EddyWill Samba Member
Joined: June 24, 2015 Posts: 9 Location: Pensacola, Fl
Posted: Sun Feb 19, 2017 9:15 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Cusser wrote: |
Use the pressure plate from the "shot" engine, if that one worked fine. |
Worked like a charm. _________________ Zoom Zoom!! |
z33taxi Samba Member
Joined: October 15, 2016 Posts: 119 Location: Troy, NY
Posted: Sat May 13, 2017 4:08 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I wish I saw this thread a week ago. First time owning a beetle and I have definelty learned to buy parts for the beetle you own not the beetle how it was stock. I have a 71+ engine, but the original trans. SO what did I do? Buy a 71+ clutch kit. Installed it and magically it even drove for a bit. Now I'm dropping the engine again and using the old pressure plate.
Correct PP
Incorrect:
_________________ My 1968 1600SP build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=665936 |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sat May 13, 2017 4:30 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
z33taxi wrote: |
Tips on inspecting PP? |
I'd say pretty much limited to checking the working surface, should be pretty smooth with no big grooves or burn marks. The center ring should be straight, not out of whack. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
EDragnDean Samba Member
Joined: July 13, 2005 Posts: 1148 Location: Vancouver, WA
Zundfolge1432 Samba Member
Posted: Thu May 10, 2018 12:13 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Cusser wrote: |
z33taxi wrote: |
I'd say pretty much limited to checking the working surface, should be pretty smooth with no big grooves or burn marks. The center ring should be straight, not out of whack. |
Yes I had one that was out of wack so I simply reinstall some wack and wadda ya know I’m back on the road. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Thu May 10, 2018 1:51 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
EDragnDean wrote: |
How do you remove the centering ring?
On the inside of the PP (as pictured above) the dark colored ring is a large "starlock" similar to this, but larger:
It is pressed onto the outer ring which passes thru the center of the diaphragm. Using a screwdriver, pry it off from the inside and you can then slip the outer ring off the diaphragm. _________________ AshMan40
Pogel Samba Member
Joined: November 21, 2005 Posts: 38 Location: Florida
Posted: Sat Aug 11, 2018 4:38 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Bus had no engine and the PO put in a centering sleeve but left the old clutch shaft for the bearing. I want to take off the centering sleeve and use the pressure plate style with the ring. Does the sleeve unbolt and will taking it off affect the seal? |
Pogel Samba Member
Posted: Fri Aug 17, 2018 8:03 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I found out that you can unbolt the sleeve. However I left it on and used the correct arm, throw out bearing and ring less clutch. |
Joined: May 17, 2003 Posts: 4863 Location: Harmony, PA
Posted: Wed Jan 01, 2020 9:47 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Hey Glenn, it looks like your “late” pictures are no longer showing up in the original post. |
Cusser Samba Member
Posted: Wed Jan 01, 2020 10:59 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Must be my phone then. If you look in the “quote” portion of the images, the early ones are samba gallery links, while the late ones are from Glenn’s personal site. |
DJ Pierre Samba Member
Joined: November 09, 2008 Posts: 349 Location: Netherlands
Posted: Wed Apr 29, 2020 8:27 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I did the old to new style conversion last year(CSP). I boke the clutchfork for the second time(Stage2 clutch..) so i decided to install the stronger version arm and do this upgrade. All went well and clutch was perfectly fine afterwards.
But after 1500 miles i got a massive tranny oil leak and suspect my mail shaft is leaking badly. The oil was coming from the bellhousing and the rest of the tranny is clean. It's definitly gearbox oil, it has a very distinctive smell and taste.
I suspected the sleeve to got loose, i've seen a picture of that happening. But all is well and tighty.
I'm not sure what could be the issue right now. The bellhousing was soaked with oil and i'm lucky the clutch kept working.
Only thing i can think of is the main shaft seal went bad. I think there is one inside the sleeve? I forgot what it looked liked inside. I had to order a puller to get the sleeve off so haven't looked inside just yet. Why would a seal go bad this quick??
I really want to address this before I put the engine back.. Hope someone can point me in any direction?
Cusser Samba Member
Posted: Wed Apr 29, 2020 9:05 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
You need to determine whether the leak is engine oil or fear oil from the transmission. Gear oil has a distinctive smell.
Most leaks from that area are from the crankshaft/flywheel oil seal and flywheel O-ring; oftentimes too much engine endplay is involved. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Wed Apr 29, 2020 9:45 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I was able to get the sleeve off. All looks fine to me but I will source another seal for it. Weird..
Posted: Wed Apr 29, 2020 9:49 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
Cusser wrote: |
Most leaks from that area are from the crankshaft/flywheel oil seal and flywheel O-ring; oftentimes too much engine endplay is involved. |
It's gearbox oil as i stated. No doubt about it. |
Posted: Wed Apr 29, 2020 1:13 pm Post subject: Re: Clutches - what pressure plate with what throwout bearing |
While you have the engine out, take some time to look for cracks in the transmission case there in the bell housing. Rare, but possible after decades. I'm pretty sure you could use a propane torch to warm up the case surface and look for weeping oil. Though, I've never tried it on the transmission case. _________________ AshMan40
Posted: Thu Apr 30, 2020 2:56 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I think I found my issue. The new shaft doesn't seat deep enough. The circlip didn't hold the arm in place causing it to move sideways when operating the clutch. That causes the seal to open up and leak. I will be reinstalling the system and shave some of the copper bush installed in the startermotor side to get the shaft in place properly. Right now it just wont go deeper.
Posted: Thu Apr 30, 2020 8:40 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
I think it's fixed now. The brass bearing sits quite differtent than original, quess that's is what went wrong. I can't say i like the way the arm sits right now but the spring appears to stay in place just fine. All works smooth and sits nicely centered. Should do it!
These are some mockup shots, the end result is better of couse.. I'm thinking of shimming the brass bearing and using a spacer to get it all line-up(and look) a bit better. Not pleased with this fit as is... |
revhead Samba Member
Joined: July 24, 2007 Posts: 9 Location: Adirondacks of NY
Posted: Mon May 11, 2020 6:44 am Post subject: Re: Clutches - what pressure plate with what throwout bearing |
This thread is great. So I’m going through on early 65 trans setup with a 68 engine. I owned this since 1984 but it’s been sitting since 93.
As you can see it has the old style parts and a 9 spring heavy duty pressure plate (from a bus at the time I think). This setup was great and I’d like to keep it.
While rusty the pp looks ok and springs are all still ok. Looking for specs on pp thickness as well as flywheel thickness to consider just resurfacing. Obviously the clutch disk will be replaced. Since these parts don’t mix well and I’d really like to keep the 9 spring this might be best if possible.
