mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Sat Oct 07, 2017 7:57 pm Post subject: Re: Official whine about Buses and parts for sale |
agreed, it is a cool bus. birth certificate would be nice. _________________ regards
Uli
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Posted: Sun Oct 08, 2017 7:40 am Post subject: Re: Official whine about Buses and parts for sale |
[quote="chris henry"]
tarzan271 wrote: |
chris henry wrote: |
thom wrote: |
Martenni wrote: |
What's this ?
For the record, I think the worst ones are those bolted to the fan opening on the back of the shroud |
I totally agree with you on that thom but my dad disagrees. He has had an external cooler partially blocking the fan intake on his 69 westy since the 70's . He has driven his bus to every state in the continental us. through Canada up into Alaska and as far south as the tip of Baja. it currently has almost 920k on the clock without a single problem. Hard to argue with that kind of success. I still use the stock doghouse on my motors, but it's nice to know just cause people say something work work doesn't necessarily mean it wont |
A little hard to believe that a Type 1 motor would go 920k miles without a problem. Actually, it is really hard to believe. |
the bus has 920k on it.. it's on it's 6th motor and 4th transmission. the first block made to the 3rd rebuild and when it was past second over line bore it was replaced with the current block that that is now at second over on the line bore. the fan shroud remains the original one that came new on the bus from the factory .He switched to the rear mounted oil cooler around 1975 when the factory single port gave up. he also switched to duel port heads then. The area we live in is hot. It's not uncommon to see 110 degrees in the summer but the system seems to work just fine despite all the articles posted to the contrary. the bus is like old faithfull. its has never left us stranded in 48 years of driving |
It's all got to do with how he drives, it runs a ton cooler at 55mph than 65mph. Even a poorly set up external cooler (or factory) is fine at slower speeds. If this guy ran 65-70 it would probably eat engines........ _________________ '66 Deluxe Bus
'65 Standard Bus
Build threads:
'66- http://www.leakoil.net/forum/viewtopic.php?f=23&t=2888&sid=54d8dedfb3822f99c7f2ea430cb4e856
'65- http://leakoil.net/forum/viewtopic.php?f=23&t=4263 |
Clara Samba Member
Posted: Sun Oct 08, 2017 8:39 am Post subject: Re: Official whine about Buses and parts for sale |
An oil cooler in the engine compartment means the air going into the shroud to cool the engine will have been pre-warmed by the oil cooler. With the same oil cooler outside the engine compartment the engine should run cooler than if it is in the compartment.
I have not compared them myself.
But .... Bruce's Dad wasn't comparing cooler in engine compartment to cooler outside engine compartment. He was just saying his bus runs good, and it sounds like he drives it a lot.
I don't know if he was saying it is at a better temp with
1) no oil cooler
compared to
2) cooler in the engine compartment?
I've heard people say that would make the oil cooler but the heads hotter.
The bus ran 920K on 6 motors? Each motor lasts an average of 153.3K miles? That is impressive! Or did each motor get 3 rebuilds? each sack had seven cats...
Saying it has 920K miles on the bus (not motor) w/o a problem doesn't actually mean the engine lasts longer with the cooler where it is.. but it does say he likes it there. And that it does not instantly overheat.
It is confusing, cause usually people don't replace or rebuild the motor unless there is a problem.
43K miles on my 56 westy with the same engine w/o engine problems and about 5K on that engine in the orange panel before that. I don't know how many miles a engine goes in a bus. FWIW |
chris henry Samba Member
Joined: October 28, 2004 Posts: 867 Location: porterville ,CA
Posted: Sun Oct 08, 2017 12:43 pm Post subject: Re: Official whine about Buses and parts for sale |
Clara wrote: |
1) no oil cooler
compared to
the engine is on its 6th rebuild now. my dad learned from old school builders like Jock lafonte ( scotts porsche in national city ) and Gehard assemacher ( AST) he typically runs the bus at 65 plus. he does all his own machine work. this makes a big difference. he uses quality parts, the pistons in the current engine are Kolbenshmit. german cam and lifters etc. I literally grew up in this bus so I know its history first hand. I was born it 69,the same year he bought it. My point was that as long as I can remember it has had the external oil cooler on the rear of the shroud and everyone says thats the worst place to put it but in this case it has worked just fine. |
Posted: Sun Oct 08, 2017 12:52 pm Post subject: Re: Official whine about Buses and parts for sale |
[quote="Bruce Amacker"]
tarzan271 wrote: |
thom wrote: |
Martenni wrote: |
What's this ?
