The Bad and Ugly (Worst Home Repairs to a VW bus)
busdaddy
busdaddy is offline
PostPosted: Thu Sep 20, 2012 7:54 pm    Post subject: Reply with quote
Sorry, didn't notice the subject.....so is it at least a fine exotic hardwood like Ash or Maple?, or just lumberyard crap?
Muthashabubu
Muthashabubu is offline
PostPosted: Thu Sep 20, 2012 8:41 pm    Post subject: Reply with quote
No worries. Honestly, I hardly ever look at the subject either.
And it just seems like a piece of crap.
Joey Premium Member
Joey is offline
PostPosted: Fri Sep 21, 2012 6:23 am    Post subject: Reply with quote
Muthashabubu, so you bought this bus without first looking underneath it?
Joey
'74 Bus - '79 Panel - '56 Beetle - '65 Beetle - '60 Kombi
vintagevdubbers.ca
Muthashabubu
PostPosted: Fri Sep 21, 2012 11:51 am    Post subject: Reply with quote
Nope, I looked. I bought it how it is. And cheap. I'm not looking to restore it, just drive it. Once I get a running engine together.
Montana74
Montana74 is offline
PostPosted: Fri Sep 21, 2012 1:38 pm    Post subject: Reply with quote
Does NOT fixing anything count??? My BUs needed pretty much Everything fixed. Especially the Aquarium quality tubing for vaccuum lines, and the feul line going across the engine tin w/ no gasket as well. Yes, the fuel line was cut half way through!!!
1974 Standard Beetle.
Muthashabubu
PostPosted: Sun Sep 23, 2012 11:58 pm    Post subject: Reply with quote
Good save! How long did you own it before you noticed the fuel lines?
udidwht
udidwht is offline
PostPosted: Mon Sep 24, 2012 6:52 am    Post subject: Reply with quote
aircooledguy wrote:
I bought this . . .
and found this.
Perfect.
At first site I would have said, "next".
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Dual 40mm Webers (50 idles/125 mains/180 air corr./F11 tubes/28mm Vents - Float height 10.45mm/Drop 32mm
Bosch SVDA w/Pertronix module
NGK B5ES - .028 gap
Pertronix Flamethrower coil
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
1967250s
1967250s is offline
PostPosted: Thu Feb 07, 2013 9:24 pm    Post subject: Reply with quote
What do you expect from the great northwestrainforest? :lol: It can be saved, we have the technology!
Syncroincity
Syncroincity is offline
PostPosted: Sat Feb 09, 2013 8:22 pm    Post subject: Reply with quote
Never buy a bus with a bra on it... Laughing 2" thick Bondo.
Found this gem in a dealer's back lot in Beaver, PA around '89 or so. Type 1 motor, no key (nice hot switch panel, though) and a Stewart-warner tach planted in the clock hole. 3x3 steel rear bumper w/ hitch, I used it to tow my '70 Ghia vert down to Florida. The drivetain lived on to power a friend's cherry bay Westy he found without eng/trans.
'86 Syncro CHC Top AAZ Turbodiesel
'04 Passat Variant 4Mo 5MT
Vanagon Build: http://www.thesamba.com/vw/forum/viewtopic.php?t=466866&highlight=
CessnaJon
CessnaJon is offline
PostPosted: Sat Feb 09, 2013 8:31 pm    Post subject: Reply with quote
Nice mullet!
1973 Westy (shared birthday)
1976 MGB
1990 Westy Multivan
2015 Sportwagon TDI
Syncroincity
PostPosted: Sat Feb 09, 2013 8:51 pm    Post subject: Reply with quote
CessnaJon wrote:
Nice mullet!
Right? C'mon, 1989... I wish my hair was still that color.
Syncroincity
PostPosted: Sat Feb 09, 2013 8:58 pm    Post subject: Reply with quote
double post
Hefner
Hefner is offline
PostPosted: Sun Feb 10, 2013 5:02 am    Post subject: Reply with quote
Downunder we have a nickname for this sort of thing, It's called Bush Mechanics, My Dad was a terrible bush mechanic. Things like zip ties as throttle linkages, Plastic real estate signs to support rusty floors.
I mentioned to him that my rearseat 'Interior Trim' card kept falling off my 69 bug and when I got home from school he'd fixed it by screwing it in and the screws were sticking through to the outside.
I seriously learnt 'everything not to do' from my old man, he was a great teacher. Nowadays he comes other and watches me in my workshop, I carefully lay everything out, use correct parts, research everything first. If I stuff up I always think of my dad! lol
Here is an Aussie TV series called Bush Mechanics and you'll get an idea where the name came from
http://www.youtube.com/watch?v=H-tsKPlDn7U
1956 RHD Oval.
www.chrisgentle.com
www.customstreeter.com
Bala
Bala is offline
PostPosted: Wed Mar 26, 2014 10:36 am    Post subject: Reply with quote
I honestly don't mind the fuel sender access panel if it's done well, but this is just too much:
1976 Westy
1966 Beetle
VeeDubWolf
VeeDubWolf is offline
PostPosted: Tue Apr 29, 2014 3:00 am    Post subject: Reply with quote
Bump!
From the gallery of this fellow-
FlyingCoyote!
Bullets as fuses, didn't the Myth-busters do this one already?
oc92
oc92 is offline
PostPosted: Thu May 01, 2014 10:39 pm    Post subject: Reply with quote
I believe the worst fixes to be no fix at all. Neglect kills VWs. From rust, to valves to leaking seals to oil changes... doing nothing does the most hands-down.
" ... he walked the pavement of the city- a beggar and a king. Has it been otherwise with any man?" WOLFE
72 bus
70 bug
96 mx5
VeeDubWolf
PostPosted: Tue May 06, 2014 5:57 am    Post subject: Reply with quote
Mmm, quite true, quite true. One of the more interesting ones being the effect water has on a mag case, can you say- Wet kitty litter!?!
Busman1985
Busman1985 is offline
PostPosted: Thu Aug 10, 2017 7:08 am    Post subject: Re: The Bad and Ugly (Worst Home Repairs to a VW bus) Reply with quote
How do you like previous owners sway bar? I laughed when i bought this 74 and brought it home and climbed under it. And no I didnt drive it with this rebar sway bar, it hasn't ran since i purchased it.
cmonSTART Premium Member
cmonSTART is offline
PostPosted: Thu Aug 10, 2017 8:32 am    Post subject: Re: The Bad and Ugly (Worst Home Repairs to a VW bus) Reply with quote
That probably cost more for the welding wire than it did for the rebar to make it.
'78 Bus 2.0FI
Just us buses
Just us buses is offline
PostPosted: Thu Aug 10, 2017 4:28 pm    Post subject: Re: The Bad and Ugly (Worst Home Repairs to a VW bus) Reply with quote
I think the mud wasp egg cases are helping hold that together. You know, 30 or 40 yrs. ago these cars were cheap, disposable even. A lot were owned by poor people who did whatever they had to in order to keep going. I'm afraid of seeing something I used to own here. LOL
It doesn't matter where you start, it all comes together; it all falls apart.
Page 7 of 8
