dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Wed Jan 25, 2006 10:16 am Post subject: Opinions on 2nd CHT gauge |
I've ordered a new Cylinder Head Temperature gauge from Dakota Digital. Without reviving all the old arguments and debates from previous threads about CHT's, what should I do with my present VDO CHT gauge?
I've thought of running them both, just for comparison (mounted under different spark plugs), although the shortcomings of the VDO gauge are well known. Which cylinder is typically the second hottest (after #3)? Or I could hook it up to the coolest cylinder (which one?), as the accuracy of the VDO seems to be better at cooler temps. By the way, engine is a 2.0 L with F.I.
Or should I just get rid of the VDO gauge and reduce the dash clutter?
What have others done who have made the switch to the Dakota Digital CHT? _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
bdann Samba Member
Joined: December 23, 2003 Posts: 460 Location: Rowlett, TX
Posted: Wed Jan 25, 2006 11:45 am Post subject: |
I think a comparision of the two gauges might be interesting, but then as you note, since they'd be tied to separate plugs, the data might not be that useful.
If it were me, I'd just stick with the one gauge.
Actually, if it were me, I'd just stick to not having any gauges at all! |
USMCbug Samba Yoda
Joined: April 29, 2004 Posts: 2573 Location: Wichita, KS
Posted: Wed Jan 25, 2006 11:51 am Post subject: |
Couldnt both senders be on the same plug? That way you could see just how different they read? _________________ 72 Super Beetle
73 Standard Beetle
79 Baywindow Bus
65 Split Window Bus
79 Baywindow Bus
71 Super Beetle (current)
"When war does come, my advice is to draw the sword and throw away the
scabbard."
- General Thomas "Stonewall" Jackson |
Randy in Maine Samba Member
Posted: Wed Jan 25, 2006 12:01 pm Post subject: |
I am just going to sell my group of 3 VDO gauges to someone who wants them. Just haven't gotten to it yet.
Better than having nothing in there, but I don't have any extra space on my dash to have 2 CHTs. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Jan 25, 2006 12:11 pm Post subject: |
Give your old CHT to PaleoWagen, who started his thread about going to Montana. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
USMCbug Samba Yoda
Posted: Wed Jan 25, 2006 12:15 pm Post subject: |
Randy in Maine wrote: |
How much? _________________ 72 Super Beetle
73 Standard Beetle
79 Baywindow Bus
65 Split Window Bus
79 Baywindow Bus
scabbard."
SlowLane Samba Member
Joined: July 11, 2005 Posts: 1044 Location: Livermore, CA
Posted: Wed Jan 25, 2006 1:00 pm Post subject: Re: Opinions on 2nd CHT gauge |
dwill49965 wrote: |
Which cylinder is typically the second hottest (after #3)? Or I could hook it up to the coolest cylinder (which one?), as the accuracy of the VDO seems to be better at cooler temps. |
On my engine, #1 runs second hottest, generally 4 - 6 F lower than #3. Cylinders 2 & 4 generally run about 12 - 16 F lower than #3. 2 and 4 usually track each other within a degree or two. _________________ Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett |
steponmebbbboom Samba Member
Posted: Wed Jan 25, 2006 6:31 pm Post subject: |
I would get a double gauge and run a toggle so I can read both cylinders on either bank. |
Posted: Wed Jan 25, 2006 7:28 pm Post subject: Re: Opinions on 2nd CHT gauge |
SlowLane wrote: |
On my engine, #1 runs second hottest, generally 4 - 6 F lower than #3. Cylinders 2 & 4 generally run about 12 - 16 F lower than #3. 2 and 4 usually track each other within a degree or two. |
Thanks, SlowLane, and everyone else for suggestions.
After further thought, my dash IS too cluttered, but I am now thinking that I might just mount the VDO in the engine bay, on cylinder #1. I also have a spare vacuum gauge lying around that I could mount back there, too. Along with my permanently mounted fuel pressure gauge, that would make 3 gauges back there, providing a nice symmetry for the three that I have mounted under the radio up front .
Ahhhh, too complicated. I think I'll just sell the thing......
I should have asked this question as a poll. _________________ Darryl
Meyer wrote: |