It's all got to do with how he drives, it runs a ton cooler at 55mph than 65mph. Even a poorly set up external cooler (or factory) is fine at slower speeds. If this guy ran 65-70 it would probably eat engines........ |
he typically runs the bus at 65 plus bruce unless of course he is on a hill then it is slower with a stock 1600 but keep in mind this is a 69 bay not a split with reduction boxes. little higher geared. bus is taching about 3500 at 65mph |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Wed Oct 11, 2017 8:11 pm Post subject: Re: Official whine about Buses and parts for sale |
Funny, the Bosch flagmaster isn't from Canada flipping ebay window parts...? _________________
EverettB wrote: |
FU#5 |
easy e Samba Member
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Fri Oct 13, 2017 9:26 am Post subject: Re: Official whine about Buses and parts for sale |
His feedback too hurt my eyes...and head. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Fri Oct 13, 2017 10:06 am Post subject: Re: Official whine about Buses and parts for sale |
Damn Jenga. Straight went from a dog leg to a frog leg.
Someone's been playing rugbyball up against that hatch.
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51126 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Oct 13, 2017 12:34 pm Post subject: Re: Official whine about Buses and parts for sale |
Skim wrote: |
Nahhh..., that's just from pushing it, obviously it breaks down alot. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Oct 13, 2017 3:24 pm Post subject: Re: Official whine about Buses and parts for sale |
https://www.thesamba.com/vw/classifieds/detail.php...82816ec46d
After vw shut down production at the Wolfsburg plant in 56 they moved production to the CA plant to take advantage of cheap labor.. Hence the rare and coveted "CA single cab" |
obus Samba Member
Joined: March 08, 2001 Posts: 11065 Location: just off Garden State Parkway Exit 81
Wheelie Pete Samba Member
Joined: October 06, 2005 Posts: 517 Location: Detroit Rock City
Posted: Sat Oct 14, 2017 12:57 pm Post subject: Re: Official whine about Buses and parts for sale |
https://www.thesamba.com/vw/classifieds/detail.php?id=2104859
I'm not even sure what the exchange rate is these days, but there is one thing I am sure of, and that is the fact that the seller has an extra zero on the end of his price! |
Malokin Martin Samba Member
Posted: Sat Oct 14, 2017 1:22 pm Post subject: Re: Official whine about Buses and parts for sale |
Whoa... “slight damage”?! I think in dollarydoos it translates to $750 |
Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Sat Oct 14, 2017 4:34 pm Post subject: Re: Official whine about Buses and parts for sale |
Quote: |
All sheet metal underneath the windows must be replaced. |
wow.... that's a whole lot worst than lower 12"..... _________________ 1964 Turkis Flipseat |
Clara Samba Member
Posted: Sat Oct 14, 2017 10:30 pm Post subject: Re: Official whine about Buses and parts for sale |
Enkiel wrote: |
wow.... that's a whole lot worst than lower 12"..... |
It is listed as a 60, and is high hinge, but the dash and front seat stands say it is later.
Was it clipped from a 66?
adriano Samba Member
Joined: March 14, 2008 Posts: 146 Location: Iseo Lake
Posted: Sat Oct 14, 2017 10:49 pm Post subject: Re: Official whine about Buses and parts for sale |
And stop bumpers in rear suspension frame ( from 1965) |
