makes some very high quality hoses. _________________ Glenn
Member #1009
#BlueSquare |
Bruce Samba Member
Posted: Sun Nov 13, 2005 6:42 pm Post subject: Re: oil filter blow-out |
IT BLEW out in 10 seconds! I watched the end puff out and then |
The root of your problem is excessive pressure. The blowing filter is just the messenger. Fix the excessive pressure and you won't be blowing any filters.
What kind of springs and pistons do you have in the oil cct? Post a pic. If they are aftermarket or just repro replacement, they are highly suspect. I only use 30+ year old parts, they always work. |
Posted: Sun Nov 13, 2005 7:10 pm Post subject: excessive oil pump pressure. |
I have had three pumps on the engine.
Mehling cast iron heavy duty pump.
CB pump with spin-on filter
Empi pump with spin-on filter
Back to Mehling oil pump. Stripped out thread on the top right this PM. Pissed off.
Oil pressure releif pistons and springs were clean and stock. r&r'd them b4 I installed the NEW EMPI pump.
Replaced with the Mehling pump, NO FILTER, and ran the car for about 20 minutes. NO it did not blow-up during that time.
I am still stumped as to what to do next. I will hook up the wires tomorrow to the oil pressure guage, VDO.
I will say that the little 1600cc engine will really cook when you step on the gas.
The engine sat after a rebuild/build for 10-15 years without being run.
It has Gene berg ported and polished intakes with Webber 40's. Ported and polished heads. Appear to be stock. Swivel rocker feet and after market rockers. I pulled the heads off when I got it to see what was there. Broken glass ans a little water in one of the cylinders, very recent. as I could wipe it out of the one cylinder and there was NO RUST. Phew! I don't know what is in the 'short block' but I suspect a counter balanced crank plus ?
There are NO fenders on the car and there won't be any in the future so one of those remote oil filters is out of the question.
I really do not want to pull the engine again if I don't have to.
Thanks for all your help.
