andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Wed Aug 16, 2017 8:37 am Post subject: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
Doing some "redo" on an engine a tech did for me and it has new 1800 heads from aircooled.net as well as new P/C set from same. I have to reseal the cylinder/case joints, BUT he did not install the cylinder head/cylinder sealing rings. I have searched and not found a conclusive answer if they are to be used or not. I have emailed and left voicemail for aircooled.net and am waiting on response but sometimes that can take a couple days. REALLY would like to get this engine back together today. Does anyone know the answer? Thanks in advance.
P.S. My Bentley is not any help on this. _________________ D-Dubya Manx clone - 63 Short pan,1914.
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21474 Location: Oklahoma City
Posted: Wed Aug 16, 2017 9:14 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
Its normal.
Its pretty much universal now to not install them but instead lightly lap the cylinders to the head openings.
There were issues with burn throughs and leakage with factory head gaskets. There was also a VW technical service bulletin about removing the gaskets. I "think" it was mainly aimed at the 2.0L but serves better for all type 4.
Ray |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Wed Aug 16, 2017 9:20 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
I see it the same as Ray. No gasket required, and do lap the jugs to the head and the case... you will need to remove the case studs to lap them to the case.
BUT do not mistake this idea for leaving out Cylinder Shims! Those ARE required for correcting deck height when setting up your compression ratio. The shims are NOT gaskets, but look like them. I put the shims between the case and the jug, but a lot of people seem to put them between the head and the jug. |
SGKent Samba Member
Posted: Wed Aug 16, 2017 9:27 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
1975 - 1983 GD, GE, and CV coded engines. Copy of VW tech bulletin
http://kentcomputer.com/77VW/techbull.pdf _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Aug 16, 2017 9:52 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
Thanks - Thats exactly what I needed to know. _________________ D-Dubya Manx clone - 63 Short pan,1914.
busman78 Samba Member
Joined: August 17, 2004 Posts: 4518 Location: Oklahoma City, OK
Posted: Wed Aug 16, 2017 10:42 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
Someone correct me if I am wrong, andk5591 you mentioned "New 1800 Heads", if they are indeed new AMC heads then they come with the step in the head, at least the ones I remember, if those heads have that step you may not need the base shim. Steel base shims and the aluminum head gaskets are not interchangeable, different ID/OD |
Tcash Samba Member
Posted: Wed Aug 16, 2017 10:55 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
I would call aircooled. Some heads have the thickness of the head gasket built in and do not require shimming. Measure your deck height before you call.
Good luck
Tcash
"aircooled, During the mock up stage, you’ll have to order cylinder base shims to get the engine’s deck height between .040-.060″; we target .050″, so if you are off +-.010″ it’s not a big deal." |
Posted: Wed Aug 16, 2017 11:35 am Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
busman78 wrote: |
They are the AMC heads... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Wed Aug 16, 2017 2:35 pm Post subject: Re: Need help ASAP - do I need cylinder sealing rings type 4 1800 |
There will be a 1mm step in the chamber, check the deck, .035 to .040 would be ideal, my personal preference, whatever you are comfy with for compression, bolt that sucker back together. |
