Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Mon Jan 30, 2006 10:03 am Post subject: Bug vs. Bus mufflers |
Other than one outlet vs. two is there a difference between type 1 and type 2 mufflers (1600cc engine)? Are the internals different? I need to replace the muffler on my bus and I have a new bug muffler here and I was wondering if I could just weld up the right-side outlet and use it. _________________ OGST
Samba Member #4862 |
ronnie Samba Member
Joined: May 01, 2002 Posts: 1053 Location: lost somewhere between the earth and my home.
Posted: Mon Jan 30, 2006 10:24 am Post subject: Re: Bug vs. Bus mufflers |
Mr. Bubblehead wrote: |
I was wondering if I could just weld up the right-side outlet and use it. |
i've asked this in the past and was told i could not, i'd love for someone to tell me different, i still have a few nice bug mufflers laying around |
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Mon Jan 30, 2006 10:42 am Post subject: |
I think the internals are differant, I had a friend who did this and it made the engine run hot and like shit, like it was blocking up one side of the engine. |
VWBobby Samba Member
Joined: April 21, 2004 Posts: 1537 Location: Central Oregon Coast
Posted: Mon Jan 30, 2006 12:35 pm Post subject: |
A stock bug muffler sucks enough power as it is, image how bad it would be with 1 outlet welded shut! It would be like sticking a banana in the tailpipe. |
Wayland Samba Member
Joined: December 29, 2005 Posts: 498 Location: Lasqueti Island B.C.
Posted: Mon Jan 30, 2006 8:13 pm Post subject: |
It depends on the muffler. As far as I know bus and bug mufflers are the same inside (really not much inside them at all!) What you would have to consider though is what side the heat riser pipe comes down. It must exit in to the tailpipe (so you want one w/ the heat riser pipe coming down on the lt. side) You'll also have to fabricate a bracket to support the tail pipe. Unless you are attatched to the stock look, why not go for a header and single QP system. Stock mufflers are VERY innefficient, and restrict motor too much in the high rpms. |
oilspot Samba Member
Joined: July 11, 2002 Posts: 909 Location: Southern NM
Posted: Mon Jan 30, 2006 10:10 pm Post subject: |
Wayland wrote: |
I'm running a 1776 with a stock bus muffler. I had it running on a single quiet pack at first and changed over to the stock unit. I can't really tell any differance, except that the stock bus muffler sounds, and looks better.
Yeah mabey you can see some differance on a dyno, but it's a bus. If i'm looking for performance my first step would be to not drive a aerodynamic brick.
Sorry for the partial hyjack, I just regret running a quiet pack for so long, worrying about the huge power loss I may suffer going stock. |
Posted: Tue Jan 31, 2006 5:55 am Post subject: |
Wayland wrote: |
My plan was to use this muffler that I already have, since it wouldn't cost me anything. But if it won't work and I have to spend money I will look into other options. I am good with welding so fabricating brackets is no big deal. _________________ OGST
iamdonquixote Samba Member
Joined: January 28, 2003 Posts: 2041 Location: M*ssholia
Posted: Tue Jan 31, 2006 7:26 am Post subject: |
this is good to hear, i am considering a 1776 w/ dual carbs 35mm & a stock exhaust. everyone says it won't work well, but until Ronnie unviels his muffler I'm not willing to get the empi,bugpack, etc header/muffler crap |
guatebus Samba Member
Joined: May 12, 2003 Posts: 393 Location: Oakland, CA
Posted: Tue Jan 31, 2006 8:29 am Post subject: |
I ran into this issue last year when I got rid of a crappy header on my 1600dp. I wanted to go stock muffler to experience the joys of a properly functioning heat riser. Unfortunately none of the VW parts shops where I live (Central America) had bus mufflers...only bug mufflers were available. I didn't want to pay huge dollars for overseas shipping of a (heavy) muffler from the States so I went with the bug version.
I considered closing off one outlet but what I did finally was rig up a two outlet system. Of course you don't want to have the pea shooter pipes cause that entails hacking the rear apron and other barbarities. I had the local muffler boys weld up brackets and bend tail pipes, one on the left and one on the right. So it kind of looks stock with the tail pipe exiting to the side/rear, only I have two tail pipes instead of one.
