zimblewinder Samba Member
Joined: January 22, 2004 Posts: 893 Location: Australia
Posted: Mon Nov 28, 2005 4:32 am Post subject: Restoring board sunvisors |
Hi all, anyone had a swing at restoring an old board sunvisor? I was going to disasemble mine to rechrome the frame and flatten and repaint the board. Anyone had any luck with this? What did you do about replacing the rivets in the frame? Hints tips and suggestions most welcome
Cheers _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Wanted- splash pan supports, og pressed bumper coach bolts, ivory blaupunkt knobs (early), armrest alloy strips, NOS door mechanism |
TeamSpatula Samba In The Rain
Posted: Mon Nov 28, 2005 9:11 am Post subject: |
Not the board itself, but those plastic pieces that mount to the body above the windshield. I've had several of those crack & break, so I had an opportunity to cast a few out of aluminum. They look sharp, and I'm sure will last a lot longer than the plastic ones.
Otherwise, the little plastic dustcap on top will come off, and you can clean up that area in there, so they will move easier & better.
But fortunately my visors themselves were in pretty good shape. _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4245 Location: between Trenton NJ. & Philly Pa.
Posted: Mon Nov 28, 2005 10:34 am Post subject: |
I have the earier ones with the metal mounting points, I don't even know if they made hardboard ones with plastic mounting points Anyway, I'm sure you can find simmilar rivits somewhere. The screw in between the 2 top rivits is what puts tension on the rod to stop it from falling down. Asfar as the hardboard goes, I don't have any good ideas on flattening them out. I was going to try soaking them in water and then press them between cinderblocks, but I really think that would ruin them. Be very careful with the frame aswell, it is very thin where the screw goes through. The frame has a dip there and the screw doesn't even go through the frame, but goes above the frame. These are the ones I redid, not original look, but more fuctionable.
_________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Mon Nov 28, 2005 11:02 am Post subject: |
would it be easier to chrome a painted frame than to dechrome and rechrome an original chrome one? the painted ones seem to be fairly common.
mintonman wrote: |
I have the earier ones with the metal mounting points, I don't even know if they made hardboard ones with plastic mounting points |
I have an early one with a plastic mounting point. it is either early-mid '61 or just a manufacturer difference. the majority of cardboard visors have metal mounting points. _________________ .
Wanted:
Posted: Mon Nov 28, 2005 12:06 pm Post subject: |
Here are a couple pic's
#1 This is the thin area of the frame I mentioned earlier.
#2 This is the different marks I found, GHE VW & RG VW.
#3 hard to see, but the broken one is a little wider & sharper on the corners & it is not as pointed at the top of the barrel either. I'm not talking about the cap, but the body itself.
Posted: Mon Nov 28, 2005 3:52 pm Post subject: |
Thanks James and Lind. Im on the look out for a nice painted one too. Thanks for the frame photos, its good to see whats under there. If anyone has any further tips on flattening the boards Id like to know your experience.
Thanks all _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Tue Nov 29, 2005 12:18 pm Post subject: |
mintonman, from what i've encountered, the ones that are marked RG-VW are early post Barndoor, Wolfsburg bus production. yeah, they are shaped slightly different than the GHE ones. The ones in my (Wolfsburg built) 56 Westfalia and my 56 Standard are both RG-VW. the ones in my 59 Westy are GHE. i'd be curious to see what some original 57-58 busses had in them. Lind? _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Lind Samba Member
Posted: Tue Nov 29, 2005 1:34 pm Post subject: |
hazetguy wrote: |
mintonman, from what i've encountered, the ones that are marked RG-VW are early post Barndoor, Wolfsburg bus production. yeah, they are shaped slightly different than the GHE ones. The ones in my (Wolfsburg built) 56 Westfalia and my 56 Standard are both RG-VW. the ones in my 59 Westy are GHE. i'd be curious to see what some original 57-58 busses had in them. Lind? |
I will check all my buses when I am at the shop next. I have a jan '56, a feb '58, and two jun '58s and an aug '60 all with orginal visors. I have a serious lack of '57 buses right now. one of the '58s has what I assume to be a dealer installed passenger side chrome visor. I also have seven or eight loose visors including one NOS grey unit that I can check for brands. I know that any beige painted visors are '59-mid '61. _________________ .
Wanted:
Posted: Tue Nov 29, 2005 1:51 pm Post subject: |
Hazetguy,
I could have sworn that when I took my others apart, there was a small nut inside the barrel holding it all together, so after reading your post I checked the RG one I have(same as the ones I took apart befor) & there is no nut inside MY BRAINS ARE FRIED That is why I thought the GHE's were older, not to mention, this one looks OLD & it's beat to hell. Thankyou for the input, I would have never check if you didn't say anything.
