Robw_z Samba Member
Posted: Sun Sep 09, 2012 11:01 pm Post subject: |
Pretty sure it's already mentioned in this thread somewhere, but I put on a Eurovan lighter socket I got from the junkyard and am very happy with it. Same external appearance as the Vanagon unit, except black instead of chrome trim. Same green light ring which is nice. It is deeper than the Vanagon unit and it holds much better.
-Rob |
syncroid Samba Member
Posted: Thu Sep 20, 2012 11:03 am Post subject: |
Robw_z wrote: |
-Rob |
Hey Rob, I think you mentioned that the EV unit has the same wiring plug as the vanagon. Can you confirm that? The one I bought from GOwesty is different. |
Robw_z Samba Member
Posted: Thu Sep 20, 2012 1:13 pm Post subject: |
It has been awhile but I'm almost positive you just plug it into the factory connector. I just went outside and felt behind the dash with my hand and it feels like the factory connector with no splicing involved. The Eurovan I pulled it from was a 93 or 94.
-Rob |
timichango Samba Member
Joined: April 07, 2012 Posts: 858 Location: Squamish, BC, Canada
Posted: Thu Sep 20, 2012 1:48 pm Post subject: |
Just wanted to give a +1 on the west marine style 12v socket. Mounts up easily, and it's robust. Threaded-ring-type mounting ring on the back is nice because it's easy to snug up if the socket loosens off down the road. I slathered the threads on mine with silicone caulking to help stave off any loosening-off.
I never saw this thread when I was struggling with removing the stock socket, and in the end I broke it to pieces with some pliers and chucked it in the bin with a spiteful grin. The nefarious thing really got on my nerves. _________________ . . . . . . . . . . . . . . . . . . .
Vroomhilde-San: Our 1991 Silver Vanagon Westy automatic + Subie EJ25 |
kuleinc Samba Member
Joined: August 10, 2007 Posts: 1603 Location: East Bay Area, California
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 11473 Location: Santa Cruz, CA
Posted: Thu Sep 20, 2012 9:15 pm Post subject: |
They have them, search for marinco on their website.
You can find them on ebay for less with the same search |
PAdom Samba Member
Joined: December 19, 2009 Posts: 205 Location: Wilmington NC
unclebrad Samba Member
Joined: November 05, 2014 Posts: 17 Location: Concord, CA
Posted: Wed Feb 15, 2017 7:11 pm Post subject: |
r39o wrote: |
I DID IT! I DID IT! I DID IT!
I got the cigar lighter socket out with out breaking it. Woo Hoo.....
What a MAJOR PITA it is though.
I will share with you the mystery now. You need to do as shown in the pictures that follow:
THANK YOU!!!!
That illustration showing the tabs that have to be pushed from the inside saved me countless hours of frustration! Still not the easiest of jobs, but that was the secret.
I had managed to get the whole thing halfway out, but ended up pushing it all back in and then tackling the green inner tabs.
No O-ring pliers but I used two tiny screwdrivers and got them between the green tabs and the metal body and gave it a little tweak, bending the metal, or maybe the plastic, out slightly so that the tabs could get past. Viola! the green plastic piece came free! Not as elegant as o-ring pliers (that was genius) but it did the trick.
_________________ '89 Syncro Tintop Weekender |
mbj Samba Member
Joined: February 06, 2015 Posts: 3 Location: United States
ChrisandGabrielle Samba Member
Joined: March 03, 2006 Posts: 45 Location: Planet Earth
Posted: Thu Jun 15, 2017 12:11 pm Post subject: Re: Replacing Winston's Cigarette Lighter: The Horror |
Our 91 has had a loose plug forever. I wrapped a rubber band around it several times mostly behind the green ring and it tightened right up and the gps plug is tight now. Cost: 1 bunch of broccoli for a good rubber band. |
jimf909  Samba Member
Posted: Thu Jun 15, 2017 1:13 pm Post subject: Re: Replacing Winston's Cigarette Lighter: The Horror |
ChrisandGabrielle wrote: |
Oh man, back to the grocery store for you. There are a dozen threads here showing that only asparagus rubber bands must be used. The iron absorbed by the broccoli rubber bands will cause an electrical short.
 _________________ Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
Posted: Thu Jun 15, 2017 4:19 pm Post subject: Re: Replacing Winston's Cigarette Lighter: The Horror |
Installing a west marine 12v socket in place of the stock lighter socket was one of the first things I did back in 2012 when we bought the van, along with a stereo upgrade.
Couldn't figure out how to pull the non-working stock one, so wound up basically mashing it down with some vise-grips until it was able to fit through.
Never looked back. _________________ . . . . . . . . . . . . . . . . . . .
