Bredmon98 Samba Member
Joined: September 10, 2014 Posts: 21 Location: Buda, TX
Posted: Sat Jan 14, 2017 8:51 am Post subject: Re: Cylinder head removal/stuck cylinder sleeve |
Hi all, I know I'm about 12 years late responding to this, but I ran into the same problem while attempting to do my first waterboxer rebuild. If you cannot pry the sleeves off when you first take off the heads, don't bother pulling and prying on those ears and risking knicking your head gasket surface. Here's what you do:
Take off the heads with the stuck sleeves. Preheat your oven to 250 degrees F. Bake the head for 30 minutes. When you take it back out, throw ice in the cylinders and bang on it with a deadblow hammer. THEY WILL COME OUT, I PROMISE.
Cheers,
-- Brent |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sat Mar 18, 2017 11:54 am Post subject: Re: Cylinder head removal/stuck cylinder sleeve |
Ixnay on what I said! If you're going to bake your heads, bake them at like 190 degrees F (aka: operating temp) I baked mine too hot and they CRACKED! Doh! Set me back about $1000 |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Mar 18, 2017 12:10 pm Post subject: Re: Cylinder head removal/stuck cylinder sleeve |
Ouch! Very, very kind of you to check back in and update that. Thanks.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
bobhill8 Samba Member
Posted: Tue Feb 05, 2019 5:57 pm Post subject: Re: Cylinder head removal/stuck cylinder sleeve |
I've been working on this the last few days. I had one cylinder sleeve stuck to each head, and one that was free almost immediately. I had the advantage of time, and kept spraying them with PBlaster, while prying, twisting, tapping,etc several times a day. As is often the case, patience and determination paid off.
Then I was able to replace the lower cylinder o rings without removing the cylinder sleeves, following the suggestions of the BenPlace video:
http://benplace.com/pistons_heads_video.htm
kirtfitzpatrick Samba Member
Joined: July 12, 2014 Posts: 55 Location: San Francisco, CA
Posted: Sat Sep 26, 2020 7:55 am Post subject: Re: Cylinder head removal/stuck cylinder sleeve |
I came up with this trick after three days of trying everything to get a stuck cylinder off the head. Worked a treat. Cylinder popped off like it was nothing and it protects the head at the same time.
Two flathead screw drivers, one big, one normal, at right angles. Use the small one as a fulcrum for the big one as close to the cylinder tab as you can get it. It increases the leverage 3x to 5x compared to a pry bar or using the edge of the head as a fulcrum.
I made a video on how to do it too:
_________________ @tintopcamper
YouTube |
iliketowalk Samba Member
Joined: April 29, 2011 Posts: 614 Location: Northern CA
Posted: Sat Sep 26, 2020 9:30 pm Post subject: Re: Cylinder head removal/stuck cylinder sleeve |
Great video -- thanks for sharing / contributing that! _________________ 1986 Weekender "Birch" |
