bljones Resident Wit
Joined: February 08, 2002 Posts: 2377 Location: ontario canada
Posted: Wed Jan 18, 2006 9:03 am Post subject: Wasserboxer "big bore" question |
It's good news/bad news time for my 86 syncro. The bad news is I have a head gasket leak. The good news is this gives me a legitimate reason to tear into the top end. The bad news is I am probably going to need new heads. The good news is it gives me a chance to do some other work. So i got to thinking...
Anybody have any experience with 2.2 l "big bore" slip-ins? Since the heads will be off, i figure i might as well take the next step, if it is worth taking. _________________ OG JHC
Author of Original Rant #1
"It stingd itself to dead... now that is control on you"
2% |
r39o Samba Polizei
Posted: Wed Jan 18, 2006 10:07 am Post subject: |
Who supplies those? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
r39o Samba Polizei
Posted: Wed Jan 18, 2006 10:28 am Post subject: |
$300 translates to cheap Taiwan crap. Most likely, the same as the $150 standard sets. You can not seriously believe you can get a quality set of custom jugs and pistons for only $300, do you?
Plus what compression ratio do you end up with?
Sounds fishy to me. I think I would pass and buy a set of quality pistons and have my jugs bored.
"You get what you pay for." _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Phil G Samba Member
Posted: Wed Jan 18, 2006 9:12 pm Post subject: |
Just a few thoughts, not a debate . . .
It might be worth researching. I only paid about that for a beautiful set for a Syncro motor I freshened up a few years ago. And before Taiwan gets axed out-of-hand, they have actually manufactured some very nice stuff when well managed. They aren't in the business of casting novelty rubber dog shit anymore. We have a lot of nice 316 stainless marine fittings cast for us over there. The guy we get our Porsche cylinders from has state-of-the-art operations in San Francisco and Shanghai. That's who I got my last WBX barrels from. Makes some really nice stuff.
Basic good quality casting and machining is a no-brainer in most parts of the world these days. But with heads it's a bit different. Add bronze, spring steel, hardening processes, and moving parts, then suddenly a few sources are good (if you're lucky) and the rest crap.
If you get heads and have a headwork guy discard the valves, springs and guides for Manley's, you'll spend a few hundred more but come out ahead in the long run.
Again, just my thoughts on the subject.
Oh, and R39o makes a good point - compression ratio. Do your research on that.
But maybe the central point here should first be that of design before getting to the quality issue. The manufacturer of the cylinders has to get that increased volume from somewhere. If they are 'drop in', doesn’t that mean you are buying cylinders with a thinner wall? No bueno, senior.
Don't go this route. If you've torn down that much of your motor, spend another few hours splitting the case and sending the halves out to be machined for larger O/D barrels, and mill the heads accordingly. You can deal with compression adjustments at this stage.
. . . . . Oh go ahead and get a longer stroke crank and nice rods while you're at it, who's gonna know? |
r39o Samba Polizei
Posted: Wed Jan 18, 2006 9:29 pm Post subject: |
We've had reproduction parts made in Taiwan. Some excellent and some that do weird things down the road. FOr something as important as pistons and cylinders, I would not want to trust myself to gamble on them. I just don't have the time for such games. Do you want to be a long way from home on a vacation and have the engine crap because you cheaped out on something as vital as those? Not I. It makes no sense. There are no savings there.
Then again, you may get lucky. Who knows?
I'll state it again:
wbx Samba Member
Joined: April 11, 2005 Posts: 1254 Location: Monterey, CA
Posted: Thu Jan 19, 2006 4:13 am Post subject: |
r39o wrote: |
"You get what you pay for." |
Read the GoWesty site for discussions on these pistons... you will end up with a lot of deck height now (pin is 1mm higher than before). I have used them, and the pistons were fine... one of the cylinders was *slightly* out of round. Personally, i don't think you will see any noticeable performance increase with these. People who were using them in the past were feeling like their vans were a little faster, but i think it was because the original AAA pistons increased the CR a bit.
Anyway, just some feedback. There are a lot of them out on the road with no problems, though. I would also pass on these. |
Posted: Sat Jan 21, 2006 4:21 pm Post subject: |
Thanks for the responses.
r39o, I used to think the same way about chinese manufacturing, but now they scare the hell out of me. Their quality improvement curve is off the charts; chinese foundries and machine shops are legitimately becoming world class manufacturers. Chinese auto parts companies are far ahead of where they were a half decade ago, quality wise, and are showing a discomfitting willingness to provide what their western customers demand, quickly and cheaply. Remember what a joke we all thought japanese cars were forty years ago?
You are absolutely right about getting what you pay for. fast, cheap, reliable...pick two. That is why i ask my esteemed colleagues for their input.
Phil, i am waiting for cylinder specs- i am generally not a fan of air-cooled slip-ins, and i want to find out what the metallurgy and wall spec is, to see what the potential downside is.
WBX, i read the gowesty! info, and have decided to do some further research, because their info seems a little contradictory. In one paragraph, the author disses the dish as being too small, causing unacceptably high compression, then further on a piston comparison is cited, with different dish displacement quoted, which would dramatically alter the CR.
At a glance, the gains do not seem to offset the losses, but with the wind howling and the snow flying outside, this is a good time of year to sit at my desk and do some blue sky engineering.
I'd like to be able to wring better than 100 hp out of the engine without breaking the bank. Time to think about improving the head flow. _________________ OG JHC
2% |
r39o Samba Polizei
Posted: Sat Jan 21, 2006 8:09 pm Post subject: |
bljones wrote: |
I'd like to be able to wring better than 100 hp out of the engine without breaking the bank. Time to think about improving the head flow. |
Ditto. I am thinking about 2.3 litters. 94x82(stroker)? GoWesty overbores seasoned barrels. Is that good? Needs cooling. Some one I met stuck their A/C condensor under the van and got 20 degrees better cooling. Lots of tricks it seems. I do not really care to become an expert at every damn car I have, but in order not to make mistakes, I guess I have to be very knowledgable. I read over in the shoptalk formums that outside of Germany, the wbx is not tuned much. With all the air cooled parts out there, you have to expect a good deal of cross over. They also noted all discussion is in German. Thankfully, I am a card carrying citizen of the Vaterland, so I just have to look and figger out where to read. I do NOT want Oetteinger (Okrassa) pricing though. What a balancing act. I do know that speed (power) costs rectangular dollars the more dollars the faster you go. How fast do you want to go? _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
Ericthenorse Samba Member
Joined: October 03, 2004 Posts: 782 Location: Los Osos CA.
Posted: Sun Jan 22, 2006 12:46 am Post subject: |
I believe the saying is "Cubic inches costs cubic dollars..." I believe that Gowesty was using overboared cylinderss in the begining, but now are having custom cylinders made...Nice thick walls.... _________________ '69 bug--rusty as hell
'91 vanagon carrat-slammed,5 speed,4 wheel disks,17x8.5's |