Here are acouple pic's, the first one will show everyone that doesn't know what we are talking about. You see the squashed metal in the center of the barrel, thats what holds it all together. I thought the RG ones had a small nut, but they DO NOT(thanks hazetguy).
The second pic is of the groove in the end of the arm that slides into the visor. There is a small dent on the backside of the metal frame of the visor. That dent rides in the groove, so if you plan to take them completely apart, you have to spred this piec pretty far apart inorder to get the rod out..............................
Posted: Tue Nov 29, 2005 2:02 pm Post subject: |
Lind,
Is the plastic one real dumb looking? Kinda big & cheap? & do you know if the og gray ones are a beige color under the gray? I have a gray one(RG VW) that looks to be original, but there are 2 spots on the visor that apears to be paint pealing off. The weird thing is, if I try to peal the gray, it feels & looks like paper. I'm thinking OG, but with layers of cardboard pealing off _________________ Hoockd on fonicks werkt for mee?
Posted: Tue Nov 29, 2005 3:56 pm Post subject: |
RG-vw in my 58 hazet. _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
Lind Samba Member
Posted: Tue Nov 29, 2005 6:17 pm Post subject: |
mintonman wrote: |
Lind,
Is the plastic one real dumb looking? Kinda big & cheap? & do you know if the og gray ones are a beige color under the gray? I have a gray one(RG VW) that looks to be original, but there are 2 spots on the visor that apears to be paint pealing off. The weird thing is, if I try to peal the gray, it feels & looks like paper. I'm thinking OG, but with layers of cardboard pealing off |
the plasic based one that I have is very similar in appearance to the metal bases. if the hardboard gets wet, it puffs up a little bit, it is just a pressed paper material. the paint is almost always cracked, even on NOS visors. _________________ .
Wanted:
twinwindows Samba Pimp
Joined: December 08, 2000 Posts: 4086 Location: So.Cal. Highland Park GFK!
Posted: Tue Nov 29, 2005 8:59 pm Post subject: |
Well since were all here, Anyone have a set of NOS or just as good Visors for a 57 deluxe hit me up! _________________ CRG
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Yeah, everyone's now doing it GFK style . . . everythinig is covert until the finished product is revealed. |
DaveM Mad Samba Scientist
Joined: June 11, 2002 Posts: 3010 Location: Dry side of Oregon
Posted: Tue Nov 29, 2005 9:09 pm Post subject: |
Lind wrote: |
<snip> the paint is almost always cracked, even on NOS visors. |
My NOS visor is perfect... no cracking. _________________ Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices. |
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Wed Nov 30, 2005 5:48 pm Post subject: |
The visors in my dad's 58 look like a hammerite type coating on the paperboard. Has anyone tried cutting some visors out of hard cardboard or panel board and painting it with a grey hammerite type paint? I think it would look close to factory, but haven't tried. |
Posted: Sat Dec 03, 2005 4:49 pm Post subject: |
Well after reading this thread I am going to go ahead and restore the set I have, Sarting with a rechrome job and trying to locate the same fiber board vw used. I found out be taking this visor apart what they used to assemble the Visor and have located the same thing, Will post pictures later when they are done.
My builds
BAD TEMPER 11
CHRISTINE
GFK LIFER!
myzamboni wrote: |
Posted: Sat Dec 03, 2005 10:49 pm Post subject: |
good good! Keep us up to date. Thanks _________________ 58Euro 23 343208 The Ultimate Zimblewinder Machine.
59 mango standard
SAMBA VAN MAN Samba Member
Joined: June 18, 2006 Posts: 146 Location: MANCHESTER ENGLAND
Posted: Mon Aug 17, 2009 9:14 am Post subject: |
mintonman wrote: |
Where did you get the visors from with the perspex centre? |
Lohe Samba Member
Joined: June 26, 2007 Posts: 662 Location: Chandler, Az
Posted: Mon Aug 17, 2009 9:23 am Post subject: |
SAMBA VAN MAN wrote: |
mintonman wrote: |
They look like stock frames with 'perspex' inserts. I would assume he went to a hardware store, bought the 'perspex' and cut them to size? |
Posted: Mon Aug 17, 2009 12:56 pm Post subject: |
Lohe wrote: |
mintonman wrote: |
I actually ordered the plexiglass online. I got 2 shades to see wich would work out best. I used a dremmil with a cut off disc to cut them out and they work pretty good, but they are starting to get alot of hairline sctratches, so it looks foggy looking through them. _________________ Hoockd on fonicks werkt for mee?
