Transmissions For Dummies
Page: Previous  1, 2, 3 ... 26, 27, 28
joescoolcustoms
joescoolcustoms is offline
PostPosted: Wed Jun 27, 2018 11:36 am    Post subject: Re: Transmissions For Dummies Reply with quote
I wonder if that is what these are from. I have had them for some time now.
UnKlear Racing TAT 2020
Bad News Racing 2018 NORRA 1000 3rd in class, 120/270 overall
Looks like it was painted with a live chicken,polished with a brick and buffed with a pine cone
dustymojave
dustymojave is offline
PostPosted: Thu Jun 28, 2018 12:52 am    Post subject: Re: Transmissions For Dummies Reply with quote
That MUST BE what those are!!!
But if there is no IRS trailing arm, I would think that would be VERY weak and flimsy with trouble maintaining camber. Maybe there's an IRS arm that it bolts to along with the spring plate. IRS with RGBs is pretty damned cool!
Richard
A.R.T.S. Tech Inspection MORE/MDR
Bajas, Fiberglass Buggies and Rails built in the Mojave Desert
SoCalBajas Member
Kicked Cancer's A$$...this match
Who.Me? Premium Member
Who.Me? is offline
PostPosted: Thu Jun 28, 2018 11:33 am    Post subject: Re: Transmissions For Dummies Reply with quote
Thanks both. I'd love to see the complete unit with axles to get an idea of how it worked.
From the description on that website, I didn't think they'd use IRS, as it says that those buses used splitscreen mechanicals. I figured it was an attempt to maintain the correct camber with spring plates.
Looking at those pictures, would the clamps grip a T-piece on the end of the axle that held the UJ (or one of them, if there was one at each end) in contact with the input shaft to the reduction box?
Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786
dustymojave
PostPosted: Tue Jul 03, 2018 3:01 pm    Post subject: Re: Transmissions For Dummies Reply with quote
If it were swing axle suspension, there would be no need to invent a different from swingaxle reduction gear box for the end of the axle with a u-joint on the inboard side as swingaxle reduction gear box axles already existed. This MUST be for an IRS suspension and the RGB MUST attach to a trailing arm. There is no other reason for this to exist. The gear box probably was an IRS tunnel case Bug box.
Obviously the generalization that the vehicle was built with split window mechanicals was, like many generalizations, not entirely true.
The shaft almost certainly has the rest of the u-joint not shown in the picture of the reduction box above. And it probably is a shaft with a slip joint built into it. And it very likely has a similar u-joint at the inboard end where it attaches to the output flange of the gear box.
Richard
SoCalBajas Member
westgl
westgl is offline
PostPosted: Fri Apr 12, 2019 1:10 pm    Post subject: Re: Transmissions For Dummies Reply with quote
I have a question for the Bug transaxle Gurus. My plan is to use the Rear suspension section, with Transaxle. I want to Make into a Front wheel drive rear wheel steering Reverse trike. I want use a adaptor plate for Warp9 electric Motor to the transaxle and transform it into a Front wheel drive fixed front wheels and a single rear wheel that is steerable. To me it looks like I just need to flip the diff over, I will Not be Flipping the trans as it will stay in it's original mounting orientation, as it will be running it Front wheel drive, I believe just the diff needs to be flipped over? and all is well. With an electric motor it will run in either direction.
Anything I should be aware of on the VW transaxle (I will be Beefing Up the transaxle) running it as a Front wheel drive.
brettsvw
brettsvw is offline
PostPosted: Mon Jun 03, 2019 3:01 pm    Post subject: Re: Transmissions For Dummies Reply with quote
Hello, looked thru all 28 pages and could not find info for thing transaxle. I have read somewhere in all this vast amounts of information that some thing transaxles had LSD diffs.
Trans code ( A 122 6 3 )
The number 1 appears to be upside down.
Thanks Brett
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
gears
gears is offline
PostPosted: Mon Oct 14, 2019 12:55 pm    Post subject: Re: Transmissions For Dummies Reply with quote
This Vanagon thread should be shared with the off-road forum. It's about significantly beefing up a Syncro transaxle, most of which applies to 091/1 as well.
https://www.thesamba.com/vw/forum/viewtopic.php?t=725130
aka Pablo, Geary
9.36 @ 146 in '86
'90 Syncro Westy SVX
'87 Syncro GL 2.5
Needed: Stock 14" x 6" Syncro steel rim
SamboSamba22 Premium Member
SamboSamba22 is offline
PostPosted: Sun Jan 12, 2020 1:06 pm    Post subject: Re: Transmissions For Dummies Reply with quote
Hey guys, so I’m looking for some clarification between a 3-rib and 5-rib transmission.
3-rib - CK (1700) type 4 engine
5-rib - CM (1800) type 4 engine
Which would be best to pair with a 1600 type 1 engine?
I’ve also measured the input shafts in both the 3-rib (type 4 engine) and the 5-rib (has been running with a type 1 engine) from the throwout bearing guide tube end to the end of the input shafts. Both measure 2 3/4”. Isn’t the input shaft in an 002 needing to be shorter to be used in a type 1 engine?
The Bus Barn Ltd. Co.
Maywood Mountain
Youtube: The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Doka)
1959 Dove Blue Single Cab - SOLD (undergoing complete restoration Dallas,Tx)
1965 Ruby Red Standard Beetle - SOLD (currently loved in Oklahoma)
1974 Brilliant Orange Westfalia “PushPop" The bus that started it all - SOLD (Livin' large in France)
Page 28 of 28
