slideshow240 Samba Member
Joined: September 10, 2005 Posts: 165 Location: houston
Posted: Mon May 20, 2019 7:03 pm Post subject: Re: Official "Super Beetle" lowering topic |
Got mine down with my little helper. Empi adjusta strut all the way down minus pulling the clip out.
Stock springs. For now.
One outer spline passenger side and one inner spline drivers side. Sits level now |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1292 Location: Modesto, CA
Posted: Mon May 20, 2019 8:34 pm Post subject: Re: Official "Super Beetle" lowering topic |
Nice height. Mine is a tad too low in the rear. I did an autocross this past weekend and would periodically hit the bumpstops on a hard transition. Course, I've not trimmed the bumpstops, which I will do soon.
H2OSB _________________ (o\_i_/o) I'm not a vegetarian because I love animals, I'm a vegetarian because I hate plants. |
RailBoy Samba Member
Joined: March 10, 2008 Posts: 2904 Location: Virginia
Posted: Tue May 21, 2019 12:22 am Post subject: Re: Official "Super Beetle" lowering topic |
Just a note here... If you run a sump make sure you are not cutting the bump sops down to were the sump will hit the asphalt when driving.. This also means when driving over speed pumps.. Yes, the suspension will deplete that much.
On mine I added like 3/4 inch to the bump stop do to sump plus driving conditions of my roads, but also if I have to take to the side of the asphalt if I have to hit the shoulder do to skinny roads. I run a sump on a stoker.
My bump stops do hit perodilically, but not hard. I run GR-2's which help. RB
By the way, to add, my pump stops are also slightly making up for tire diameter change, which is not much..... _________________ [quote="smitty24"]"HELP, I ported my own heads and now have fire coming out my ass" .[/quote]
NOV 75 SB Samba Member
Joined: September 04, 2018 Posts: 4 Location: NSW AUSTRALIA
Posted: Sat Nov 23, 2019 5:14 pm Post subject: sway bar for lowered front end |
Purchased a pair of adjustable struts from CIP1. adjusted the ring to lower 2 inches. Can I use my stock sway bar. Also noticed that the bolt ends of the sway bar have a slight angle. Should they point upwards or downwards when reinstalling sway bar. Thanks[/s] |
cajun_sun_bug Samba Member
Joined: October 20, 2019 Posts: 168 Location: Ms Gulfcoast
Posted: Sun Dec 08, 2019 9:22 pm Post subject: Re: Official "Super Beetle" lowering topic |
FWIW to those with the CIP1/EMPI adjustable struts, read some posts that the struts could be adjusted on the car...I tried and to the best of my knowledge that info is false, you have to pull the strut off to move the c clips, spring compressors will hit most things if you try to do it on the car, did mine today, went down two more spaces (about 2")
YMMV
PS one tip on strut spring compressors;..always hear horror stories about using a pair of spring/strut compressors, the trick is to use 3 (THREE) compressors (i own 2 sets) so the spring is compressed evenly on three sides, this keeps the compressors from walking, also the compressors with the sliding "lock pin" work best, IMHO.
_________________ Regards,
Todd
1974 Super Beetle Sun Bug
#cajunhotrodder on insta |
Posted: Fri Dec 27, 2019 8:08 am Post subject: Re: Official "Super Beetle" lowering topic |
Adjustable struts all the way down with cip1 2" springs |
Posted: Fri Dec 27, 2019 11:09 am Post subject: Re: Official "Super Beetle" lowering topic |
slideshow240 wrote: |
Very nice, any rubbing issues? _________________ Regards,
Todd
Posted: Fri Dec 27, 2019 12:59 pm Post subject: Re: Official "Super Beetle" lowering topic |
cajun_sun_bug wrote: |
Very nice, any rubbing issues? |
Waiting on disk brake to show up. The lower control arm is pretty close to the steering rack mounts and the factory sway bar is twisting the lower control arm. I am going to try and make some custom LCA's and ditch the sway bar and make tension rods then figure out how to reuse the sway bar
Hopefully. Haha |
Posted: Thu Jan 09, 2020 9:45 pm Post subject: Re: Official "Super Beetle" lowering topic |
New design roll center adjuster for my 79. Trying to fix all the problems with being low low |
Eric71sup Samba Member
Posted: Sat Mar 14, 2020 5:22 pm Post subject: Re: Official "Super Beetle" lowering topic |
I have installed the EMPI adjustable struts and Topline sport springs on the front of my 71 super. My issue is that the driver side now sits 3/4in lower than the passenger. They were within 1/4" before lowering. I can put a 4' level across the parking lights and see the difference. I have measured here, there and everywhere and can't find my issue. I haven't touched the rear yet until I get this figured out. _________________ 66’ Beetle (in process)
