Save your Door panels!
Bub
Bub is offline
PostPosted: Thu Jan 19, 2006 10:35 am    Post subject: Save your Door panels! Reply with quote
Probably a no-brainer, but you get in a hurry had to rip that window regulator out and put it back in. Didn't have time to get a proper door seal on between the panel and the outside elements. Well, you door panel will go right to hell the 1st time it rains, I promise.
If your panels are aftermarket TMI or some crap like that they'll warp right before your eyes and start to disintegtrate, original panels are sturdier.
Simple solution for $7. And its easy.
A little bead of glue (I used spray adhesive) around the door and apply the weather=proof clear plastic available at any hardware store. Use a hair dryer to tighten it up.
And it has a great "R" value = good insulation.
Just thought I'd pass it along.
Bob O
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
jtauxe Premium Member
jtauxe is offline
PostPosted: Thu Jan 19, 2006 2:28 pm    Post subject: Reply with quote
Good suggestion. Also - if you have speakers in your doors, leave enough slack in the plastic to protect them, too.
John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus
, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
VWBusrepairman
VWBusrepairman is offline
PostPosted: Thu Jan 19, 2006 2:36 pm    Post subject: Reply with quote
There are plastic enclosures also to protect the speaker and enhance sound quality which fit inside the door. Razz
Amskeptic
Amskeptic is offline
PostPosted: Thu Jan 19, 2006 3:45 pm    Post subject: Re: Save your Door panels! Reply with quote
Nice bus Bub. I like the way the paint is continuous from outside to inside.
I have the TMI Disappearing Door Panels Just Add Water, and did a 3 mil vapor barrier and I used a can of silicone shoe leather protectant spray on the back of the panel itself. Panel still wants to disintegrate just thinking about rain.
Colin
www.itinerant-air-cooled.com
