hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Jun 11, 2018 6:47 pm Post subject: Re: Official whine about Buses and parts for sale |
Busstom wrote: |
No seals between the bullet housings and nose panel (probably missing from headlights too)...
With the fitment of emblems (even repops) being rather simple- the gaps under this one lead me to believe beneath pigeon blue lies a field of bondo. _________________
EverettB wrote: |
FU#5 |
AlteWagen Troll
Posted: Mon Jun 11, 2018 10:27 pm Post subject: Re: Official whine about Buses and parts for sale |
hitest wrote: |
Busstom wrote: |
With the fitment of emblems (even repops) being rather simple- the gaps under this one lead me to believe beneath pigeon blue lies a field of bondo. |
Good luck adjusting the headlights with those Type I buckets in there! _________________ Grapes of Wrath $200 Engine Rebuild
Official Dual Carb Thread
Cylinder Head Quick Reference Sheet |
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1276 Location: Surprise, AZ
Posted: Tue Jun 12, 2018 7:40 am Post subject: Re: Official whine about Buses and parts for sale |
AlteWagen wrote: |
hitest wrote: |
Busstom wrote: |
Good luck adjusting the headlights with those Type I buckets in there! |
Are you talking about the adjusters' location, or are you seeing something that I'm not? That configuration, 5' and 7', is correct for the period up approx Dec '63 ('64 MY), I believe. Then again, I'm looking at this from my phone, so what makes them Type I? _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Tue Jun 12, 2018 7:44 am Post subject: Re: Official whine about Buses and parts for sale |
brand new safari windows..the best from wolfgang int.
Bwahahahahahahahaha! Stop, my sides... _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Posted: Tue Jun 12, 2018 8:21 am Post subject: Re: Official whine about Buses and parts for sale |
More on this one: https://www.thesamba.com/vw/classifieds/detail.php?id=2179195
Any one else see the lower bench mount for a humpback seat? Looks like it's a fine blend of earlier and later. So far as I know, the humpback era did not begin until October '60...~70,000 vehicles after this one.
And is it me or is there no headlight switch? Either I'm descending further towards blindness, or someone was plugging holes like a couple of pervs at a rest area bathroom. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
Posted: Tue Jun 12, 2018 8:33 am Post subject: Re: Official whine about Buses and parts for sale |
Yes on the lower hump seat mount - that is strange.
It's really hard to see but I looked at the original larger ad photo and there's a normal hole there with no headlight switch:
The gas pedal is super high here, I hope you have excellent ankle flexibility:
A lot of Buses have pedals without full travel so a nice change? _________________ How to Post Photos
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Tue Jun 12, 2018 8:54 am Post subject: Re: Official whine about Buses and parts for sale |
62DoKaGuy wrote: |
AlteWagen wrote: |
hitest wrote: |
Busstom wrote: |
Are you talking about the adjusters' location, or are you seeing something that I'm not? That configuration, 5' and 7', is correct for the period up approx Dec '63 ('64 MY), I believe. Then again, I'm looking at this from my phone, so what makes them Type I? |
The bulb is 90 degrees off from where it should be, which is a clear indicator of a bug bucket. The real difference is in the clamping ring behind the bulb. You can just bend the tabs and rotate the bulb to an upright position. You can also drill a drain hole in the bottom of the headlight ring if you want to totally turn a bug bucket into a bus bucket. If you put a bug bucket in a bus with the bulb in the stock bug location, the light pattern on the road is obviously way wrong. The builder of this bus does not have the skills necessary to put a bus on the road, and cannot fix their mistakes, even when it requires no extra parts, just a working knowledge of how to properly bodge bug parts onto a bus. _________________ .
