denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Fri Oct 19, 2012 2:00 pm Post subject: |
On my 90 westfalia (stock springs) I was quite happy with 1 turn (360 degress = 50% dialed in from full soft) on both front and back. Brake squat is still there but well controlled, and the ride quality is about right. Brake squat behaviour btw would be identical regardless of rebound setting. My goal is a balance of both handling and lots of travel to soak up the bigger hits. My typical hard right/left check (call it the evasive manoever) at 50km/h is nicely controlled and I noticed the van at speed on the highway is more stable with some fairly high winds last night.
The shocks in there were likely not stock so my frame of reference was a bit suspect in terms of what "stock" feels like.
Coming from a long history of autocrossing, the suspension feels just right. To be honest, given the high center of balance and mass, the van handles considerably better than a lot of similar vehicles I've driven. I won't be pulling 1G laterals with it like the autocross car, but my wife and kids won't be complaing either _________________ Cheers,
Dennis Wood
The Grape |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Sun Apr 27, 2014 1:38 pm Post subject: Koni Bottom Mount Moving |
Little bit of movement on the bottom mount of my Konis. Both sides.
I have not pulled them off yet to check the condition of the rubber. Has this happened to any one else?
Replacment all of the bottom with after market parts?
Or just some rubber or urathane spacers.
I thought I saw a home made metal spacer somewhere. Two of them to keep the shock body centered. Like a large washer and short tube welded together. Thanks _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Sun Apr 27, 2014 2:40 pm Post subject: |
Mine did that, too. Its not hurting anything to be slightly off centre like that.
I don't think its anything to worry about - the shock absorber migrates over to a place that equalizes/centres the lateral pressures and settles in happily. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
singletrackrod Samba Member
Joined: January 14, 2011 Posts: 77 Location: Southern Oregon Coast
Posted: Mon May 19, 2014 9:34 am Post subject: Should you consider Koni's? |
I've owned my "87 Westy since it was new. 2WD, full camper, stock springs, 225/55 16's on 7.5 x 16 wheels.
Over the years I have added parts and played with lots of different mods. This weekend I installed a set of Koni Classic "Red" shocks - hey they were on sale from the Koni site. I can't remember another modification that so improved the character of my bus. The Konis replaced a set of regular (not HD) bilsteins. night and day difference. Maybe the best $400 I have yet spent. |
Mark70baja Samba Member
Joined: August 13, 2008 Posts: 152 Location: Heron, MT
ame Samba Member
Joined: March 19, 2007 Posts: 18 Location: Langley, B.C.
Posted: Wed Jul 15, 2015 8:43 pm Post subject: |
Just bought a 2WD Doka and want to lower it. Is the Dokas suspension the same as a vanagon? Was hoping to go with Weitec springs and koni shocks.
Thanks. |
Kombi///M3 Samba Member
Joined: March 16, 2011 Posts: 427 Location: Vancouver, BC
Posted: Wed Jul 15, 2015 9:07 pm Post subject: |
ame wrote: |
Thanks. |
Pretty sure their the same.. I had an 85 tintop that I installed
Koni and weitech combo.. Great handling and big diff of course.
I have the konis and h&r blue springs in my Wolfsburg. It's great too.
ame Samba Member
Posted: Wed Jul 15, 2015 9:15 pm Post subject: |
Thanks for the reply. Your van looks great. What size are your wheels and tires? |
Posted: Wed Jul 15, 2015 10:07 pm Post subject: |
Thanks..wheels are 15", I have to check my tires.. Can't remember. |
pdxleaf Samba Member
Joined: January 14, 2014 Posts: 43 Location: Portland, Oregon
Posted: Sun Jul 19, 2015 5:55 pm Post subject: lowering DOKA |
ame wrote: |
Thanks. |
I had Weitecs with Bilsteins in a 2wd Doka. Very stiff. Coming out of Seattle on I5 I was bouncing in the air like a low rider. Too stiff and couldn't respond in time. I like the lowered look but would go with Carat springs and Konis myself based on comments from others and on my experience. But the Weitec with koni might be a better combo than what I experienced. Just a thought.