71' Super Convertible |
The Vos Samba Member
Joined: November 04, 2011 Posts: 44 Location: N. La. Swamps
Posted: Mon Apr 13, 2020 5:40 pm Post subject: Re: Official "Super Beetle" lowering topic |
Eric71sup wrote: |
I have installed the EMPI adjustable struts and Topline sport springs on the front of my 71 super. My issue is that the driver side now sits 3/4in lower than the passenger. They were within 1/4" before lowering. I can put a 4' level across the parking lights and see the difference. I have measured here, there and everywhere and can't find my issue. I haven't touched the rear yet until I get this figured out. |
Same situation here but the passenger side is lower! I have the TopLine Lowering Struts with the Sport Springs and have them in the top slot, just to lower a bit to level the front end. |
Posted: Tue Apr 21, 2020 12:26 pm Post subject: Re: Official "Super Beetle" lowering topic |
Anyone running drop spring plates on their super?? Thinking about getting some or making them |
Twony Samba Member
Joined: March 28, 2011 Posts: 27 Location: SE(Delco), PA
Posted: Wed Apr 22, 2020 7:35 am Post subject: Re: Official "Super Beetle" lowering topic |
The Vos wrote: |
Eric71sup wrote: |
I too just received my TopLine super low kit with sport springs and did the Maxx struts also. I have yet to install it but am considering on doing it now with all of my free time. I purchased from HDWheels in Plantwood Florida machine finish 914 retro 17x7" wheels with 205/40R17 tires. I can't wait to get it in the weeds. I hope to see how yall make out. Once I get this going I will post some photos. Happy wrenching! |
Twony Samba Member
Posted: Wed May 06, 2020 9:21 am Post subject: Re: Official "Super Beetle" lowering topic |
I just finally started putting some parts on my 71 Super. I bought top line super low coilover kit. I have not installed the sway bar yet but I did get the sway bar in addition. I hung the fender just to see how low it is after I put on my 17x7 914 remakes. I love that there is no wheel gap it sits perfect in the front. I have it at the lowest setting. These are really easy to put together in my garage with just a mounted vice and some hand tools. I've had this car since I was 15. When my dad passed away just after I could never part with it. It is great to see everybody else's projects. I hope to add to the community. As far as the rear, I like a raked look. The front in the weeds and the back sitting up just a little bit. |
boxer74 Samba Member
Joined: July 03, 2011 Posts: 709 Location: Ontario, Canada
Posted: Fri May 22, 2020 5:02 am Post subject: Re: Official "Super Beetle" lowering topic |
I'd like to lower the front of my 74 super about 2-2.5". I realize Top Line is the way to go, but I'm in Canada. With the exchange rate, shipping costs, etc. this puts it substantially more costly than ordering the EMPI adjustable struts and inserts from CIP1 in Canada. Are these really that bad? _________________ 74 Super
84 Westy |
Daddy o's 67 Samba Member
Joined: November 25, 2008 Posts: 118 Location: Lancaster, SC
Posted: Fri May 22, 2020 9:20 am Post subject: Re: Official "Super Beetle" lowering topic |
Aberg83,
Just build your own adjustable struts. This is a cutdown 79 Super Beetle strut housing to fit VW rabbit inserts (about 1 3/8" - 1 1/2" removed), some off brand spring adjusters i picked up in a junkyard off of a Honda and 12" 140lb springs I purchased from Summit Racing.
Posted: Fri May 22, 2020 9:21 am Post subject: Re: Official "Super Beetle" lowering topic |
Daddy o's 67 wrote: |
Aberg83,
Thanks, but that's about outside of my comfort zone. _________________ 74 Super
84 Westy |
Turnswrenches Samba Member
Joined: May 02, 2019 Posts: 552 Location: Dawsonville, GA
Posted: Tue Jun 02, 2020 4:08 am Post subject: Re: Official "Super Beetle" lowering topic |
I bought my 71 SB a year ago and only now realize... it looks like it was lowered already by the previous owner ???
offtherailz1 Samba Member
Joined: May 28, 2014 Posts: 166 Location: Bedfordshire, England
Posted: Tue Jun 02, 2020 3:00 pm Post subject: Re: Official "Super Beetle" lowering topic |
standard height rear on Koni reds and Kerscher’s on the front with uprated anti roll bar.
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
