joshua jones Samba Member
Joined: February 16, 2005 Posts: 132 Location: groton ct
Posted: Sat Nov 26, 2005 9:05 pm Post subject: stock 1200 upgrades? |
my 65 has a stock 1200. runs like new. previous owner had rebuild with lots of new parts dist, carb, etc. it runs so well just not enough power. i know i cant expect much out of a 40 horse but does anyone know any affordable upgrades like exhaust or bigger carb maybe? without sacrificing the reliablity of my little sewing machine, thanks |
sixfootdan Samba Smartass
Joined: February 13, 2002 Posts: 4848 Location: \Lo*ca"tion\, n. 1. The act or process of locating.
Posted: Sat Nov 26, 2005 9:07 pm Post subject: |
I judson supercharger would be expensive but really cool. _________________ Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!! |
volksfiend Samba Member
Joined: June 01, 2004 Posts: 283 Location: Mo....West of Mexico
Posted: Sat Nov 26, 2005 9:11 pm Post subject: |
if you can scrounge up an old 40 horse Kadron manifold they will do wonders. If you cannot find them then you can get a nice new set of weber ICT's for the singleport. This with a little free-er exhaust will wake it up nicely. If you still want more a set 1.4 rockers and heavy valve springs will round out the bolt on goodie package. Or you could just get a Judson |
ovalvwfan Samba Member
Posted: Sat Nov 26, 2005 9:33 pm Post subject: |
You said "set of Webers"...dual single port carbs?? I'd love to juice up my 1100 a bit. _________________ (o\UlU/o) = |
Posted: Sat Nov 26, 2005 9:40 pm Post subject: |
Yipes! Pricey! Think I'll keep that cash in my savings for my 1776cc! Thanks for the link tho. _________________ (o\UlU/o) = |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Nov 26, 2005 9:56 pm Post subject: |
You can ream the main jet out of the carb to a larger size. Maybe 1 or 2 sizes larger. It'll use more fuel, but you'll gain a slight noticeable increase. |
Posted: Sat Nov 26, 2005 11:42 pm Post subject: |
That's a good idea...ream w/ a regular drill and bit? What size bit? _________________ (o\UlU/o) = |
hlwimmer Samba Member
Joined: May 29, 2002 Posts: 533 Location: concord, calif.
Posted: Sun Nov 27, 2005 10:26 am Post subject: |
danny zepeda used to sell a dual carb kit... i think it ran a pair of 28s and mushroom aircleaners (or here) for a 40horse... you might also look @ steph's 4-tip abarth repro. then, there's always the okrasa 40horse kit. i'll admit, though, i'm biased to the old-speed parts. you could likely drop in a stock 1600 for the same price. |
glandnut 40 horses of Fury
Joined: February 26, 2003 Posts: 1432 Location: J-ville, FL
Posted: Sun Nov 27, 2005 10:47 am Post subject: |
I just picked up an old Kadron single port manifold set up with the metal balance tube that ties it all together. I'm thinking of modifying it to fit the smaller diameter, flat intake ports for my 40 horse. Don't forget, the port size and angle is different for 40 horse heads versus later single port heads. Those ICT kits don't fit 40 horse. _________________ Looking for aluminum single port Kadron manifolds. |
glutamodo The Android
Joined: July 13, 2004 Posts: 26325 Location: Douglas, WY
Posted: Sun Nov 27, 2005 11:42 am Post subject: |
A stock 1192 40HP won't have much in the way of improvements from bolt on upgrades. They were designed to be small motors designed for economy instead of performance. I've tried larger main jets before, but never noticed much difference other than worse gas milage. If you put an extractor on it, going up one size in the main jet might help. Some small dual carbs would be better. A bigger single carb won't make much difference, the intake manifold is small, and the heads have small valves. And those old "bugspray" carbs they sold for 40HP are a waste, way overcarbed and not worth messing with.
All of the 40HP motors I've run have had the larger 83mm big bore kits on them, making them 1385cc in size, which helps a lot. There's been many topics devoted to hopping up the 40HP motor on here before, here's a few of them:
http://www.thesamba.com/vw/forum/viewtopic.php?t=130453
http://www.thesamba.com/vw/forum/viewtopic.php?t=123839
http://www.thesamba.com/vw/forum/viewtopic.php?t=124701
But if you aren't going to keep the 40HP, I'd just live with it the way it is now, enjoy the good gas milage, learn to drive within the car's limitations, while you save for the big motor you want to use.
andy |
crazyman_stanley Samba Member
Joined: November 01, 2005 Posts: 180 Location: Norcal
Posted: Mon Nov 28, 2005 11:42 am Post subject: |
interesting stuff...how about the same question on the 1500? what are some easy upgrades? would the dual weber setup help out alot on the 1500's as well or is there a better set up. thanks for the help |
Posted: Mon Nov 28, 2005 11:50 am Post subject: |
also would it be worth it to upgrade to dual port heads, or would it make more sense to just get a whole new engine? |
Posted: Mon Nov 28, 2005 7:48 pm Post subject: |
VWfan1069 wrote: |
That's a good idea...ream w/ a regular drill and bit? What size bit? |
Not a drill bit. You'll need to purchase a carb jet reamer kit. Just enlarge the jet to 1 or 2 sizes larger. Don't go overboard |
