CopperBaja Samba Member
Joined: March 29, 2005 Posts: 1725 Location: Santucky, CA LaJolla of EastCounty
Posted: Tue Jul 22, 2008 11:13 am Post subject: |
baja5 wrote: |
Don't know if it will work, but I can pick it up |
Now what good does that do me?
...might as well give me a balljoint and an ancient balljoint tool.... _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
rickosuave1987 Samba Member
Joined: April 19, 2006 Posts: 1299 Location: Glendale, CA
Posted: Tue Jul 22, 2008 11:38 am Post subject: |
If you use that one, it will sit sideways like the one in my car...I dont like it _________________ '69 Baja Bug
STFU |
Lotrat Samba Member
Joined: December 08, 2007 Posts: 2528 Location: Vista, CA
Posted: Tue Jul 22, 2008 12:54 pm Post subject: |
CopperBaja wrote: |
Bleeder on the MC???
That's a new one to me.... There's one there? |
Yeup #14
Posted: Tue Jul 22, 2008 1:12 pm Post subject: |
rickosuave1987 wrote: |
If you use that one, it will sit sideways like the one in my car...I dont like it |
The reservoir will? Do they make a sideways reservoir?
I'll try bleeding the MC first....then we'll go from there.
thanks lotrat. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Tue Jul 22, 2008 6:35 pm Post subject: |
CopperBaja wrote: |
I'll try bleeding the MC first....then we'll go from there. |
That didn't work...
And I have bigger problems. Any indication when the tach is going crazy, the engine is sputtering to stay running, then dies...won't restart, but give it a minute or two and it starts back up, like nothing happened? _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
motorbreath53 Samba Member
Joined: September 08, 2005 Posts: 901 Location: POWAY
Posted: Tue Jul 22, 2008 6:43 pm Post subject: |
You say the tach is going crazy when this is happening yes?
If so, sounds very ignition-ish..... specially since the tach shouldn't run off fuel.... mine doesn't anyway.
... electronic ignition mod? connections at coil? coil itself failing? plug wires tight? dizzy cap tight, and in good shape? clean fuel filter?
any nausea, vomiting or shortness of breath? Do you have any new desire to listen to Neal Dimond, or WHAM perhaps? _________________ Shameless buildthread plug:
..."cut n' turn in progress"... |
Posted: Tue Jul 22, 2008 9:13 pm Post subject: |
motorbreath53 wrote: |
any nausea, vomiting or shortness of breath? Do you have any new desire to listen to Neal Dimond, or WHAM perhaps? |
After reading a couple posts, I'm leaning twd a pts/timing issue....
Hopefully it's not the coil. Just bought a Bosch blue a mth ago.
I bit of shortness of nausea...I am getting sick of all this little stuff.
My buddy and his wife had a baby boy yesterday, so we spent the evening at the hospital. Lookin like some work to do tomorrow evening. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Wed Jul 23, 2008 9:03 pm Post subject: |
After some painful troubleshooting, I found that the points were arcing and grounding out the spark! Also found that my baja likes to sit around 20*...instead of the recommended 0* timing with a light.
Next...to find a dellorto tuning guide.
I have a pic that I will post tomorrow of the arcing points.
Now back to replacing the master cylinder. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Thu Jul 24, 2008 9:41 am Post subject: |
It's a grainy cell shot. I was really lucky to catch this in action...I left the key on and thought I would doublecheck the status of the cap and rotor.
68 Baja on STFU
68 Baja on Samba |
baja5 Samba Member
Joined: February 28, 2004 Posts: 4326 Location: Ramona,Ca.
Posted: Sat Jul 26, 2008 7:19 pm Post subject: |
How are you coming with the brakes?I put the car back together today so I am ready for a run if you want.Call me. _________________ http://www.wix.com/baja5s/nightrun |
Posted: Sun Jul 27, 2008 12:11 am Post subject: |
Didn't get the brakes "finished" til about 10:30...thought it would be too late to call.
No test drive yet either. At that point I had a couple beers and was a bit frustrated....had a couple setbacks during the procedure.
Did pick up a solid mount trans kit. Don't think I'll have it on by next weekend, though.... My 3/8" bit took a crap on me the other day. I have 1/2 of my front bumper mounted. I picked up a Bugpack breather box...just going to vent the oil filler for now, but it will be there for future use.
Only had time for a few hours on the baja today.
Still not sure on the adjustment for that brake rod....my book only says to not adjust it...to adjust the brake stop bracket. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
baja5 Samba Member
Posted: Sun Jul 27, 2008 7:26 am Post subject: |
Drive it up here today and we'll get the brakes worked out and then hit some trails. _________________ http://www.wix.com/baja5s/nightrun |
Posted: Mon Jul 28, 2008 1:16 pm Post subject: |
After I talked to you, I didn't run a relay for the hood lamps. They're actually pretty bright and should come in handy next week!
Glove box in. Still needs some cosmetics and the door.
Breather box mounted and line ran.
Hood lights wired and working.
Fuel gauge mounted, but not hooked up yet. That mount was $20 at pepboys. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
takotruckin SUPER Baja
Joined: August 14, 2005 Posts: 2378 Location: stuck in fresno, ca
Posted: Mon Jul 28, 2008 7:40 pm Post subject: |
but do the brakes work? _________________ Member of the baja's that don't run club, for now!! |
Posted: Tue Jul 29, 2008 8:31 am Post subject: |
takotruckin wrote: |
but do the brakes work? |
Yes. I'm not 100% on the rod adjustment or how they are "supposed" to feel. Gonna have to get a 2nd opinion this weekend....unless someone stops by....
I plan to do my solid mount on Friday. I bought this one from Veeparts. Same price as CIP1, but no shipping.
Pics...as promised.
68 Baja on STFU
68 Baja on Samba |
Posted: Tue Jul 29, 2008 8:32 am Post subject: |
Also started to mount the bumper....ran out of MIG wire and killed my 3/8" drill bit....still have to do the other side and finish this side.
The welds were crappy...I think it was partially due to running out of wire. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Wed Jul 30, 2008 9:23 am Post subject: |
VDO fuel gauge connected.
I grounded the sender wire and the gauge went to full....unlike the stock gauge. Looking like a bad sender.
Or...could be low on gas. (I'll find that out tonight)
I'm also a bit concerned about gas mileage, but I'll be bringing a fuel can. _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Wed Jul 30, 2008 4:50 pm Post subject: |
Adding a solid mount for the trans on Friday.
Any tips or suggestions? _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
Posted: Wed Jul 30, 2008 4:53 pm Post subject: |
Dont pull the trans completly. Just jack it up and install the mounts.
Mine fell on my foot moving it from the frame horns _________________ '69 Baja Bug
STFU |
Posted: Wed Jul 30, 2008 5:06 pm Post subject: |
Mine fell on my foot moving it from the frame horns |
I was going to pull the engine. And change the transaxle fluid while I have 'er opened up.
Any special tools that I'm going to need, besides the normal metric 19 and below? _________________ Look at my for sale ads.
68 Baja on STFU
68 Baja on Samba |
