Baja Ben Samba Member
Joined: December 17, 2004 Posts: 634 Location: riverside
Posted: Mon Feb 20, 2006 5:15 pm Post subject: |
Show off.  _________________ Baja Ben.
Why do I try to wright some sort of banter down here. It doestnt mean anything |
USMCord1 Razorback
Posted: Wed Mar 29, 2006 12:52 pm Post subject: |
Well I blew the dust off of it and finished the paint, yes same paint scheme, kinda hooked on it. the Blazer steering box, heims and rods rebuilt King and Link pins, adjusters widen beam.
Installed tree bars had a heck of a time finding the right angle pipe fitting Put 27MM torsion bars to replace the stock ones added dual carbs, moved the seats back 10 inches to add some leg room.
I like the stance of the front end, like the adjustment that I can get should handle alot better being a bit wider, now if those trees will just part like the red sea all will be ok.
alot of hooking up to do including redoing the wiring even though the other was one season old, adding oil buzzer, fused main line and new fuze box. Have to have it done by April 8th. have a ride to go on. So guys what do you think? Paybacks are a bitch huh? Come and get it!!! _________________ For a Good time |
UncleBob Grease Midget
Joined: August 21, 2002 Posts: 2862 Location: Northeast Florida
Posted: Wed Mar 29, 2006 1:02 pm Post subject: |
Looks pretty good to me. _________________ OG JHC
don't worry, the ciggaret is fake. |
USMCord1 Razorback
Posted: Wed Mar 29, 2006 2:49 pm Post subject: |
They grow bigger and closer as I move toward them but on both sides. Ya got me SHMO why do you ask, what'd I screw up? _________________ For a Good time |
Skidmark Samba Member
Joined: June 17, 2005 Posts: 2988 Location: Orange, CA
Posted: Wed Mar 29, 2006 5:52 pm Post subject: |
Cordy,
If you look at your picture it looks like the left tree bar is higher than the right... could be just the picture, 'cause I am sure you measured first...  _________________ "It's not complicated, it's just expensive!"
WARNING! This person has been consumed by the Dark Side.
www.socalbajas.com
http://i135.photobucket.com/albums/q148/bajaskidmark/SCBaja.jpg |
DeMinimis I Eat Glue
Joined: November 16, 2004 Posts: 1840 Location: Down in the pig mine
Posted: Wed Mar 29, 2006 5:55 pm Post subject: |
I guess its truly a "rat" rod. _________________ Yes Virginia, beer can make you smarter.
'78 SB CEII In Progress. |
USMCord1 Razorback
Posted: Wed Mar 29, 2006 6:34 pm Post subject: |
Skidmark wrote: |
Cordy,
If you look at your picture it looks like the left tree bar is higher than the right... could be just the picture, 'cause I am sure you measured first...  |
Yes I did but ya made me look 24 5/16ths both sides where the bars meets the hoops. Now you'll have to come to Little Sahara to check for yourselves. Come on guys put the magnifing glass to it you can do better then that. _________________ For a Good time |
takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Wed Mar 29, 2006 9:43 pm Post subject: |
about time you did some work.. the steering box doesnt look like such a monstrosity now that is all the same color. have you driven it yet? _________________ Member of the baja's that don't run club, for now!! |
USMCord1 Razorback
Posted: Wed Mar 29, 2006 9:48 pm Post subject: |
No I am now at the making engine noises sitting on the not bolted down seats stage. Can't wait to trail riding, alot of changes to the front end hopefully won't be for not! _________________ For a Good time |
USMCord1 Razorback
Posted: Thu Apr 06, 2006 3:41 pm Post subject: |
IT LIVES!!!! sorry for short post but have work still to be done. Frankenstien lives. Man I am happy! _________________ For a Good time |
bajaherbie Samba Sooner
Joined: November 27, 2003 Posts: 2985 Location: altus, oklahoma
Posted: Thu Apr 06, 2006 4:41 pm Post subject: |
when does the subaru go in? _________________ blank |
USMCord1 Razorback
Posted: Thu Apr 06, 2006 6:43 pm Post subject: |
bajaherbie wrote: |
when does the subaru go in? |
Subie will be a fall/winter project if I don't find something else to stuff it into.
Will not be in before we go to little Sahara, Ok. I have not ridden since November I am past the withdrawl stage. Can't wait till August I think that is going to be a great time. I need some time off, bad. I'll post some pics tomorrow if I get it all buttoned up and flying low.
David _________________ For a Good time |
USMCord1 Razorback
Posted: Mon Apr 17, 2006 4:33 pm Post subject: |
Well it is all together have some bugs to work out but is driveable, wanted to show you the seats. It's close qtrs but what can you expect. Will have more pics later. Oh and the Boxer on the seat that is our newest addition 3 months old getting ready to have her ears cropped. _________________ For a Good time |
SHMO Samba Member
Joined: July 29, 2004 Posts: 1647 Location: Lynden, Washington
Posted: Mon Apr 17, 2006 6:26 pm Post subject: |
Hey come on,
snap some more pics of that jalopy. Let us check it out. It looks good.
SHMO _________________ SHMO's Baja |
USMCord1 Razorback
Posted: Thu Apr 20, 2006 3:53 pm Post subject: |
Ok here are some more shots. Still have some carb work to do and a few other areas but for the most part I am pleased. And for now done!
I do like the stance with the front beam 10 inches wider.
Here is one with the blazer steering box, I am glad I did it steering is like having power steering, I don't get the jarring and bumps through the wheel and steering with one hand in corners is not a problem.
Cannot speak for R&P but it beats the stock VW steering by leaps and bounds. Which is also what it handles better.
You can look back at some of the before shots and see a difference in ride height and stance.
Did alot of changes including dual carbs instead of a progressive, electric pump, regulator, spark arrestor/muffler, electronic ignition, getting a SVDA instead of the 009 so that should help also.
Pic of the engine, yea I know big deal.
Pic of tranny and Hyd clutch
Ground clearance is pretty good and has total 4 wheel ind. suspension.
Seats and shifter, which is now in line with the hockey stick and have alot easier adjustment.
Well for now that is it, next big project is the subie engine, HMMM what to put it in? Thanks guys for all the help, advice and telling me to get busy on it. Semper FI
1FASTHOE Samba Member
Joined: December 16, 2005 Posts: 318 Location: gilbert az.
Posted: Thu Apr 20, 2006 4:31 pm Post subject: |
looking good cordy, hey just an observation, in the one pic where you show your tranny, is the breather line collaped or just the picture ? when do you break it in, i mean in a good way...  |
Jowlz The Anti-Purist
Joined: May 02, 2005 Posts: 2464 Location: Tunkhannock, PA
Posted: Thu Apr 20, 2006 4:34 pm Post subject: |
Great work. The whole thing looks great. _________________ The honey-do list put my project on hold....... |
