orangebug60guy Twin #1
Joined: June 28, 2003 Posts: 1516 Location: South Hadley Mass
Posted: Tue Jan 17, 2006 8:21 am Post subject: jack it up! |
how do i want to put the bus on jack stands? i know i can up two on the front beam but where should i put the two rear ones? on the rear axels? and how can i jack up the whole rear of the bus without using 2 jacks? _________________ Arachibutyrophobia- Fear of peanut butter sticking to the roof of the mouth.
Coprastasophobia- Fear of constipation. |
Stocknazi Samba Member
Posted: Tue Jan 17, 2006 8:31 am Post subject: |
you want to put your jackstands on the rear torsion bar tube. on either side. if you have only one jack you can put a large , thick board accross the underside of the rear frame, in front of the tube, and jack it up. be sure to block the front wheels _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
ronnie Samba Member
Joined: May 01, 2002 Posts: 1053 Location: lost somewhere between the earth and my home.
Posted: Tue Jan 17, 2006 8:57 am Post subject: |
i use a high lift suv jack and just jack it up close to the center of the torsion tube, and place the stands as stated above. i've never used more than one jack. you're not talking about a stock jack are you? |
Lind Samba Member
Joined: November 06, 2000 Posts: 9916 Location: idaho
Posted: Tue Jan 17, 2006 10:06 am Post subject: |
first, sweep up your floor.
then, jack up the back of the bus first with a good floor jack and put the jack stands on the torsion tube. then jack up the front of the bus from the front making sure that your jack actually rolls on the garage floor as it lifts (otherwise, it can pull the bus off of the jackstands.) then put one jackstand anywhere on the front beam. (you can put two jackstands in the front, but the beam will only sit down on one of them and the other will have no weight on it.) then when you are taking it down, take the front down first and then the back. don't take shortcuts. make sure that you use a decent floor jack, because a cheap little one will not lift your bus high enough to get the wheels off of the ground. if you don't have a real floor jack, then save your money and get real tools before working on your bus. _________________ .
Wanted:
