Chevy Guy with a Baja
Page: 1, 2, 3 ... 19, 20, 21  Next
CopperBaja
CopperBaja is offline
PostPosted: Thu Jan 19, 2006 6:06 pm    Post subject: Chevy Guy with a Baja Reply with quote
I started my install today. Here's the mess that I had to start with.
After pulling everthing I was left with this....
And this:
QUESTION: Anyone need a stock wiring harness? Are they worth anything?
Look at my for sale ads. Cool
68 Baja on STFU
68 Baja on Samba
CopperBaja
PostPosted: Thu Jan 19, 2006 6:08 pm    Post subject: Reply with quote
After a bit of cleanup and some Rustoleum....
Much better looking, don't you think? Very Happy
Here's from a distance....
68 Baja on STFU
68 Baja on Samba
Baja Ben
Baja Ben is offline
PostPosted: Thu Jan 19, 2006 6:13 pm    Post subject: Reply with quote
wow. that looks 100% better. now hit the gas tank. you can allways tell the real men from the boys by their attchen to detail, espicialy with wireing. a good clean wireing job says wonders about the build
Baja Ben.
Why do I try to wright some sort of banter down here. It doestnt mean anything
CopperBaja
PostPosted: Thu Jan 19, 2006 6:20 pm    Post subject: Reply with quote
I was thinking of that...was going to start another thread, but since the subject came up....
Should I have the tank cleaned out? What is the best way to clean it?
Oh....and what are the 2 sets of wires running across the tank? I can't see where they goto.
68 Baja on STFU
68 Baja on Samba
Baja Ben
Baja Ben is offline
PostPosted: Thu Jan 19, 2006 6:23 pm    Post subject: Reply with quote
I would think your wire wheel there would do the job just fine. hot vw's did an artical about gas tank refurbishing but they went way over board if you ask me. hot tank and the whole nine yards. but just sanding and wire wheeling should be just fine i would think. that is what i did and never looked better. but again that back paint looks really good.
Baja Ben
Baja Ben.
Jowlz
The Anti-Purist
Jowlz is offline
PostPosted: Thu Jan 19, 2006 6:28 pm    Post subject: Reply with quote
cleaning the gas tank is a good idea. There are a few ways to do it. Por-15 makes a kit to do it. There is an old fashioned way. Empty tank. Fill with water. Drain till empty. Put a few handfulls of pea gravel in the tank. Add some kerosene. not alot. Shake the tank with the gravel for a while. In all directions. Empty tank. Flush with water. Repeat until all signs of contanimation are gone. Reinstall.
The honey-do list put my project on hold.......
Baja Ben
Baja Ben is offline
PostPosted: Thu Jan 19, 2006 6:32 pm    Post subject: Reply with quote
oh. cool. I wasnt thinking about the inside but that is a really cool way to clean it out. Smile
Baja Ben.
CopperBaja
PostPosted: Thu Jan 19, 2006 6:42 pm    Post subject: Reply with quote
Thanks Jowlz!
Think I'll try that this weekend.
It's dark now, but I'm going to go ahead and pull the tank.....how I get sidetracked!!! Laughing
Clean up the trunk, then when it's nice and bright daylight tomorrow, back to the rewire! Cool
Seen that one of the wires is still the turn signal/headlight....not sure where the other goes....looks like under the tank.
68 Baja on STFU
68 Baja on Samba
Kosmicride
Kosmicride is offline
PostPosted: Fri Jan 20, 2006 8:12 am    Post subject: Reply with quote
they are probably your brake switch wires for your brake lights
Pay Up sooka!
If it don't make $dollars$ it don't make $sense$
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger Classifieds Feedback
CopperBaja
PostPosted: Fri Jan 20, 2006 10:18 pm    Post subject: Reply with quote
Yeah. Sorry, but forgot to post after I pulled the tank...
They are the brake wires. Thanks! I wasn't able to work on the bug today....had some dental work done earlier and I've been down all day.
