Skidmark Samba Member
Joined: June 17, 2005 Posts: 2988 Location: Minden, NV
CopperBaja Samba Member
Joined: March 29, 2005 Posts: 1725 Location: Santucky, CA LaJolla of EastCounty
Posted: Mon Jan 23, 2006 8:40 pm Post subject: |
Thanks skidmark!
My bud said that the 3 prong connection is
-exciter
-ground
-hot....I think...don't remember the 3rd.
Which goes to the Alt/Gen Light, then to the fuseblock?
I know the one on the post goes to the starter.....
Jeff _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Mon Jan 23, 2006 9:49 pm Post subject: |
***Copied and pasted from another web site***
Alternator Wiring
If you are replacing an alternator which uses an external voltage regulator (mounted under the rear seat) with an alternator having an internal voltage regulator, do the following:
Remove the small blue wire and the small green wire from the regulator (terminals (61) and (DF) respectively).
Cut off the push-on connectors from these wires and connect them together using a "butt" connector.
Connect the small green wire to the (D+) terminal on the alternator.
Remove the two large red wires from the (B+) terminal of the regulator. Cut off the push on connectors from these wires and splice them together with the red wire that WAS on the D+ terminal on the old generator using a "butt" connector. These two wires carry up to 50 amps to the battery, so the new connector MUST be big enough to handle that current.
Connect the red wire that was on the D+ teminal of the generator to the B+ terminal on the new alternator.
Reconnect the large red wire or a new 10-gauge red wire from the (B+) terminal on the alternator to the "30" terminal on the starter solenoid.
Note: Do not run the alternator without being connected properly from the (B+) terminal to the positive battery terminal. This can cause damage to the alternator!
Reconnect the cable to the negative terminal on the battery.
The (D+) terminal on the alternator must be connected to a working "Alt" light in the instrument cluster.
Note: A failed bulb will cause the alternator not to charge.
Check to make sure this bulb is working by turning on the ignition key (do not activate the starter motor!) If the "Alt" light in the instrument cluster comes on, the bulb is working and the alternator is grounded. _________________ "It's not complicated, it's just expensive!"
WARNING! This person has been consumed by the Dark Side.
www.socalbajas.com
http://i135.photobucket.com/albums/q148/bajaskidmark/SCBaja.jpg |
Posted: Tue Jan 24, 2006 1:52 pm Post subject: |
Thanks!
That explains the kit's design!
So, how do I know if the alternator has an internal voltage regulator or not? _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Tue Jan 24, 2006 5:59 pm Post subject: |
Does your alternator have a white ceramic box looking thing on it? That is the voltage regulator portion... I haven't seen any VW aftermarket alternators with external voltage regulators. But then again, I can't claim to have seen everything. Hook it up like this explains, turn it on, and check for smoke!!!! _________________ "It's not complicated, it's just expensive!"
www.socalbajas.com
Posted: Thu Jan 26, 2006 12:31 pm Post subject: |
It's in a white cover...
Does that mean it has one?
Which prong do I connect to?
I really don't want to fry everything when I'm completed. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Thu Jan 26, 2006 12:48 pm Post subject: |
You do not have an internally regulated Alt. There's gotta be a regulator somewhere, unless you're putting this engine in this particular car for the first time. Usually they're under the back seat, driver's side. _________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote: |
I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
Posted: Thu Jan 26, 2006 1:10 pm Post subject: |
I'm installing a wiring kit that doesn't use an external regulator.
So if this one isn't internal, that means I need to buy one with an internal regulator. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Thu Jan 26, 2006 1:11 pm Post subject: |
DesertBob wrote: |
Sounds like my old Motorola. Is the 3 prong connector in a white cover? If so, you don't need a voltage regulator. |
Is that the white cover you were speaking of? _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Thu Jan 26, 2006 1:35 pm Post subject: |
CopperBaja wrote: |
So if this one isn't internal, that means I need to buy one with an internal regulator. |
Where did this Alt. come from?
And just because you're putting in a wiring kit that doesn't have the provision for an external Reg. doesn't mean you can't add them yourself. _________________ Andy
bill may wrote: |
Posted: Thu Jan 26, 2006 1:39 pm Post subject: |
It's in my bug. The first page shows a pic. I have a 68 bug. The motor (according to the case number) is a 73+.
If I can delete the regulator, I would like to. Less=simpler.
Plus the kit comes with a diagram that I will refer to in the future. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Thu Jan 26, 2006 1:47 pm Post subject: |
It's like pulling teeth, and I'm not a dentist.
Good luck. _________________ Andy
bill may wrote: |
Posted: Thu Jan 26, 2006 1:57 pm Post subject: |
No. It's pretty simple:
1) I don't want the voltage regulator in the circuit. So, if I can delete it from the current setup, by purchasing an alternator with an internal regulator, then that is the direction that I want to go.
2) I'm not restoring to stock and I would like to keep it as simple as possible. I'm looking for info on the path I wish to take. (no external regulator)
DesertBob mentioned a white housing=internal regulator. I can only assume this is the housing he mentioned, but maybe not....I don't know. = which is why I'm asking questions.
Bottom Line: If this alternator has an internal regulator, I keep it. If it doesn't I go to (INSERT PARTS STORE HERE) and get one.
Thank you for your help and your wish of luck,Jeckler....and no thank you for your comment. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
DesertBob Samba Member
Joined: February 09, 2004 Posts: 1245 Location: Goodlettsville, Tennessee
Posted: Thu Jan 26, 2006 2:02 pm Post subject: |
CopperBaja wrote: |
DesertBob wrote: |
Is that the white cover you were speaking of? |
Nope. Mine was a large rectangular one. The cover was in fact the regulator. _________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
74 Super Beetle (German Look Project)
Full Flow 1776 with 36 Dells, 4 wheel drilled and slotted disc brakes, Porsche 7x17 Turbo Twists, Topline Maxx Struts, Camber kit, 7/8" Front Sway bar, Rear Sway bar, Urethane bushings all around. |
Posted: Thu Jan 26, 2006 2:49 pm Post subject: |
DesertBob wrote: |
Nope. Mine was a large rectangular one. The cover was in fact the regulator. |
Thanks! I'll check with Autozone and see what options they have.
Any recommendations? _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Thu Jan 26, 2006 3:09 pm Post subject: |
Kustom1Warehouse was the cheapest when I bought my Bosch late last year. Autozone will be really expensive. _________________ All it takes is a little imagination, some mechanical ability, and neighbors who mind their own business
Posted: Sun Jan 29, 2006 2:45 pm Post subject: |
DesertBob wrote: |
Kustom1Warehouse was the cheapest when I bought my Bosch late last year. Autozone will be really expensive. |
They are currently out of stock...
Here's my current progress. Fab'd and painted a piece of 12 ga metal as a mounting plate. The pic in the install shows a nice flat area to mount it....I wasn't that lucky.
Close-up view
Not-so-close-up view. (I also decided to round off the corners)
Hope to get more wires hooked up today. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba
takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Sun Jan 29, 2006 3:23 pm Post subject: |
you sure paid a pretty penny for that wiring kit. looking good though. i think im gonna go homemade with mine... |
Posted: Mon Jan 30, 2006 10:36 am Post subject: |
I figured I was paying for their engineering and knowledge.
Part of my slow progress is the fact that there are things I didn't think needed upgrading, but do.
Things I plan on upgrading:
1) Ignition Switch
2) Light switch
3) Dimmer switch for high/low beams
4) Alternator (to internal voltage regulator)
5) Louder horn _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