Perhaps this is a bad idea and I'm totally ruining my engine or something, but it seems to be working OK. Just another option you may want to consider.
Guatebus |
Posted: Tue Jan 31, 2006 8:32 am Post subject: |
It can also harm the engine. It builds a lot of heat in the heads when you have a restrictive exhaust. Combine the restriction with the fact you are pushing a 2200lb loaf up a hill, and the engine is not happy. Of course most people aren't looking for performance in a bus, but at least research what you're doing. |
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Tue Jan 31, 2006 8:52 am Post subject: |
guatebus wrote: |
Guatebus |
Can you post a picture? _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Tue Jan 31, 2006 10:56 am Post subject: |
I don't have a photo or camera handy, so I used photo editor to hack up a photo someone posted in the gallery. My setup kind of looks like this:
With the apron and bumper on you can pretty much only see the ends of the tail pipes.
- Guatebus |
pyrOman Fire Master
Posted: Tue Jan 31, 2006 11:21 am Post subject: |
That is actually a pretty "trick" looking muffler! _________________ Some people are so busy being clever they don't have time enough to be wise. |
15 windowdelux Samba Goober
Joined: February 06, 2001 Posts: 432 Location: Hastings, Nebraska
Posted: Tue Jan 31, 2006 5:08 pm Post subject: |
Heres another option using a stock bug muffler. Just weld a bend into the muffler and have it exit below the stock bumper. _________________ My last fortune cookie said:
"A short saying oft contains much wisdom."
Why is it all I can think about now is George
Carlin's "Seven words you can't say on television"???? |
Andrew Samba Member
Joined: October 27, 2000 Posts: 5865 Location: Who in the what now?
Posted: Tue Jan 31, 2006 6:24 pm Post subject: |
Personally, on a 1600 sp, I felt a noticeable difference between the stock muffler and a header. I didn't lose as much speed on hills with the header over the stock muffler. I ended up running stock, though, just because it was quieter with better ground clearance.
As for stock mufflers, though, you can usually pick them up at swap meets pretty cheap. The last one I got, I paid like $20 for at a swap. _________________ -Andrew |
Split Decision Samba Member
Joined: August 25, 2003 Posts: 675 Location: Katy, Texas
Posted: Wed Feb 01, 2006 8:20 am Post subject: |
I thought that if you used anything that didn't exit out the side you risked sucking exhaust fumes back into the cabin/engine? _________________ In 1966 Volkswagen pinched my loaf.
67 Deluxe
On year seven of the "I'll get it done next week" engine rebuild.
74superTN wrote: |
Just seems these days that unless you are dragging your engine on the ground and have crazy negative camber, people seem like you're doing it all wrong. |
Andrew Samba Member
Posted: Wed Feb 01, 2006 9:26 am Post subject: |
Split Decision wrote: |
I thought that if you used anything that didn't exit out the side you risked sucking exhaust fumes back into the cabin/engine? |
That is true. So if you do have an exhaust that exits to the rear, be sure you have a good rear hatch seal. _________________ -Andrew |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Thu Feb 02, 2006 6:29 am Post subject: |
Andrew wrote: |
That is true. So if you do have an exhaust that exits to the rear, be sure you have a good rear hatch seal. |
i've never heard of this before? tell me more. _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Thu Feb 02, 2006 7:32 am Post subject: |
Thanks for all the info. If I have to buy something (looks like I will) I think that I would prefer a header with a single or dual QP muffler. Can anyone recommend a good header to use, one that has heat risers on it for the carb? I also would like one that clears the apron, but I don't want the exhaust dragging on the ground. I currently have one of those EMPI 4-tip exhausts (came with the bus) and 1) it looks ugly, and 2) it is too close to the apron and has burned off all the paint. _________________ OGST
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Thu Feb 02, 2006 7:37 am Post subject: |
Thanks for all the info. If I have to buy something (looks like I will) I think that I would prefer a header with a single or dual QP muffler. Can anyone recommend a good header to use, one that has heat risers on it for the carb? I also would like one that clears the apron, but I don't want the exhaust dragging on the ground. I currently have one of those EMPI 4-tip exhausts (came with the bus) and 1) it looks ugly, and 2) it is too close to the apron and has burned off all the paint. |
good headers, in my experience only come from S&S or berg. |