Wanted:
Posted: Tue Jun 12, 2018 9:05 am Post subject: Re: Official whine about Buses and parts for sale |
Lind wrote: |
62DoKaGuy wrote: |
AlteWagen wrote: |
hitest wrote: |
Busstom wrote: |
The bulb is 90 degrees off from where it should be, which is a clear indicator of a bug bucket. The real difference is in the clamping ring behind the bulb. You can just bend the tabs and rotate the bulb to an upright position. You can also drill a drain hole in the bottom of the headlight ring if you want to totally turn a bug bucket into a bus bucket. If you put a bug bucket in a bus with the bulb in the stock bug location, the light pattern on the road is obviously way wrong. The builder of this bus does not have the skills necessary to put a bus on the road, and cannot fix their mistakes, even when it requires no extra parts, just a working knowledge of how to properly bodge bug parts onto a bus. |
Now that I'm on a desktop I can see the bulb orientation, etc., which I remedied on my DC years ago, until I replaced the headlight assemblies with period-correct (almost date-code exact) buckets. Hard to tell if these even have drain holes, which I doubt...another easy remedy to make a bug bucket into a more bus-correct setup...what about the running light bulb? Is that even installed, or am I [again] showing my need for a new prescription? _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
4/62 Double Cab
5/61 Panel (sold)
Malokin Martin Samba Member
exotic plants Samba Member
Joined: January 30, 2006 Posts: 298 Location: God's Zoo
Posted: Thu Jun 14, 2018 2:47 pm Post subject: Re: Official whine about Buses and parts for sale |
Too damned funny! $7.81 _________________ 1956 Beetle - Jungle Green.
Parts needed to complete:
Front driver side fender.
Rear driver side fender.
Cash waiting.
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Fri Jun 15, 2018 5:38 am Post subject: Re: Official whine about Buses and parts for sale |
https://www.thesamba.com/vw/classifieds/detail.php?id=2179948
Um, no. The "near perfect" rattle can paint isn't even good. _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
Zvonimir1985 Samba Member
Joined: August 19, 2015 Posts: 135 Location: Zagreb, Croatia
Posted: Sun Jun 17, 2018 2:28 pm Post subject: Re: Official whine about Buses and parts for sale |
Hey guys!
Where can I buy A pillars for 67 bus? Cant really find them....only for about 400$ each.
Is there a way for get it cheaper?
Thanks! _________________ Proud to be Croat! |
chris henry Samba Member
Joined: October 28, 2004 Posts: 867 Location: porterville ,CA
Posted: Sun Jun 17, 2018 9:11 pm Post subject: Re: Official whine about Buses and parts for sale |
EverettB wrote: |
Woah, that is close to or at NOS Deluxe visor territory
I bought one nicer than that and in original paint for $5 recently. |
This is odd because this seller is usually fair on his prices and delivers excellent service...At least every time I have delt with him anyway.. sure missed the mark on this one |
Posted: Sun Jun 17, 2018 10:55 pm Post subject: Re: Official whine about Buses and parts for sale |
chris henry wrote: |
EverettB wrote: |
Agree.
I took a look at other ones for sale just in case there were no "reasonable" ones right now but there are several for much, much less. _________________ How to Post Photos
Posted: Mon Jun 18, 2018 4:36 am Post subject: Re: Official whine about Buses and parts for sale |
EverettB wrote: |
EverettB wrote: |
Agree.
I took a look at other ones for sale just in case there were no "reasonable" ones right now but there are several for much, much less. |
Found one for 40 and modified it to fit my BD. But that's the cheapest I've seen. 5 bucks goes in the good deals thread! _________________ 53 Hatch Barndoor
sled Samba Member
Posted: Mon Jun 18, 2018 8:27 am Post subject: Re: Official whine about Buses and parts for sale |
this is ridiculous, and if someone actually pays anywhere near this, I feel bad for you...well maybe I don't cause its your own fault
https://www.thesamba.com/vw/classifieds/detail.php?id=2186072
_________________ drive your split. |
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Mon Jun 18, 2018 9:32 am Post subject: Re: Official whine about Buses and parts for sale |
EverettB wrote: |
Recording the price here for reference - $4000
Awesome part that could complete someone's original Bus but at that price... |
Original paint?
I can see the red over spray on the splash pans (which are supposed to be black).
Old paint, yes.
Original, not 100%.
That being said, if I had a patina bus that needed a bumper to match, I'd start negotiating, but good thing I don't need it. |
