keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Thu Dec 01, 2005 11:47 am Post subject: 80 or 81 Auto trans info |
I am about to pick up an 80 or 81 Westfalia with a non running but free turning 2.0, FI intact and an auto trans that is said to be bad.
I did a search but did not find alot on the early automatics... quite a bit on the later models.
Does anyone have any info on years that will fit ( later model Bay's?--?)
or any source for rebuilt kits/parts etc.
Anyone know if they are similar to the 411-412 models as I have a friend who rebuilt his 412 unit and said it was really pretty easy to do.
Also what are good shape Vanagon Westies worth nowdays?
Thanks for any responses... |
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Thu Dec 01, 2005 12:04 pm Post subject: |
Early aircooled vanagons have a differant gear ratio than anything else, so you have to use a Vanagon tranny on them, but putting the tranny on a bay might work. There where autos but they are few and far between.
Both were very solid basic transmissions.
As for swapping with newer vanagons I don't think you can, I can't remember why. I'd love a 5-speed in my 81, but I've never seen it done. _________________ My Art:
http://www.instagram.com/flynn8552/ |
Posted: Thu Dec 01, 2005 12:12 pm Post subject: |
I would convert it to a manual but I think that would be alot more hassle and expense than just rebuilding or finding a good used unit out of what ever year will fit.
I am hoping someone knows what years that might be or have a contact in the industry/scrapyards that knows their shit |
Posted: Thu Dec 01, 2005 12:23 pm Post subject: |
I'd make sure the one in it is bad, very few people know about aircooled vanagons, could be something simple. They are easier to work on than late bays(room to move wise), but basicly the same setup, if your comfortable with late bays you should be able to tear right into this.
keeping it an auto is a good Idea, Air cooled Westys are about the least expensive of the lot but a very nice example can get 7-8 grand. _________________ My Art:
Posted: Thu Dec 01, 2005 12:31 pm Post subject: |
I will know more when I pick it up tomorrow or Sat and get to checking it out next week. It could be something simple like bad fluid/filter or modulator valve/hose connection etc...
I have worked on Vanagons some but not as much as Bays and I am comfortable tearing into it. Just need some info on trans and parts so I can get it going ASAP when I get it figured out.
Thanks mightyart! |
Posted: Thu Dec 01, 2005 4:53 pm Post subject: |
For Pete's sake peep's... no one has any info on auto trans years and compatibility?
Now I know what it feels like to be an impatient newbie!
CAN'T YOU GIVE ME MY ANSWERS NOW!!!!! |
sc-surfer Samba Member
Joined: May 16, 2005 Posts: 865 Location: Santa Cruz, CA
germansupplyscott Samba Member
Posted: Thu Dec 01, 2005 7:33 pm Post subject: |
the aircooled vanagon auto transmission is an 010, nearly identical to a bay auto from 75-79. the waterboxer tranny is an 090, but even it is very similar and could probably be used in a bay, the main difference is in the final drive, on the waterboxer it has a transmission oil cooler which is cooled by the engine coolant, obvioulsly not found on the aircooled vanagon. there are many interchangeable parts between any of the 3-speed automatic transmissions used in all VW's from 75- through the early 90's. _________________ SL |
Posted: Fri Dec 02, 2005 8:04 am Post subject: |
germansupplyscott wrote: |
the aircooled vanagon auto transmission is an 010, nearly identical to a bay auto from 75-79. the waterboxer tranny is an 090, but even it is very similar and could probably be used in a bay, the main difference is in the final drive, on the waterboxer it has a transmission oil cooler which is cooled by the engine coolant, obvioulsly not found on the aircooled vanagon. there are many interchangeable parts between any of the 3-speed automatic transmissions used in all VW's from 75- through the early 90's. |
Thanks a heap Scott... that is the kind of info I was looking for.
If anyone else has any other particular do's or don'ts as far as using one year over another or anything they may have run into doing a swap that would be useful info too. |