This is my first bug and I was amazed at the braking system. What kind of system? Gravity fed?
Are there aftermarket brake lines? The stock ones don't look very strong. Is the only option to swap to hydraulic?
Plan on sanding and panting the tank tomorrow.
68 Baja on STFU
68 Baja on Samba
Jowlz
The Anti-Purist
Jowlz is offline
PostPosted: Fri Jan 20, 2006 10:25 pm    Post subject: Reply with quote
The VW brake system is pretty basic hydraulic. Upgrading to stainless lines might have a little noticable effect. On higher performance cars with bigger brakes the difference is small but noticable. The pedal feels firmer and the brakes work better. This is because the stainless lines dont expand like rubber. The bigger benefit in an off-road car...is a stray object...like a rock would be less likely to end your day. On off road cars I also like to see the later dual res. m/c's. If you lose either the fronts or the rears the other set still works.
CopperBaja
PostPosted: Sun Jan 22, 2006 1:23 pm    Post subject: Reply with quote
There's a billet reservoir in JC Whitney.
Will this work on the Type 1 application?
http://www.jcwhitney.com/autoparts/Product/tf-Brow...30/c-10110
And then some stainless lines? Or are the zinc-plated good enough? (1/2 the price)
http://www.jcwhitney.com/autoparts/ProductBrowse/r...se/s-10101
68 Baja on STFU
68 Baja on Samba
CopperBaja
PostPosted: Sun Jan 22, 2006 1:34 pm    Post subject: Reply with quote
Here's the kit:
No, unfortunately the beer is not included in the kit.... Laughing
And here is my progress so far:
68 Baja on STFU
68 Baja on Samba
(183)Beast
(183)Beast is offline
PostPosted: Sun Jan 22, 2006 5:12 pm    Post subject: Reply with quote
I have done the old fashioned way and it works great. Specially if your on a budget.
An unfinished SandRail and a Baja occupy my time.
1835 with Dual Kadrons, 1 5/8 Tri-Mill and a C-35 Cam//Hopefully a Turbo is soon to come with a Stroker Crank.
subybaja
subybaja is offline
PostPosted: Mon Jan 23, 2006 12:56 am    Post subject: Reply with quote
I was told to use the white crushed quartz that you can get for aquariums...sharper than regular gravel. Also, muriatic acid inside, to get any rust the gravel misses.
I haven't tried this yet, but I guess you better wash that acid out well!
CopperBaja
PostPosted: Mon Jan 23, 2006 1:17 pm    Post subject: First Problem Reply with quote
I ran into a possible first problem.
The wires they use route directly from the fuse box to the alternator.
They don't mention anything about a voltage regulator. I can only assume that I need to keep the voltage regulator in the circuit, right?
I think I may have to get some new connections, since they were part of the wiring harness.
68 Baja on STFU
68 Baja on Samba
DesertBob
DesertBob is offline
PostPosted: Mon Jan 23, 2006 1:36 pm    Post subject: Reply with quote
Don't most alternators have built-in regulators? I know my Bosch does and my Motorola did.
All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around.
CopperBaja
PostPosted: Mon Jan 23, 2006 1:54 pm    Post subject: Reply with quote
I don't know.... If so, how could I tell?
There's a 3 prong connection and a stud connection.
68 Baja on STFU
68 Baja on Samba
DesertBob
PostPosted: Mon Jan 23, 2006 2:09 pm    Post subject: Reply with quote
Sounds like my old Motorola. Is the 3 prong connector in a white cover?
If so, you don't need a voltage regulator.
CopperBaja
PostPosted: Mon Jan 23, 2006 2:28 pm    Post subject: Reply with quote
I'm currently at work. Here's the closest pic I have with me:
If I don't need the regulator, then I can forge on through!
My other option is to buy a higher output/ more efficient, so I can run a stereo and CB and lights.
68 Baja on STFU
68 Baja on Samba
Page 1 of 21