And to your original question, the 2wd Doka setup will be the same as the Vanagon GL. |
oldhuldy67 Samba Member
Joined: November 25, 2008 Posts: 506 Location: somewhere with a southern exposure
Posted: Sun Jul 19, 2015 6:06 pm Post subject: |
Stock 2WD 1980 Westy...Replaced my OG 33 year old shocks with Konis and guess what..it drove and handled so much better...duh..
I set them on their softest setting and the plan is to stiffen them up as needed.
Also, tires...Vanco D rated _________________ Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
1967 stock Sunroof Beetle
Formerly:
1978 Westy Campmobile, the"EM50 Urban Assault Vehicle" code named "The Pickle"
1973 Squareback (sold on a lark)
1973 Super Beetle (crashed..walked away without a scratch)
1972 Standard Beetle (lost in a relationship..)
1966 Beetle (the Black Beauty, my Dad's)
1964 Beetle (the Beige Bug, my beginning beater, also my Dad's) Thanks, Dad. |
Posted: Sun Jul 19, 2015 9:47 pm Post subject: |
oldhuldy67 wrote: |
I set them on their softest setting and the plan is to stiffen them up as needed. |
The adjustment on the Koni's is for the rebound only. Not for the compression. _________________
TheAndante wrote: |
70 KG Coup
Posted: Mon Jul 20, 2015 11:45 am Post subject: |
Riiiiiight...learn something everyday if I'm not careful...thanks _________________ Currently:1980 Westy Westfalia Poptop (a total stock-look rebuild with all my favorite camping mods)
Formerly:
Formerly:
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3414 Location: OR & CA (Oregon/California)
Posted: Mon Jul 20, 2015 1:31 pm Post subject: |
I have the Koni Classic Red on my '90 Carat w. highest setting and I like them...
my other '90 Carat has Bilstein HD they are good but I feel they're a bit soft to my liking...
well... you need to adjust to your taste... but the Koni Red are not easy to adjust once they are on the van... |
ChristophtheGerman Samba Member
Posted: Tue Mar 21, 2017 8:02 am Post subject: Re: Koni shocks |
Hey guys,
quick off topic question:
Do the Konis come with the upper rubber bushings and nuts for the front shocks?
Mine are shot and I need new ones.
If not - where do I get those best?
Thanks for your help.
Are there yellow and red Konis??? This is how I know them from my other cars. Red was gas, Yellow oil.
Thanks
Best
Christoph |
eeebee Samba Member
Posted: Tue Mar 21, 2017 5:22 pm Post subject: Re: Koni shocks |
They come with the nut but not the bushing. Bushing and washer is available from van cafe. _________________ Eric
1987 Vanagon Wolfsburg Special Edition
GoWesty 2.3
Democracy is the recurrent suspicion that more than half of the people are right more than half of the time. |
Posted: Wed Mar 22, 2017 7:18 am Post subject: Re: Koni shocks |
Okay, thank you very much!!! |
takeiteasy Samba Member
Joined: August 11, 2016 Posts: 169 Location: New York, NY
Posted: Mon Apr 24, 2017 6:55 pm Post subject: Re: Koni shocks |
I am about to install koni reds and gowesty 0 lift on the rear of and '85 weekender. Anybody have a koni setting they like on their weekender? _________________ '85 Weekender 1.9L
"With your past and your future precisely divided.
Am I at that moment? I haven't decided." |
ThankYouJerry Samba Member
Joined: September 01, 2012 Posts: 2271 Location: Shakedown Street
Posted: Sun Mar 18, 2018 8:11 pm Post subject: Re: Koni shocks |
takeiteasy wrote: |
I am about to install koni reds and gowesty 0 lift on the rear of and '85 weekender. Anybody have a koni setting they like on their weekender? |
Bump _________________ 1990 Multivan - "Ohana"
1.8T, Auto w/3.27 R&P + Peloquin TBD |
